Question about Cycling
I need help trying to install tektro front brake setup on my bmx bike.. i think they are caliper brakes.
    Brigadier General:
  • 8,546 Answers
Google "install tektro front brake download" - lots of hits and docs from Tektro.
Posted on Mar 24, 2011
Replacing front brake pads 2001FXST
Front Brake Caliper: All But FLSTS/FXSTS
Remove the front master cylinder reservoir cap to be able to check the fluid level as the caliper pistons are pushed back into the caliper because the fluid level may rise more than the 1/8 in. (3.2 mm) from the top level and you may have to remove some excess fluid if it does so. THEN loosen but do not remove both pad pins with a 12 point one quarter inch socket. THEN remove both metric caliper mounting bolts and remove the caliper from the front forks and brake disc and pry the pads back to force all four caliper pistons into their bores. THEN once the pistons have been retracted, remove the pad pins and the brake pads.
Although the front and rear brake calipers except FXSTD models, use the same exact brake pad set the FXSTD does not and the FXSTD rear pads have a vertical slot cut into the pads. Be sure NOT to substitute front and/or rear brake pads for the other on these bikes. On the right side of the vehicle the pad with the two tabs installs on the inboard side of the caliper and on the left side of the vehicle, the pad with the two tabs installs on the outboard side of the caliper.
THEN install new pads into the caliper noting that the curved portion of the pad faces to the rear of the bike, and loosely install the pad pins until you hear an audible click from them. THEN re-attach the caliper to front fork, place the caliper over the brake disc with the bleeder valve facing upwards, loosely install the long caliper mounting bolt into the top hole on the fork leg, install the short mounting bolt into the bottom hole on the fork le, tighten the bottom mounting bolt to 28-38 ft-lbs (38.51.5 Nm) and final tighten the top mounting bolt also to 28-38 ft-lbs (38.51.5 Nm) and final tighten the two pad pins to 180-200 in-lbs (20.3-22.6 Nm).
THEN and whenever new pads are installed, before moving the bike pump the brakes until brake fluid pushes the caliper pistons and the pads out and verify that the pads are against the brake disc and then rotate the wheel to ensure there is not any excessive drag between the pads and the disc, check for proper fluid level in the reservoir and if necessary top it up with DOT 5 Silicone base brake fluid only, install the reservoir cover and tighten its screws to 6-8 in-lbs (0.7-0.9 Nm).
THEN and whenever any work has been done on brakes always test the brakes at low speed before operating on a roadway or at higher speeds. THEN test brake system light and if during the road test the brakes feel spongy at all bleed the system and after obtaining a hard lever or pedal road test the bike again.
Oct 04, 2014 | Cars & Trucks
My brakes work when sitting still, but will not stop bicycle in motion/under power
There are multiple possible reasons:
1. Brake caliper is not adjusted so pads are within 1/8" or so of rim (rim should be straight enough to allow that).
2. Brake pads are old and hardened.
3. Too much friction in brake cable and housing
4. Brake cable housing is too long, allowing too much flex.
5. If brake levers have been replaced wrong levers were installed.
p.a. It is helpful to know whether a problem is new, has developed gradually over time, or has always been there, and if any maintenance or event occurred just before the problem began.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Jan 30, 2018 | ProMax 197NC Bmx V Type Brake Set, Rear,...
Does the Eastern 2010 Night Prowler have front brakes?
I am unfamiliar with this bike but most do have front and rear brakes . You should be able to see brake calipers mounted on forks and they are operated by hand lever on right side of handlebars.
Aug 25, 2011 | Eastern Bikes 2010 Night Prowler BMX Bike
My bike got crushed by the garage door: back linear tektro bent to side and wheel spokes broke, wheel looks bent. Is this a costly repair? Ladies wildwood. Thank-you.
What's the whole bike cost? Normally every part of the bike except the frame is replaceable economically - which is subjective.
Tektro brakes or equivalent - cheap; wheel - probably cheaper than a rebuild; labor - unknown.
If the frame or the brake bosses are bent - fuhgetaboudit. Take it to a Bike Shop for evaluation. They can just hang new wheels on it and see how straight everything else is.
Jul 29, 2011 | Raleigh Diamondback Maravista Bicycle
The brakes type tektro cannot stop the byke.
The brake shoes may be worn out or they are installed wrong, you have to set the brake shoe so that the front of the shoe is toed in to touch the rim first, in other words, it has to hit it first. Brakes setting is really not for amateurs, have someone who really knows bikes look at them because your life depends on it being right.
Sep 25, 2010 | Mongoose Gravity Games BMX Bike
My new Brakes Tektro Novela are sqeaky and noisy. What can I do?
A lot of pads are unfortunately. They will become a little better after a few hours of riding as they do "bed-in" a bit but the longer wearing the brake pad is the noisier it will usually be.
Jun 09, 2010 | Mountain Tektro Disc Brake Pads Gemini...
Whats the difference between the gsf600 and gsf1200 front brake discs will 1200 front brake discs fit a 600
think the disc them selfs are bigger on the 1200 than the 600...also they have diffrant brake calipers as well on each bike...so i dont think 1200 disc & calipers will fit the 600
Mar 04, 2010 | 1998 Suzuki GSF 1200 Bandit S
Havin problems puttin the brakes on they have givin us the wrong instructions
Try this website:http://www.bikeguide.org/how-to/brakes/brakes.php It might give you some ideas.
Sep 28, 2009 | Hawk Tony Boom Boom Huckjam 20-Inch BMX...
On my freestyle bike, I can't get the front brake to lock up.
This site might help:http://www.bikeguide.org/how-to/brakes/brakes.php
Sep 01, 2009 | Mongoose 20-Inch Gravity Games BMX...
BMX bike rear braking system
put WD40 or soome greese on it.
Jun 15, 2009 | Cycling
Cycling Logo
123 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
