Question about Car Audio & Video
I'm installing a Handsfree Cellphone dock and need power, preferably from radio area
  • 115 Answers
Usually you find an empty 12v or 5v source from the fuse block and use a fuse adapter with an inline fuse to "tap" in to a power source. piggybacking off the raido is not recommended as it can cause undesired side effects. the fuse adapters are located at any auto parts store. roughly five dollars.
Posted on Mar 23, 2011
How do I turn on the bluetooth
On the cellphone menu there will be a set of preferences and settings for Bluetooth. Scroll through the menu options. Make sure the headset is on. The phone should list the detected devices. Activate it from that menu.
Nov 25, 2014 | cellphoneshop.net BH29 Boom Mic Bluetooth...
My Delphi SkyFi2 power goes off when I hit a bump in my car
You most likely need a new dock with a solid DC jack connection. Also, there is a "lock" on the back of the dock to hold your SkyFi tuner in the dock tighter. I'd give you one of my docks if you lived nearby! Good luck and let us know what you find out.
Oct 02, 2014 | Delphi SKYFi2 SA10101 XM Radio Receiver
I installed an mki9200 into a 2007 ford expedition but it seems to not get any power at all I am using a plug and play harness i don't know why it's not getting power
Not all vehicles have a ignition supply at the radio as they use the canbus system to turn things off and on. You will need a multi meter to check if there is power on the correct wires and you my need to pick up the ignition from the fuse box. Parrot web site has details of the accredited engineers in your area.
Jan 01, 2012 | Parrot SA Parrot MKi9200 Advanced Color...
The sportster will loose power / disconnect with no warning. i am able to get t to turn back on by shaking the entire unit. I had the sportster removed and installed it in a car unit at a best by and the...
Get a new dock if you think its the dock. If that doesn't fix it, then your dock connector has a broken solder joint from years of wear and tear. It's common, and a very easy repair. Just resolder the connector to the board.
Dec 30, 2010 | Sirius Satellite Radio Sirius Sportster...
I tried my best. bt i couldnt connect my nokia n73 with bluetooth handsfree...plz provide me solution for this...how to connect...
in most nokia N series, you will have your handsfree device paired to your cellphone. it also depends on your handsfree model. some bluetooth handsfree models are not compatible with nokia N series. Jabra handsfree models are compatible with nokia phones. best buy.
Nov 01, 2010 | Cell Phones
My Delphi XM2GO MyFi has stopped transmitting to an FM station on a house radio. Is it repairable? If so, is there a facility in the Cleveland, OH area where I can take it?
IF you take it out of the home dock and run it on batteries, I'll bet you it works again. The newer home docks TURN OFF the FM transmitter. Try a car dock, or try it with just the power plug plugged into the bottom of the MyFi, without the home dock and see if you can now get the FM transmitter to work. Let me know. Thanks and good luck.
Aug 09, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
2630 radio problem
I think your problem is, your handsfree isnt compatible to play radio into. So you can't.
Thankyou for submitting.
=D
Dec 23, 2009 | Nokia 2630 Cellular Phone
USB Device Not Recognized Error?
1.connect the USB cable to Mother Board Back side port, not for extension or frontside port.
2. Check Your USB Cable...make sure usb cables are correct
Jun 30, 2009 | Cell Phones
Installing a nokia handsfree kit to my car
what is the make and model of the head unit - not many aftermarket radios have a mute line input
Nov 21, 2007 | JVC KD-S6060 CD Player
Car Audio & Video Logo
21 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
