Question about InFocus Proxima Pro AV 9320 Multimedia Projector
I need a remote control for a Proxima ProAv 9320.
    Brigadier General:
  • 8,909 Answers
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Posted on Mar 23, 2011
Remote control code
the price for the remote control is USD30
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Dec 18, 2013 | ASK Proxima C5 compact Lamp
Codes for srt 9320
Check these codes. If you wish to get more codes to different other brand remote controls to Philips brand TVs, check this link. 0037 0054 0556 0056 0238 0012 0721
Feb 10, 2013 | Philips Prestigo SRT 9320 20 in 1...
How do you use the RS-232 port to control the projector ?
you will need to get an RS232 compatable remote and wire it together
usually this will only control power on and off and not much more
this is usually done only in commercial set ups are you using it at home or work?
you would be best off getting a pro to install and load/ write code for you
Apr 15, 2011 | InFocus Proxima UltraLight S520 Multimedia...
Do you know where I can get a replacement remote for the Proxima Ultra Lite LX-1 projector?
The projector is kinda old but your best bet would be ebay or call projector doctor. I know from time to time they have some old remotes.
Apr 19, 2010 | InFocus Proxima UltraLight SV1 Multimedia...
I need a new female reciever for the lamp house male plug, where can i get one?
wow. good luck. the plug is part of the power supply, and parts for that model are few and far between. you could try www.avsolutionsny.com. they are a proxima service center.
Jan 07, 2010 | InFocus Proxima Pro AV 9320 Multimedia...
Our Proxima DP5800 will not turn on with remote
First check the main switch located at the rear of the unit next to the power socket.Make sure it's turned on. Next, if the projector turns on with the power button on top of the unit, then the problem is with the remote. Replace batteries to make sure fresh ALKALINE batteries are installed correctly--the batteries must SAY alkaline on them. Ordinary carbon batteries WILL NOT WORK! Check inside the battery compartment for corrosion from a leaked battery. To actually test to see if a remote is working, you will need use of a camcorder with "night shot" or night vision capability. Turn on the camcorder and set it for night vision. From a distance of at least 8-10 feet, aim the remote at the camcorder and press a button...you will see the front of the remote light up as if it were a flashlight! That is the infrared coded light the remote produces to signal the projector.If you don't see any light, the remote is bad and will have to be replaced. If you see light, the receiver on the projector is not functioning correctly and will have to be repaired.
Sep 04, 2009 | InFocus Proxima Remote Control for DP5800...
Proxima ds1 not lighting
hi
replace or clean the Air filters. Run the lamp reset command if you have.if not solved then check ballast unit which ignites the lamp.
try this also, press the poweroff button on the remote control for ten seconds, the lamp will reset to zero, if you run the projector more than 1100 hours earlier.
Viren
Jan 16, 2008 | Office Equipment & Supplies
Hi ask proxima c420
You can either search for the remote on Ebay, or if you go to proxima's homepage and click on the where to buy tab it will tell you all of the reseller's.  www.infocus.com
Dec 17, 2007 | ASK Proxima C420 Multimedia Projector
InFocus Proxima Pro AV 9320 Multimedia Projector Logo
53 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
