Question about Viking Freezers
I have an Eatons Viking Chest freezer 3-24308-009. The inside of the lid/door has a crack and there is a build up of ice inside the lid itself. I am currently defrosting the freezer and am waiting for all this lid-ice to melt. How do I tell if there has been damage to the insulation? Am I safe to assume that this ice, and the ice/frost that was on the inside of the freezer is a result of a leaking seal? And where do I get a replacement seal now that Eatons is long gone (though I'm sure it is a standard freezer that Eatons just put their label on)?
5 Suggested Answers
Falling Down
  • 67 Answers
SOURCE: door liner on chest freezer broke due to ice build-up
if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
Posted on Nov 30, 2007
brainyass
  • 242 Answers
SOURCE: Frost in Chest freezer
Not much you can do except ensure you have a tight seal and not to open it more than you have to.
Posted on Oct 24, 2008
SOURCE: Kenmore 12 Chest Freezer - Needs New Lid
searspartsdirect.com
All you need is the model number
It gives you a list of all parts you can buy to replace what's broken, as for the frost try placing a sheet of plastic over the insulation, under the the plastic cover to keep moisture and humidity out of the insulation.
Posted on Mar 24, 2009
  • 4793 Answers
SOURCE: we have a skandiluxe chest freezer and frost keeps
check to make sure the seal fits flat, if not use a hot cloth to shape it..
Posted on Aug 13, 2010
Ice on the inside walls of chest freezer
Check the seal around the lid sits firmly on the rim, give it a good defrost before restocking. Make sure all else is working and clean, particularly any condenser grilles / fans.
Mar 23, 2014 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Chest freezer ice is building up on the inside lid
These ideas ****. Question was, what causes ice to build up in the chest freezer.
Jul 03, 2012 | Kenmore 5 cu. ft. / 142 liter Chest...
I have a woods chest style deep freeze and the lid is very cold on the outside, but the sides are room temperature and the freezer works fine. Why is the lid cold and how can I fix it
Yes, the freezer temperature means the lid gets very cold. Every time you open it some moisture condenses in the lid and the outside ambient also affects it. The insulation may be beginning to break down and the ice is forming inside. It is not a major problem however and many freezers go on for years with freezing lids!
Apr 18, 2012 | Woods Chest Freezer C1501W3
My chest freezer has a build up of ice on the left hand side of the lid
THEN YOU HAVE AN AIR LEAK AT THAT SIDE OF THE LID....
use blocks under the unit to get it square with a spirit level.......
Sep 15, 2010 | Freezers
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Freezer builds up frost and ice too quickly.
Either the door gasket is not sealing well or the unit is low in refrigerant.
Sep 24, 2009 | Freezers
Meat is frozen but ice cream is soft
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 31, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Apr 25, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Door liner on chest freezer broke due to ice build-up
Nov 27, 2007 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
Freezers Logo
282 people viewed this question
Top Viking Freezers Experts
Gil Shultz
marlin siecinski
Dan Apthorp
Are you a Viking Freezer Expert? Answer questions, earn points and help others
