Question about SMC Barricade g SMCWBR14-G (662698582192) Router
I cant log in to my smcwbr-14g router. Everything seems to be ok, like all the neccessary leds are lit, still it is like not connected. My utp cable is good for sure, cause I can connect with it directly to the modem. Any idea? Thanks!
  • 59 Answers
SOURCE: wireless
Router is probably configured incorrectly. Try this... Turn off cable modem and router for 1 min. Turn on cable modem...when done booting..turn on router...check for internet. If no...log into router and make sure it is NOT in PPOE but rather in dynamic mode. Good lUck
Posted on Sep 10, 2007
sandrew
  • 2961 Answers
SOURCE: My router doesnt seem to be Broadcasting the wireless connecition!
it may be that the router is not assigning ip addreses properly, and is duplicating the ip address on all pc's. or you have done the windows diagnose and repair or detect problems. Go to the properties of each wireless card in control panel>network connections and on the TCP/IP line click propertes again and ensure obtain ip address automatically is checked. Also go into the routers settings and ensure DHCP is enabled to give all pc's an automatic ip address. Restart all pc's and your router (not Reset) and you should get renewed ip addresses and be able to connect.
Posted on Sep 13, 2007
  • 173 Answers
SOURCE: Dropping internet connection
check if this problem is with both wired and wireless computers, if not with the wired..only wireless has problems, check if you have any other wireless device operating in the same frequency of the router..if s, turn off other devices and check b.cos that me interfere your w/ls connection, if wired is having the same problem, connect modem straight to the pc and observe the connection, so that you can isolate problem..
Posted on Nov 16, 2007
SOURCE: My laptop cannot locate my network
have you tried MAC filtering to remedy your problem?
Posted on Mar 24, 2008
ziraffa
  • 827 Answers
SOURCE: Using Wireless + PPPoE at the same time kills router. SMCWBR14-G2
From your description, I am assuming you have a direct ethernet connection from an RJ45 connection in a jack in the wall. If this is the case, then you would just need to purchase a wireless router (linksys, D-link, netgear, etc). Connect the ethernet connection from the wall to the routers internet or WAN port. You will need to access the routers firmware configuration and set it to connect with PPPoE, so get your username and password from your ISP if you are not sure what it is.
You will be able to continue to have the PC plugged into the router with an ethernet cable, and then run the laptop with a wireless connection, just be sure to configure the laptop with the security key if applicable.
If you were using a software PPPoE connection on your PC, quit using it. Just set your network adapters on both computers to DHCP, and you should be good to go.
Hope this helps
Chris (ziraffa)
Posted on Jan 14, 2009
Am having a problem with my yuotube when i click on it i dont see any thing i try every thing but throw it out the window
is your router lit on the internet connection?
if its not then your router is broken...
and if there's a lit on internet from your router
then check on your PC Lan connection if it is connected.
then if not maybe your UTP cable is damage
or Install a lan card..
Or if the website youtube is your problem but you are connected to the internet then try to update your adobe flash player..
hope this will help
Jun 26, 2011 | Computers & Internet
Have Linksys WRT54G2. All port led's are lit and
How is your router connected? If you have all port lights lit, either green or orange, and nothing connects seeing the Internet, are your problems with wireless access? Is the Wireless set correctly, by going to http://192.168.1.1 and logging in to the router? Make sure the SSID (network name) and other security measures are set correctly ... I prefer WPA-PSK[TKIP] for its simplicity. You will need the passcode you choose to log in with wireless devices.
Nov 11, 2009 | Linksys Wireless-G WRT54G Router
Link 1 lit up and no more connection to internet
You may have been hit by lightning or power surge which knocked out one or 2 ports. If the WAN port is out you may still be able to use your router as a hub provided your modem can be configured as a router (many newer ones can) . Connect one of your working LAN ports to the modem and others to your computers.
May 22, 2009 | D-Link DI 514 Wireless Router (DI-514)
Unable to connect with dlink300 router
You must configure first its settings both on your network card and router. See you manual.
First you must connect your internet directly to the computer then get its DNS settings, jot it down. Then connect the router lanport1 to lan card port of your computer using LAN cable. Under lan properties goto TCP/IP settings input the default IPaddress 192.168.0.1 of the router then its subnet mask commonly 255.255.255.0, the router's default gateway, input the DNS settings of your ISP 2 of the set.
Then goto default router's utility web. Open internet explorer, key in router's ip add 192.168.0.1 you should go to router's configuration log in user = admin, pass = just hit enter. Set your time and date then save. You could also test its connection by pinging the IP address of router. on windows DOS. Type ping 192.168.0.1 you should get 4 lines.
If everything is set. Connect the internet cable(UTP/LAN cable) to its WAN port of the router then test to browse the internet. If not then change the DNS settings with the remaining set (on Lan setting).
If I miss something just leave a comment.
May 22, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I cant connect my computer to the orinoco bg 2000 router. the light on the lan does not appear on the router. what should i do to make the router work?The cable i bought to connect my pc to the orinoco bg...
hi, you have to note one thing. there are two types of devices. one is DTE and another one is DCE. DTE included Computer, Router etc, DCE includes Switch Hub etc. DTE to DTE is crossover cable. DCE to DCE Cross over cable. DTE to DCE or DCE to DTE is Straight through cable. Ok? Here you have to change the cable type to cross over cable. If the problem again persists dont hesitate to mail to me.
May 02, 2009 | Proxim ORiNOCO BG-2000 (700003212) 802.11b
How to connect two remote device with a phone line in between.
no, not with a phone line... you could but making a bridge connection with an utp cable... but with all respect, if you were thinking about a telephone cable you are surely not qualified to do that bridge without assistance... so i recommend the following.
You surely know that UTP cable (lan cable) supports a distance up to 90 metres which is about 295 feet. If you need to go outdoor for that connection i would recommend outdoor cable for that connection its very cheap... and you dont need two routers if you just have four computers tops...
other stuff like amplify antennas might help your reach the far away computer via wireless...
other way is to find info on how to build a bridge with two routers on the net by searchin on google, its not that hard, but you still need utp cable... never phone line.
Mar 17, 2008 | Computers & Internet
Unable to connect to internet on desktop pc
does your utp cable crimped correctly? have you tested this? try to use this utp cable to your laptop if its okay then follow the instruction as what is written in the manual, i also experience like this with my 4pc's before and i found out that the utp cable i crimped was not properly done. in the case of the DI-524 this is just a plug and play you don't need to configure.
Dec 10, 2007 | D-Link AirPlus DI-524 Wireless Router
Cannot Log on to my Router
These steps solve most of the problems with logging on to routers. 1. Connect a computer and a router directly with an Ethernet cable, putting an end in one of the router's LAN ports. Check that both ends are secure. 2. Check the Internet LED is lit. If it is not, troubleshoot the light status, as explained in the manual. 3. Check that the LEDs for the ports with cables are lit. If they are not, try moving the cable to a different port. If there are still no lights, then troubleshoot the light status, as explained in the manual. 4. Check the LED on the Ethernet adapter is lit. If it is not, then troubleshoot the adapter, do not continue with this document. If the Ethernet adapter was not made by NETGEAR, contact the adapter's maker. 5. Select Start > Run. Type cmd. Type ping 192.168.1.1. If there is a message "Request timed out", type ping 192.168.0.1. If that also has a "Request timed out" message, then your computer is not making a connection to the router. 6. Otherwise, your computer is connected to the router: * Make sure proxies are not enabled. If using Internet Explorer, select Tools > Internet Options > Connections > LAN Settings. Uncheck "Use a proxy server for your LAN....". * Delete offline contents. Select Tools > Internet Options > Delete Files. Select Delete all offline content, and click OK. (This is to clear any possible previous router log on page.) * Try accessing with a different computer, or with the Netscape browser, if you have it. * Delete cookies. WARNING. Do not do this if it's possible Web sites you visit need cookie information such as your logins and passwords. 7. Power off the router, and power it back on again. 8. If you still cannot log on to the router, then do a hard reset on the router. (Described here: http://www.fixya.com/ThreadView.aspx?thi...) 9. If you know how, check the computer's IP address and DHCP. The IP should be in the 192.168.0.x range, and DHCP should be enabled.
Feb 19, 2006 | NetGear RP114 Router
These steps solve most of the problems with logging on to routers. 1. Connect a computer and a router directly with an Ethernet cable, putting an end in one of the router's LAN ports. Check that both ends are secure. 2. Check the Internet LED is lit. If it is not, troubleshoot the light status, as explained in the manual. 3. Check that the LEDs for the ports with cables are lit. If they are not, try moving the cable to a different port. If there are still no lights, then troubleshoot the light status, as explained in the manual. 4. Check the LED on the Ethernet adapter is lit. If it is not, then troubleshoot the adapter, do not continue with this document. If the Ethernet adapter was not made by NETGEAR, contact the adapter's maker. 5. Select Start > Run. Type cmd. Type ping 192.168.1.1. If there is a message "Request timed out", type ping 192.168.0.1. If that also has a "Request timed out" message, then your computer is not making a connection to the router. 6. Otherwise, your computer is connected to the router: * Make sure proxies are not enabled. If using Internet Explorer, select Tools > Internet Options > Connections > LAN Settings. Uncheck "Use a proxy server for your LAN....". * Delete offline contents. Select Tools > Internet Options > Delete Files. Select Delete all offline content, and click OK. (This is to clear any possible previous router log on page.) * Try accessing with a different computer, or with the Netscape browser, if you have it. * Delete cookies. WARNING. Do not do this if it's possible Web sites you visit need cookie information such as your logins and passwords. 7. Power off the router, and power it back on again. 8. If you still cannot log on to the router, then do a hard reset on the router. (Described here: http://www.fixya.com/ThreadView.aspx?thid=102071&prdid=252225) 9. If you know how, check the computer's IP address and DHCP. The IP should be in the 192.168.0.x range, and DHCP should be enabled.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
SMC Barricade g SMCWBR14-G (662698582192) Router Logo
129 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
