Question about Intermatic Hardware & Accessories
Need a replace knob for Intermatic Timer 885L.
885L is a UL number and not Intermatic model number.
You probably have mechanical dial-type timer with red and turquoise trippers.
Likely you have one of the consumer outdoor timers showing on following page:
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers.aspx
Dials and knobs are not available for Intermatic outdoor timers.
You can buy trippers, and some box-type models have separate clock motors
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 24, 2011
  • Anonymous Apr 21, 2011
    Researched information given in answer above is 100% accurate. Add a comment and include in-focus photo of your timer for verification and identification.http://www.fixya.com/support/r6568559-po...
  • jamcvey88
    jamcvey88 Jan 22, 2013
    I just bought the same switch online but it doesnt have the UL number engraved on back like the original one. All the other numbers are the same though. Is this a problem?
The knob on my Intermatic bathroom fan timer switch is broken and falls off every time it's touched. Is there any way to temporarily rig it to stay on until I can go purchase a new one?
Maybe there is a replacement...
-If the knob has half-moon shape when it connects to stem, then open following link, and scroll down almost to bottom of page to the section with yellow background
http://www.aplussupply.com/intermatic/timerspring.htm
They sell ivory, white, grey
-Local home center probably sells a new 30 minute spring-wound timer
-There are several brands of these spring-wound timers
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#FF
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#FD-knob
Gene
Water Heater Timers Save Money
Mar 18, 2015 | Intermatic Hardware & Accessories
How to remove a Intermatic 30 Minute Spring Wound Timer FF30MC
10-22-12
FF30 Intermatic timer: The turning knob pulls off.
(With some really old models, 1960s, there is a small set screw on the fat end of knob.)
Under the knob is a small hex nut that twists off to remove plate.
http://waterheatertimer.org/How-to-wire-switches.html#gang
Oct 22, 2012 | Spring Step Intermatic 30 Minute Spring...
I have an Intermatic 4 function Air Switch with Timer RC2343PT for my pool and spa blower switch. The timer no longer turns off at night. I have to manually turn the breaker off each night and turn it on...
You might need new trippers?
Problem is not fully clear.
Can't tell what is new, and what is not working. Add a comment.
You have a new timer with same problem as old timer.
And you have a new control box and switch.
At your new house.
You have RC2343PT air switch, likely with PB913N84 24-hour timer module with manual override knob.
http://waterheatertimer.org/images/Intermatic RC2343PT.jpg
http://waterheatertimer.org/pdf/Intermatic-PB800-PB900-timers.pdf
http://www.poolandspacontrols.com/~/media/Files/PoolAndSpaControls/Products/Instructions/RC2403RT.ashx
The RC2343PT air switch operates a pool-n-spa blower switch.
Pool and spa blower successfully turns on-and-off with circuit breaker.
Did you install a new PB913N84 timer module?
Are both ON-and-OFF trippers present? Are the 107TN222 and 107TN221 on-off trippers worn down and need replacement?
Does the timer dial rotate and keep good time?
What happens when you manually rotate the timer dial clockwise two rotations? Does the blower turn on-and-off?
Have you checked wiring terminals for signs of loose or burned connections?
Add a comment with more information for possible additional help.
Aug 30, 2011 | Solar Intermatic Rc2343pt 4 Function...
Broken press on knob for my commercial spring wound timer. Would like to replace with a metal one if possible. Renee
Intermatic makes replacement plastic knobs, but I have not run across a metal knob.
Since the plastic knob sells for $3-4, and probably is not a high volume seller, there would not be much incentive for industry to make a knock-off imitation of Intermatic knob out of more costly material like metal, let alone have a viable market outlet for that product.
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
May 06, 2011 | RTO In Wall Timer Intermatic Timer Ff2h...
Intermatic press on plastic knob is broken for my "commercial spring wound timer". Where can I find replacement with metal to take the use of multi-daily use? Renee
I have a wall-switch Intermatic Timer Model 885L that has become too stiff to turn itself off automatically. Can these be lubricated by WD-40 safely???? Or what is best fixit???
I am unable to identify Intermatic 885L
Add a comment with clear description of timer so I can identify and help.
With mechanical dial timers, once the motor begins to slow down, then motor overheats and burns out. This is true for all electric motors, and eventually all electric motors stop working.
Power pack yard-light transformers, in-wall timers and plug-in type timers are not repairable, even with WD40, because the motor has already overheated.
These timers are replaced with new timer.
However if you have a power pack, since this timers is expensive, you can buy cheap plug-in timer, set power pack to override, and then plug power pack into cheap timer.
With direct wire mechanical box-type timers that are used for parking lot lights and pool pumps, for example T100 series 120V and 240V timers, the clock motor is replaceable. These small motors cost $16 to 60 depending on clock.
Again, add a comment with clear description of timer so timer can be identified for certain.
I can also post the manual if available, and post links to sellers of similar/same timer if replacement if necessary.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
http://www.aplussupply.com/intermatic/timer.htm
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 31, 2011 | Intermatic Hardware & Accessories
HOW DO YOU REMOVE THE KNOB FROM THE 15 MINUTE INTERMATIC TIMER SWITCH SO YOU CAN REMOVE THE SWITCH PLATE.
The knob pulls off.
Use a screwdriver or fingernail file to pry up.
Some really old timers, the knob attaches with a tiny screw located on the knob.
Dec 23, 2010 | Intermatic Spring Wound Wall Switch Timer
Remove Intermatic 60 min. wall timer face plate only from wall
That knob should just pull straight off. Check to make sure there isn't a tiny set screw on the side, but otherwise you can pull it off and remove the cover plate.
Jan 23, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Hardware & Accessories Logo
555 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
