Question about Dishwashers
My whirlpool adp-4608 will start the cycle pump water in it will sit in the bottom for a minuit then empties and the light goes off for 2 minuits and then flashes as if the cycle has finished
3 Suggested Answers
  • 1073 Answers
SOURCE: whirlpool adp 8540 - 7 flashes
replace the control board in the console
Posted on Apr 10, 2008
SOURCE: whirlpool adp 5540
try just pressing the start button down for a few seconds!
Posted on Aug 20, 2008
Duet washer does not drain all the way. clothes left in sitting water
sounds like pump not working fully.at the bottom fo machine theres a round plug.,that sounds blocked.open and unblock.alot of water will come out so get plent towels down.
Jun 04, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Weed eater run minuite hen quits let it cool a minuite then will run until it gets hot then shuts off again
you are getting a vapor lock, empty all the fuel, replace the filter and refill to the top.
Aug 04, 2014 | Husqvarna 128 LD Weedeater
Honda cb unicorn
more info, you should be able to drive right away, though you should let it warm up.
Jun 07, 2013 | Motorcycles
Water sits in bottom
If water does not drain at all then the drain pump could be blocked.
If only a little water is remaining but cycle is complete, then this is normal.
However, do check the kitchen drain is clear and you do not have a garbage disposer (insinkerator) in sink which is full. Normally empty it before you start the dishwasher.
Do you get any alarms (lights flashing etc)
Jan 03, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
I have 03 Yukon Denali XL. When I drive longer than an hour on highway all of sudden all the warnig lights comes on, goes off a minuite later after 2 seconds black out. Reapeats same problem every 3 to 5...
Sounds like possibly a faulty ignition switch, They will cause symptoms very similar to that. Another thing 2001-2003s were known for are bad instrument panel clusters (dash assembly) usually the speedo gets pegged at a certain speed and stays there.
Jan 28, 2011 | 2003 GMC Yukon Denali
The soap dispenser seems to open, but is not dissolving,which it used to, and this is a fairly new washer
plugged holes in spray arm, fill valve screen plugged how mutch water is in it 3 minuits after it starts should be min of 1 1/4 inches, there is a screen in the pump on some models that gets plugged
Dec 19, 2009 | Whirlpool DU1055XTS Built-in Dishwasher
Whirlpool dishwasher adp 4608 when switched on green light flashesand stops after 10 minutes
was it set on rinse only or lite? And, remember the prewash soak.
Jun 08, 2009 | Home
Dishwasher (Whirlpool ADP 952) not working
I have a whirlpool ADP 952 and the start button is flashing and it won't work
May 25, 2009 | Dishwashers
Whirlpool adp 5540
My dishwasher isnt working anymore after i cleaned the filters? i took out and cleaned the filters in it and now it doesnt seem to be working properly. it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. is it possible that its blocked somewhere?
It is a Whirlpool ADP 5540
thanks for your help
**** the walls are still dirty after the cycle but there is steam in there as if its done its normal cycle
May 13, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool adp 8540 - 7 flashes
Apr 10, 2008 | Dishwashers
Dishwashers Logo
119 people viewed this question
Top Dishwashers Experts
