Question about Atlantek 60 I Thermal Label Printer
I am a former user of a Atlantek Labelprinter. I am now desgning a cutter mechanism for a other machine for our own internal use and do remember the clever cutter of the Atlantek label printer, which cuts the label at the end of the print process. Now my question: do you sell this cutter module itself or can you tell me where I can buy it? I was in contact with Harry Schofield at the time, Thank you an best regards, Werner Vogt Switzerland
  • 2,632 Answers
Welcome to Fixya. Can you provide the the make and the model of the cutter module that you're looking for so that we can provide you with the correct info
Thanks
Posted on Mar 23, 2011
How do I use the thread cutter?
Most of the time, you will sew a seam and then do a few stitches after pressing the Reverse button. Leave the presser foot down and press the button with the scissor icon. (That's the top-most button in the row that curves up from the needle area.) The LED will blink. If the thread cutter LED blinks when you turn on the sewing machine, press the button again. The machine will remember if the thread cutter was in use when the power went off. For some thick threads, the auto-thread cutter will not work. Instead you'll need to lift the presser foot and bring the item up to the thread cutter on the side of the sewing machine. It's towards the back of the side of the sewing machine near the needle.
You can even program in the thread cutter in memorized sewing pattern by selecting pattern 48 and pressing the M button after all the other stitches for the pattern are added to the program.
Do remember to clean the thread cutter regularly. Lint or thread buildup will interfere with the mechanism. The cleaning steps are on page 61 of the manual.
Janome has the instruction book for the Memory Craft 6300P on the product page: http://janome.com/en/machines/sewing/6300p/ . The direct link to the manual is http://janome.com/siteassets/support/manuals/professional-series/inst-book-6300peng-fr-sp.pdf .
I hope this helps.
Oct 22, 2015 | Janome MC-6300P Heavy-Duty Computerized...
The cutter on my White super lock 1934D has dropped down and won't stay in the correct position to cut. How do I fix this?
The cutter mechanism connects to the machine whet the front is closed. If you look at the machine with the door open. You will see a finger coming out of the inside of the machine. If you turn the hand wheel it should move up and down. On the cutter mechanism there is a fork that fits over the finger. When it is all closed up it sould work together to move the cutter blade up an down. Is the cutter in the up position?
Apr 29, 2015 | Sewing Machines
Is Janome L-344 sewing machine compatible with Side Cutter/Serger Attachment?
this is a low shank 5mm front load machine so yes there is a side cutter available. This will not replace having a serger by any stretch of the imagination
Jul 09, 2014 | Janome L-344 Mechanical Sewing Machine
Knife cutting knives
Remove the stichplate and snap out the plastic cover over the thread cutter (left most end of machine). This exposes the thread cutter mechanism. You should then be able to position the knife arm back into the mechanism (two pins on the cutter mechanism that insert in a hole in each actuating arm).
Apr 11, 2014 | Husqvarna Viking 1
Dymo LetraTAG LabelPrinter
Please contact us for that. You can find our contact details at dymo.com.
Feb 11, 2013 | Dymo LetraTAG Thermal Label Printer
I have a Husqvarna Topaz 30 Sewing machine that the thread cutter will not retract
A work around would be to remove the thread cutter mechanism completely. You can manually cut the top thread when spool changes are reqiired and would only have to deal with the bobbin thread when the hoop is removed. Moreover, I suspect when the cutter mechanism is removed the source of the problem will reveal itself. Depends on how skilled you are whether you tackle this yourself or take it to a sewing machine repair person. I suggest the latter.
Jan 02, 2013 | Husqvarna Sewing Machines
How to install a lock cutter on singer 8280 sewing machine?
How do i install and use my lock cutter on my singer 8280?
Jan 03, 2012 | Singer 8280 Mechanical Sewing Machine
Husqvarna embroidery diamond machine not cutting thread. Machine sounds like it is cutting thread but cutter doesn't move.
If the cutter is not moving when the cutter motor runs, there is probably a gear loose in the cutter mechanism. Take the machine to the dealer that you purchased it from, or the nearest authorized dealer. http://webservices.us.vsmgroup.com/DealerLocator.aspx?Brand=Viking
Make sure that you have your warranty card and purchase receipt. If a gear has broken, the mechanism is warrantied to the original owner for 20 years.
If you are the second owner, or the machine was purchased online instead of through an authorized dealer, an authorized dealer will give you an estimate for parts and labor and repair the problem for you.
Oct 16, 2011 | Husqvarna Designer I
My simplicity serger SW432 wont cut
There are 2 blades, a fixed cutter and a moving cutter. The moving cutter should move approx 1/8" at it's lowest point past the fixed cutter. There should also be some pressure between the cutters
Mar 18, 2009 | Simplicity Serge Pro SW432 Mechanical...
Open Questions:
See all Atlantek 60 I Thermal Label Printer Questions
Atlantek 60 I Thermal Label Printer Logo
Top Atlantek Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you an Atlantek Office Equipment and Supply Expert? Answer questions, earn points and help others
