Question about Webroot Spy Sweeper (spysweeper) for PC
It sweeps forever but hangs up at about file/folders 20, 076. I can't stop it. I reboot and then set it not to sweep, it does it anyway. I can't delete it in task manager either.
  • 2,229 Answers
When software does weird things like this, my first thought is to uninstall it and then reinstall it.
Do not run any other spyware software at the same time.
Posted on Mar 23, 2011
How do i delete cookies from my IRULU 7in.tablet
That would be done in the browser, in the settings. While you are there, you can also delete the cache files - also in the settings... a good thing to do once in a while.
Jan 26, 2015 | Tablets & eReaders
I have been using spy sweeper for a couple of years and have had no problems until last week. Every time I try to run a sweep the program hangs my system so hard it requires a power reset. During a sweep...
boot the maschine in secure modus, backup your stuff !!!
1st solution is to try to re-install spysweeper, but as i have done a few times as so... its better to uninstall it fully, reboot, remove settings from sweeper in registry;
reboot again;
if everything goes well, install sweeper again;
if not after having confirmed, that your data is securely back-uped to external media, re-install system.
other case bevore, try to reset system to good working situation, but as you wrote, you removed dll... hmmm... think ur system s badly damaged. sweeper sometimes does fragment parts of system so badly, that theres no other option.
u could try to check system with other sweeping tool... happens, that bug gets looping system...
good luck
Ganimidis
Mar 04, 2011 | Webroot Spy Sweeper (spysweeper) for PC
Ice maker hanges up ice forms on blades
Hi and welcome to FixYa. I am Kelly.
Usually when ice (teardrops) form on the sweep blades it can be caused by a couple of things.
1. A dirty freezer door seal
2. A torn freezer door seal
3. Separation in the freezer door.
4, Calcium build up on the sweep blades.
Give the door seal a serious look for dirt and tears.
If the door seal looks ok and is clean then...
Wash the icemaker sweep blades with a mixture of vinegar and water. Give the freezer door some attention with that same mixture. Oils from hands or food can prevent a good seal on the freezer door. Just make sure you clean the icemaker sweep blades FIrst...
Do not use a new scotch brite pad on the sweep blades. USE an OLD one.... scratches on sweep baldes invite condensation when the door is opened.
Make sure to toss the next few cycles of ice cubes.
Doing the above should stop the ice build up on the sweep blades unless you have folks or visitors in the home that love holding the freezer door open for longer than normal.
Thanks for using FixYa.
Kelly
Feb 09, 2010 | Refrigerators
How do i turn back on spy sweeper and my micro trend internet security
In order to disable the Anti-Virus components of Webroot Anti-Virus you must go to two separate sections:
Anti-Virus Shield Disabling
1. Click on the Options button on the left hand side of Webroot Anti-Virus
2. Go to the Shields tab of the Options Menu
3. Under the section labeled Anti-Virus Protection, take the checkmark out of the Protect against Viruses box.
Anti-Virus Sweep Disabling
2. On the Sweep tab, put the dot into Custom Sweep (please note you can only disable Anti-Virus Sweeps by using the Custom Sweep option)
3. Under the section labeled Sweep Settings Summary, click the Change Settings link which is next to Custom Sweep Settings
4. A Custom Sweep box will appear with various sections to click on. Click on the What To Sweep button on the left side of this Custom Sweep box.
5. On this screen, take the checkmark out of Sweep for Viruses under the Viruses section.
6. Click the OK button at the bottom of this screen and you will be returned to the Sweep tab. (Again please note that you can only disable Anti-Virus Sweeps by using the Custom Sweep Option which will now be selected)
Jan 22, 2010 | Microsoft Windows Vista Home Basic for PC
Vertical bars and lines run up and down the screen. Need service manual or parts outlet
There is no such thing as a "vertical sweep circuit board" in that set. The vertical circuit is part of the sweep module. And BTW that type of symptom is more often a power supply filtering problem anyway.
May 05, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Spy sweeper
In which place you click on the icon of sweep.
In the menu, on the screen or directly from the directory where you can find the sweep.
There are all kind of possibilities.
Problem with the registry.
File is moved
Version expired.
Probably the easiest way is to reinstall sweep.
Nov 05, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Webroot spysweeper won't sweep
i had the same problem getting also an error message when i would log in about a valid definition file and go to program option page to update the definition file, after trying fixes from others i found one that said to reboot computer and put in safe mode, then open spy sweeper in safe mode, everything was in large print and nothing was turned on, so i rebooted the computer again and this time when the screen came up came up normally and not in safe mode and most of all there was no error message, my spy sweeper is now opened and now it is sweeping like it is suppose to do i don't know who was the person that posted the resolution but thanks it works so everyone try it.
Aug 01, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Spy Sweeper won't sweep
I have seen this problem a couple times. The only fix that seems to work is uninstalling Spysweeper and then reinstall it again. If you go to start>Programs>webroot you will see an uninstaller. Run that, reboot the computer, then reinstall again from your install disc.
Jun 04, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Oct 09, 2007 | Watches
Webroot Spy Sweeper (spysweeper) for PC Logo
Top Webroot Computers & Internet Experts
Mike
Jerry
Jerry
Are you a Webroot Computer and Internet Expert? Answer questions, earn points and help others
