Question about Dishwashers
I have an asko 1776 and the f2 flashes. I opened the bottom part. I can't figure out where the float, switch is? There is not water in the pan.
  • 55 Answers
The float switch is the small square Styrofoam piece in the front of the base pan. You can watch a video that explains about what which part is at the link below.
Appliance & Refrigerator Repair
Posted on Mar 23, 2011
How do I test the float switch and the pressure switch in an Asko D1976 dishwasher? Getting F2 with no water in the pan or in the machine.
i would assume be n/o.
if have VOM put on OHMS setting. touch ur leads together listen for tone. once verified it works. put on the terminals on switch. and manully switch it, to see if makes or breaks the contact
Nov 22, 2014 | Asko D1976 Built-in Dishwasher
Pump continually running with F2 displayed.
There is water in the lower pan that you must access by removing the toe kick plate and then the panel behind it. you will see water in the overflow area. Clean that out and all will be well. Asko's are awesome dishwashers that capture any water they may overflow or leak internally instead of it going on your floor, then a float switch triggers the F2 error and runs the drain pump.
May 30, 2012 | Asko D1716 Built-in Dishwasher
F2 and all panel lights flashing part way through cycle. Machine will not switch off unless you switch power button off
Hi
You have water in the bottom pan.Turn off power Remove bothe front and rear lower panels and dry out pan with a towel after tipping water from pan. Turn on power and try operating the washer and look for water leak. It could be coming from a number of places. The repair will be what ever is the cause of the leak. F 2 = water in the pan. Hope this helps. Rgd Robocam
Mar 07, 2011 | Asko D1876 Dishwasher
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
Our Asko D3112 was not draining, so we had maintenance drain the hoses to clear any blockage but it did nothing. They said it must be our pump not working. I ran one more cycle to see if things went back...
Check your manual to see if you have a drain pan at the bottom of the unit, and a 'float' that checks for water collecting there. On at least some Asko models, water collecting in the pan causes the float to rise, which then changes the operation of the dishwasher. Once that float switch turns on, the diskwasher will always run the drain pump whenever power is applied.
If this is the case for your machine, remove the kick panel. There likely is another panel behind that which covers the 'internals', including the drain pan area. You'll have to remove all of the water in the pan, and that will lower the float and return the controller to normal operation. THen you will have to diagnose the cause of the water collecting in the pan.
Another possibility is damage to the float such that it has turned on it's switch despite no water collecting in the drain pan. I've heard that in some cases a mouse will chew on the float and damage it, causing such machine operation.
In another thread, I posted my solutions to one cause of water collecting in the drain pan. In that case the drain pump was no longer reliably moving water out of the sump area inside the dishwasher. I had thought it was the manual dial control on my d1706 unit, until I learned that the dishwasher has this 'special' drain pan mode.
Jul 07, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
Asko Dishwasher F2 Fault
i have an asko washing machine that is displaying f2 how do i fix this problem myself without calling any one in
Jan 21, 2008 | Dishwashers
Asko 1805 Frozen
Sounds like the controlunit is bad.
Jan 01, 2008 | Asko 24 in. 1805 Built-in Dishwasher
Asko Dishwasher F2 Error Flashing
F2 flashes, and wll not stop runing. No water in pan. help
Sep 29, 2007 | Asko D1776 Built-in Dishwasher
F2 error message flashes, cannot reset.
Try to find out from where water leaking from (pump or inlet valve). The leaking one, should be replaced. Good luck !
Apr 22, 2007 | Asko D1976 Built-in Dishwasher
Dishwashers Logo
104 people viewed this question
Top Dishwashers Experts
