Carbon circle - Computers & Internet
    Brigadier General:
  • 8,909 Answers
Anything to do with "crop circles"?
Posted on Mar 23, 2011
What are the health benefits of carbonated drinks?
Carbonated water is almost as beneficial to health as plain water. When compared to regular water, sparkling water has the ability to cause dental erosion, but the negative dental effects of carbonated water are negligible. However, adding sugar or acid substances to carbonated beverages greatly increase these negative effects. Carbonated water is good for hydration, although fizzy water has less of a hydrating effect than the same volume of regular water. The taste and texture of carbonated water may lead you to drink a greater volume of sparkling water than you would have consumed had only regular water been available. Carbonation is one way to increase consumer interest in drinking water.
Feb 04, 2013 | Wine & Spirits
Mac book pro showing circle with line through it when I login in
Before doing anything else, make a backup of your entire hard drive. Use either Time Machine or cloning software - (SuperDuper or Carbon Copy Cloner).
The next thing to do is a FSCK on the hard drive. Boot your machine with the original install DVD, select the top menu item "Utilities", "Disk Utility" and do a verify and repair on the entire hard drive. Also run the repair permissions option while you're at it.
The reason for all of the above is that your hard drive might be acting up, thus it's best to find out now before data is lost. Don't forget to make a backup first!
Nov 01, 2012 | Computers & Internet
Whay my Hotpoint -Ariston Aquarius WD420 Front Load All-in-One Washer / Dryer stpos have way the circle
You say it stops half way through cycle (if I have read it right), especially when fast spin starts. Does it stop anywhere else (in wash cycle or rinse cycle)?
I would check the main filter in the sump (pipe from drum to drain pump) and ensure pump itself is not blocked which could cause the pump out time to be exceeded and thus stop the program. A faulty pressure switch could also be responsible.
I would also check the tacho on the motor and connections to main board at bottom of machine near to motor.
Disconnect machine by pulling out plug and wait 10 minutes for capacitors to discharge before doing anything, to protect yourself against residual voltages.
From a retired engineer who owns one of these machines.
Jul 28, 2012 | Hotpoint Ariston Aquarius WD420 Front Load...
My remote control bottom is not working well
Please find the link below for tips to repair the remote. Possible the carbon pad had worn out and might need to be resurfaced.
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Apr 27, 2011 | Televison & Video
What is the cheat for the trick book in MTX Mototrax
here are some tricks:
Rock Solid: down-circle-circle-circle
Extended Whip: right-down-triangle
No footed whip: right-down-triangle-triangle
Flatliner: left-up-circle
Superman one handed grab: down-down-circle
Greg's flip varial: up-down-triangle
Heelclicker lander: up-circle-square
Double heelclicker lander: up-circle-circle-square
Disco can: left-left-triangle
Corkscrew: up,down,triangle,triangle
Rodeo Air: Up-circle-circle-circle
No Footed backflip: up-down-circle-circle
Kiss of Death: up-down-down-circleBar hop-up triangle
Coffin-down triangle
can can- left or right triangle
heelclicker-up circle
double heelclicker-up circle circle
superman-down circle
superman double grab-down circle circle
superman one handed grab-down down circle
nac nac- left or right circle
whipped nac-left or rigt circle circle
shaolin-up triangle triangle
lazyboy-down triangle triangle
travis'lazyboy-down triangle triangle triangle
odeo air-up circle circle circle
backflip-up down circle
one foot backflip-up down circle triangle
no footed backflip-up down circle circle
indian air-down circle triangle
dead body-down down triangle
saran wrap- left right circle
scorpion-down left triangle
no footed can-left triangle triangle
cliffhanger-down up triangle
one footed cliffhanger-down up triangle(r2)
extended whip-right down triangle
no footed whip-right down triangle triangle
flatliner left up circle
cordova-up up triangle
disco can-left left triangle
tsunami-up up circle
one handed tsunami-up up circle (R2)
side double grab-left left circle
hart attack-down up circle
gregs flip varial-up down triangle
corkscrew-up down triangle triangle
one handed indian air-dow circle triangle(R2)
ladder-down down circle(R2)
stripper-up up triangle triangle
kiss of death-up up circle circle
helicoptor-down up circle circle
disco can indian air-left left triangle triangle
super can-left up triangle
9 o clock nac-left down circle
barel roll-up down circle right
Feb 23, 2011 | Microsoft Xbox 360 Console
The + volume button is not reponding
if all the buttons are working and only this one isn't working then there's something wrong with how it functions. does the button have a double function?
Jun 11, 2010 | Samsung TV Remote Control
Where do you put the two little springs, and what do they do? My blades have started to rattle on clipper. Oster turbo clippers.
The springs probably go with the carbon brushes, to hold them in. To find the brushes, use a dime to unscrew the two circles on the side of the clippers.
The rattling could be from loose screws on the blade hinge. My turbo clippers did the same thing. The blades rattle if the screws are even slightly loose.
Nov 12, 2008 | Oster 76076-010 Hair Trimmer
V V T i D4 toyota shivering
It may be the valves carboning up because of the octane rating of your petrol. I had a 2003 Toyota Caldina with the D4 motor that was so annoying because it kept missing at highway speed and shuddering at idle. I had it carboned cleaned twice through the valves but after that no difference changed plugs no difference talked to toyota new zealand and they said our octane rating 91-98 RON was to low it should only run on 103 Ron like in japan but we dont have it here so I sold it quick! Maybe your problem I dont know it might help.
Oct 05, 2008 | 2003 Toyota Corolla
Broken handset
The weakness with the handsets was that women using hand lotion or hair gel can get it on the front of the keypad. It then works it's way to the back side of the rubber keypad. The oil gets on the powder carbon on the keypad. The Carbon shorts the copper on the phone to activate the #1 or #2, etc. When the oil mixes with the carbon the key no longer works. I replaced many keypads until Sony Supplies ran out.... A cheap home fix would be to open the handset and clean the #1 key and the circuit board. You can try the keys but if they don't have any carbon on them you can buy liquid carbon at Electronic Stores OR just paper punch a circle of alumimum foil. Glue the foil on the key with thin glue. Works....
AL
Jan 03, 2008 | Sony SPP-A2780 Cordless Phone System
Solve my problem
you are in the right area, the motor or the motor control circuit board is the problem (assuming you have checked the drive belt) check the control board for any blown or burn marks, sometimes when motor carbons wear out they can damage the board, have you connected everything back correctly and fitted the carbon brushes right, double check you have done so, easy mistake to do keep going you are nearly there
Oct 03, 2007 | Washing Machines
Open Questions:
Cloud storage and file storage - DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jul 20, 2018 | Quantum Computers & Internet
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
