Question about Kenmore 72912 / 72914 / 72919 Bottom Freezer Refrigerator
Vegies are freezing. kenmore smart reach model 596.70003003. about 10 years old. temp settings are mid range on both frig (3-4) and freezer (3-4). van't find the manual, or online, for troubleshooting
  • bllgrrsn Mar 23, 2011
    so how do i solve my problem. i checked out the manual and though they did not have my exact model #, the trouble shooting in the manuals they did have for similar model numbers did not address the problem.
  • 668 Answers
You need to check the following to make sure your fridge is working properly:
Vent blockage - Air flows between the freezer and refrigerator sections to provide proper cooling via air vents.
Condenser coil - When the condenser coil is dirty it causes the sealed system to overheat and therefore the refrigerator will not cool properly.
Defrost Cycle - When the refrigerator goes into defrost, the cooling mode stops and a defrost heater energizes to remove accumulated frost from the evaporator (cooling) coil, which causes the freezer temperature to rise slightly.
Proper Air Circulation - Refrigerators require a specific amount of clearance around the cabinet to allow for air circulation. If the refrigerator does not have the minimum clearance required, the refrigerator cannot cool properly.
Hope this helps.
Shane
Posted on Mar 24, 2011
    Genius:
  • 1,157 Answers
Hi bllgrrsn,
If you're looking for the manual of your machine you can find it here. Please click the link below for you to be forwarded to the official support site of Kenmore.
KENMORE Support site
Hope it helps.
Thank you for using FixYa.
Posted on Mar 23, 2011
Kenmore Refrig Model # 75922400 top Freezer. Freezer is freezing really good but frig is around 46 - 48 degrees at coldest setting. We discovered ice on vents in freezer and thawed them out with hair...
Sounds like a defrost failure.
Look on the back wall of the freezer from the inside.
If it is covered in ice your defrost system has failed.
Also check the fan motor in the freezer.
If it is not running it must be replaced.
Feb 24, 2011 | Kenmore 18.9 cu. ft. Top Mount...
Our 3 months old refrigrator will get so cols that freezes food products.
There are actually 2 cold controls on refrigerator-freezers. The main control is within the refrigerator cavity, the other is located in the freezer cavity. The one in the freezer is usually only a cold air deflector. It takes the cold air that is produced and divides it proportionally between the freezer and refrigerator sides. Set the control in the refrigerator to about mid-range. Set the control in the freezer to mid range. That is your starting point. If the freezer is not cold enough, adjust the freezer control. If the refrigerator s not cold enough, adjust the fridge control. After any adjustments, you MUST wait at least 24 hours for the temp to equalize before making any more adjustments. It may take a week to get it set right. This is true for all refrigerator-freezer combinations. Be patient.
Oct 09, 2010 | KitchenAid Refrigerators
Kenmore upright freezer only 3 years old running ,no clicking noise, no ice build up but won't completely freeze although set to 7 (lowest temp)
check door seals, also check vent direction, a dial or lever in fridge, it adjust how much air goes to fridge and freezer
May 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezing problem in maytag frig
the probe from the temp panel is not sensing correct temp or the panel itself is bad...call a tech to check it out
Feb 04, 2010 | Refrigerators
Items in frig freeze
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Here's a diagram of your fridge controls and parts.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5177055&diagram_id=1347585#d1347585
Oct 20, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Whirlpool Freezer doesn't freeze?
insulated or not, garages are generally too cold for new energy efficient frigs to operate. ambient temp needs to be above 60 to work efficiently.
Mar 07, 2008 | Refrigerators
Food freezing in frig
Go to the link below and the choose line 22 and click it. That link page helps identify most common problems you may have with your refrigerator, Thanks Sea Breeze.
 http://www.applianceaid.com/refrigerator.html
Sep 11, 2007 | GE Profile PSI23NCR Side by Side...
Kenmore 72912 / 72914 / 72919 Bottom Freezer Refrigerator Logo
275 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
