Question about Hotpoint RVM1325BW Microwave Oven
I unpacked my new hotpoint countersave plus microwave RVM1535 and there is no installation manual. how can i get on online?
    Brigadier General:
  • 8,909 Answers
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Posted on Mar 23, 2011
How can I get a copy of the manufacturer's installation instructions for a Hotpoint JX-81J over the range microwave oven?
JX-81J is the microwave recirculating charcoal filter for several models of GE and Hotpoint microwaves. The installation instructions will be available from the manufacturer with the model number of the microwave itself.
One microwave that uses this filter is the RVM1535MMSA . See http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=HPSPECPAGE&Sku=RVM1535MMSA#tab1_ for all of the details on this microwave. The owner's manual, http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=39-40541-1.pdf , shows the installation of the filter on page 34. The guide for installing the microwave above the range is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=39-40425.pdf .
If you have a different microwave, add a comment with that model number. I hope this helps.
Feb 13, 2017 | Hotpoint Microwave Ovens
What and where is the Magnetron TCO located? Where is the Magnetron located? Where can I find a sketch or drawing to work on these items
Kerry,
If your microwave is over 5-7 years old or nearing that, you might want to consider replacing it. Magnetrons can get very expensive and in some cases, some parts dealers will not sell one unless you are an authorized service tech. I am not sure exactly what you mean by the TCO, so not real sure that I can help you with that. Anytime you work on the inside of a microwave, you MUST be very careful because there are parts that create lethal voltage when running and you should only work on it if you know what you are doing. The magnetron, by the way is a square silver/gray box that will be mounted above the high-voltage transformer. That transformer usually will produce over 1000 volts of electricity when energized. Hope this helps!
Jun 25, 2015 | GE Hotpoint RVM1535 Microwave Oven
Why is my GE mircowave starting by its self ?You do not even have to in the same room and it just starts running.
The touch pad could be giong bad and closing the contact by itself. A new touch pad should fix this.
Aug 18, 2014 | GE Hotpoint RVM1535 Microwave Oven
HOTPOINT COUNTERSAVER PLUS RVM 1435 DISPLAY READS F3
"F3" on a GE / Hotpoint microwave means you have a shorted membrane keypad.
On RVM1435-series microwaves, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number (RVM1435XX###) from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays have a lock:
Nov 23, 2011 | Hotpoint RVM1435 Microwave Oven
How do I change the filter on the Hotpoint RVM1535WMCo01 microwave oven. When I took the top off I can not see a filter to replace. Does that mean that I have been running the Micro for the last year...
Microwave ovens produce dangerous emissions and require servicing by qualified technicians.
I suggest purchase a new one rather than repair because most microwave models cost as much to repair as simply buying a new one.
Nov 02, 2017 | GE Hotpoint RVM1535 Microwave Oven
Microwave runs but won't heat
hello there
here are some things to look for
If the power is on, but it does not work check to make sure the door closes and aligns properly. Microwave door switches have metal terminals on the end that make contact with the door hook or latch. This completes the circuit which allows the microwave oven to run and without this contact the microwave will not operate. A simple misalignment might be breaking the circuit causing the microwave not to operate. If you suspect that the thermal fuse has blown, call a professional appliance repair person. Even an unplugged microwave oven can kill or seriously injure someone. This is because there is a high energy capacitor inside the microwave oven case. If it is not discharged properly, you could be electrocuted.
If your microwave buzzes or hums but does not produce any heat, it could be a faulty defective diode, triode, high-voltage capacitor, or even a faulty magnetron. However, this problem usually means a bad means a bad magnetron, followed by a bad diode. Call a professional appliance repair person for assistance.
Nov 14, 2009 | GE Hotpoint RVM1535 Microwave Oven
Hi I have elcetric hotpoint oven. I did sef-cleaning and after that I am not able to unlocked the oven. What should I do?
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
You can download GE./ Hotpoint owner's manuals and installation instructions here.
Oct 10, 2009 | GE Hotpoint RVM1535 Microwave Oven
Hotpoint RVM1535DMCC OTR micro-has NO stove top draft.
Did you check the installation instructions and the owner's manual?
You can download GE owner's manuals and installation instructions
here.
If you still have a probme, I would call the GE Answer Center:
GE Answer Center®
1-800-626-2005
Monday - Friday: 8 a.m. - 10 p.m. ET
Saturday: 8 a.m. - 7 p.m. ET
Closed Sunday.
Mar 05, 2009 | GE Hotpoint Over-the-Range Microwave
Hotpoint RVM1325BW Microwave Oven Logo
157 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
