Question about PSC PowerScan RF Industrial Handheld Bar Code Scanner Barcode Scanner
I want to set a motorola scanner to scan to excel and do not even know where to start
Why does my LS1203 scans only first 7 digits of bar code?
its in the settings youll need a settings barcode chart to change that
Jul 25, 2014 | Zebra Symbol LS 1203 Barcode Scanner
On the SYMBOL MC9090, when a bar code is scanned, the cursor tabs (or maybe a field exit) automatically to the next unprotected field. Is it possible to keep the cursor in the within the field being...
yes - if you are in excel you need to set the parameters on the scanner/software before hand - you can find software for this on the motorola web site
Sep 27, 2011 | Symbol MC9090-G Barcode Scanner
After scanning a bar code I need it to enter and go to next row in excel
This can be possible, therefore it is not an Excel setting. You would need
to use the software that comes with your bar-code reader to configure this.
Try looking in your bar-code reader documentation for "Append Enter" or
"Append Carriage Return"
May 21, 2011 | Symbol LS 4000i Handheld
Dear Sir/Madam, I have Motorola PDA (N-410), Windows Mobile is inside. Microsoft Office is also inside. I want to use the excell sheet, with the barcode scanner. Means if i Scan the barcode by using...
You would need an application, which can use the scanner. If there is no app preinstalled use the DataWedge provided by Symbol on their support pages.
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=10774
You can install the whole package on the desktop PC and then connect your PDA. The DataWedge will be installed automatically.
Oct 30, 2010 | Zebra Symbol Technologies MC909X-G Series...
I have third party software to initiate scanner functions on the Motorola but they do not work. In fact I cannot even scan without using the "Rapid Deployment Client" provided with the hardware.How do I...
DataWedge is an Application provided by Symbol/Motorola to enable the scanning module also for application without the driver. Scanned barcode is sent like an usual keyboard input.
There can be just one active application using the barcode scanner. If you are running DataWedge, you would need to stop it before starting any other application with built-in scanner drivers.
To stop DataWedge just click on the barcode icon in a right down corner and select - Disable DataWedge
Sep 22, 2010 | Zebra Symbol MC5590 Wireless Enterprise...
Cannot Get Symbol m2004-i290 cyclone to work with Beetle /M
When connecting to a serial port there are a couple of things that could be causing the issue. The biggest problems are usually one of these:
  1. The app does not accept serial data.
  2. The RS-232 settings of the scanner and serial application do not match.
  3. The cable issue.
  4. The data is not using the termination character the application needs.
Are you using a Symbol 25-32465-20 or CBA-R01-S07PAR cable?
If so, do you know for sure your application accepts serial data? The scanner puts the data on the COM port and the application takes it from there. A good test is to try the scanner in Hyper Terminal if you have it. It is usually listed under: Programs>Accessories>Communications.
The M2004 series scanners default to 9600 baud (or bits per second), 8 data bits, 1 stop bit, no parity and no hardware or software flow control.
When starting HyperTerminal you may have to go through a screen that asks for a phone number. Just enter something and click OK to get to the next screen (sorry I can not remember exactly what that screen looks like- once it is set you do not see it again.) Next will be the Connection Description window. You will name the session (name it anything you would like) then click OK. Next is the Connect To box. Select your COM port in the Connect Using box, the first three boxes do not matter. When you click OK a Properties window will open. Most likely you will only have to change the Bits per second to 9600 and the Flow control to None. When you click OK your session should be active. You will have a blinking cursor in the upper left corner and in the bottom left portion of the window you should see the session time counting up. You can now try to scan a barcode. If the data shows up you know the scanner and cable are both working.
If you know your application accepts serial data (Word, Notepad, Excel do not) then it may be the application needs to see a carriage return at the end of the data. The CR is added by scanning Scan Options, Data Suffix, Enter from the M2000 Series Product Reference Guide. Test the scanner. If you still do not get data scan Scan Suffix, 1,0,1,3. Again all of these barcodes are in the M2000 PRG which can be obtained here:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3969606apdf&sliceId=&dialogID=116516744&stateId=0%200%2011867900
Hopefully this information will be helpful in getting the M2004 working.
Jul 24, 2009 | Symbol M2004 Barcode Scanner
My Visioneer 8650 flatbed scanner with auto document feed gives a message when I try to scan a document, telling me to move the switch on the bottom from the "locked" to "unlocked" position. The lock is...
Actually a very common problem. Try the following:
1. Power down then re-power up the scanner.
2. Try slightly moving scanner. Sometimes a small change works to fix.
3. Change one of your scan setting to flatbed scan (not adf). Do a test scan under this setting. This will usually kick start scanner unit to unlock.
4. Last resort, by does also work...give it a medium slap on the side, sometimes unjams the scanner light.
5. Super last resort, power down over night, it almost always works the next day. (could be that lock up is heat related to scan lamp, dont know but just a guess).
Excellent scanner, so worth the effort to try these fixes.
May 22, 2009 | Office Equipment & Supplies
PSC PowerScan RF Industrial Handheld Bar Code Scanner Barcode Scanner Logo
Top PSC Computers & Internet Experts
Jax Planet
Jax Planet
Electric Dime
Electric Dime
Sardar Yasir
Sardar Yasir
Level 1 Expert
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
