I own a DELL W42000 HD TV when i moved everything was unplugged and i no longer have the user manual. Where can I see a diagram of which input/ output connectors go where, especially cable and HD. I am also using router and dvd etc.
    Brigadier General:
  • 8,909 Answers
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Posted on Mar 23, 2011
My neighbor gave me her tv because she has just bought a new one. I plugged it into the wall and hooked up my ps3 to it to watch netflix. I watch for about an hour or so and then i decided i wanted to move...
I tried to download the manual but had no success. The set has it's input set to the component video input. You need to change the input to the correct HDMI input. If you don't have the owners manual see if your friend does or if they can tell you how to change the input.
Sep 22, 2013 | Proview PA-37JK1A 37 in. LCD Television
I have a Sharp LC-42D62U AQUOS TV. As a result of my grandchildren pushing buttons, inputs 1 and 2 are no longer available. We have followed every proceure in the operation manual to correct the problem to...
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Jul 27, 2008 | Televison & Video
Remote control sound button wont stop when increasing volume, and input button wont move left or right, just keeps moving faster and faster
The remote might have problems,tries used the manual tv buttons on the sides of the tv,see if the problems is not accuring.If it is the remote control only,the remote CPU chip control everythings,it not repairable most of the time.Try website like Remotes.com to buy a an original remote for the replacement.
Mar 21, 2011 | LG 37LF2510 LCD TV 37 inch (94 cm) 16/9,...
I am trying to hook up my Dell inspiron 1520 to my viewsonic n2750w tv. Is there an easy way to do this?
Yes there is... You are going to need a VGA cable and an 1/8 audio cable (for sound)
http://support.dell.com/support/edocs/systems/ins1520/en/om_en/pdf/UX8623D.pdf - On page 29 it shows a picture of the right side of your computer. You will hook the VGA cable to the VGA port (Number 8 on the diagram).
The on your tv you will hook it up to the vga port as well. Page 7 of the following document shows a pictures of the back of your tv. You will hook it up to "L" on the diagram. Be careful to not bend the pins in the connector. http://www.viewsonic.com.au/support/manuals/files/LCd%20TV/N2750w%20User%20Guide%20English.pdf
Switch your tv over to the PC input by clicking the "Input" button. Then make sure your PC is sending a signal, you might have to hit the function key to switch the view.
Mar 05, 2011 | ViewSonic N2750w 27 in. HD-Ready LCD...
Have no sound for TV, everything else is fine
First check to see if you get it on all inputs (DVD, Cable, etc.). If you get no sound on all inputs, then do a hard reset by unplugging the TV from the wall overnight and plugging it back in and test again. If this does not work, then the main board needs to be replaced.
If you do not get it on all inputs, most likely it is just a loose connection. Check the connections going out of the source and into the TV for something that might have come loose. If everything is okay, test the bad input with something that you know has some on a different input on the TV. If this still does not work, replace the main board or simply do not use the bad input.
Nov 08, 2009 | Samsung LE37B550A5 37 in. HD-Ready LCD TV
Need user's manual for Mitsubishi HD-6000
Mitsubishi Parts Dept. still had stock on an owner's manual for the HD-6000. I ordered one -- although the price was quite high. (Unfortunately, Mitsubishi no longer offered this manual for free download.)
Nov 06, 2009 | Mitsubishi HD-6000 DTV Receiver / Video...
Have a philips flat screen model#30pf9975/17. need diagram of inputs on underside of tv
iam glad to be of help. please download user manual (18.3Mb)at:
http://www.p4c.philips.com/files/3/30pf9975_17/30pf9975_17_dfu_aen.pdf
in the manual you will find the diagram of inputs on underside of TV.
Oct 26, 2009 | Televison & Video
"weak signal" on my RCA scenium
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Jan 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
