Question about Refrigerators
When the ice maker fills with water, it also sends water to the Water outlet in the door. It appears to lead about 1/16 or 1/8 cup each time. We've watched it several times and cannot figure out where it comes from.
  • tecountryman Mar 23, 2011
    If I use the water dispenser i get water out of only one side (water dispenser). If I switch the wires, I get a full stream out of one side (the ice maker side) and a trickle from the other side (water dispenser). Is this a wiring problem or a valve problem and what should I do?
  • tecountryman Mar 27, 2011
    Worked like a charm! Thanks for the help!!
  • 4,070 Answers
The water inlet valve on the back of the freezer where the water supply connects is made up of two valves. One for the ice maker and one for the water dispenser. Either both of yours are opening. ( you can disconnect both water lines and watch the water come out when you try the dispenser. You can swap the wires on the valves and try the dispenser again to see if water comes out both.)
OR the water is leaking between valves. If that's the case just replace the valve. If they are both opening then there is a wiring problem.
Posted on Mar 23, 2011
  • Charles T Nevin
    Charles T Nevin Mar 24, 2011
    It looks like the water inlet valve need to be replaced.
I have a whirlpool WRF736SDAM11 french door fridge. I've changed the icemaker per a repairman, but I still have no ice.
if water is dispening and you replaced the ice maker, the most probable cause is a bad water valve. The valve has two outlets, one for the water and one for the ice maker; it appears that you ice side is not working as it is not likely to be from the Ice Maker
good luck
Oct 02, 2015 | Whirlpool Refrigerators
Ice maker is not making ice.
Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
Jun 04, 2015 | Refrigerators
Ice maker is not producing ice and the control light is blinking red
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve.
Install nocold refrigerator icemaker
Jun 02, 2015 | Refrigerators
There isnt any water getting thru to the icemaker. i changed the watervalve and still no water i cannot locate the water filter even tho i removed the bottom grill, water is still getting to the water...
if you put a new water valve on the fridge then you either have a bad ice maker or the line is frozen where the water fills the ice maker,a bad water valve will make the line freeze,water keeps dripping through the valve and freezes the fill line behind the ice maker cup,you can remove the ice maker and check the fill line,if it's frozen get a hair dryer,shut down the fridge or unplug it and blow the hot air into the fill line until the ice melts,then get a piece of wire and after you reinstall the ice maker pop off the cover to the ice maker and jump it out with the wire,stick it in the t and h for 15 seconds and pull it out,if the ice maker is good it will start turning and when the arms get at like 11 oclock it should fill,also you can jump out the fill valve from the ice maker,stick it in v and L and if water fills the ice maker you know you have a bad ice maker if the fill line isn't frozen.hope this helps.next time you need help send the model number,on your machine look in the fridge section on the right hand wall up near the ceiling to find it,if it's older look down near the bottom hinge on the fridge door and you'll see a tag with the model number.good luck
Sep 12, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
This is in response to fixxa 144. The model# for the Whirlpool unit is ed2shaxmq. It is a SXS with the ice container in the door. There is no voltage between testpoints L-N I removed the ice maker and...
When you open the freezer door , the receiver should flash 2 times then pause , repeatedly . Close the flap on the left side , and the emiter should stop flashing and be off . If you open the door , and no flash , then the icemaker should be in the harvest cycle ( trying to dump ) . If not trying to dump , then the ice maker is bad . Also check the black fill tube , above the ice maker fill cup . A lot of times , it will freeze up , not letting water get to the ice maker ( sign of a bad water inlet valve ) . As far as voltages , I don't know of any techs , who check this way .
If the optics are responding this way , and the black fill tube is clear , then the problem is the ice maker .
Oct 30, 2009 | Refrigerators
My ice maker is not filling up with water preventing it from making ice. However we are recieving water from the door
Check the well in the ice maker to see if there is ice in it. If empty, with a small cup, pour water in the cavity until it is near full. With the ice maker turned on close freezer, and wait about 2 hours to see if it will harvest what you put in. If it harvests O.K..
then it is usually the dual water valve in the bottom rear of the machine, and will need to replaced.
2 exceptions. Rare but are possibilities. One. The fill tube that fills the ice maker has built ice up and will not let the water reach the ice maker. You have to remove the ice maker to inspect the tube, and if it's blocked with ice, must be defrosted but WITHOUT heat. A hair dryer or such will create havoc with the plastic parts. Two. There is a micro switch in the ice maker that can fail and fail to send info to the water valve to fill while it is going thru a harvest cycle. If it is exception One, the water valve still must be replaced as well, since it is leaking small amounts of water when the ice maker is off. If it is exception two, the ice maker must be replaced. These exceptions are rare but I've had to deal with them more than once.
Oct 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water to ice maker but there is to the water dispenser in the door. Whirlpool model ED22PQ
This could be two reasons. The water control valve that sends water to the ice maker or the ice maker is not sending the signal to the water control valve to send water to ice maker There are 2 valves on back of your refrigerator one for ice and the other is for the dispenser. If ice maker is empty then the signal should be sent to back control valve and 120 volts should open the valve for about 4 seconds. If that valve is bad nothing will happen.You can test the ice maker by filling with tap water and if it cycles until time to refill and no water fills the tray then I think the water control valves need replaced. Click on link below and enter your model number in model search feature. Let me know what you find, Sea Breeze
http://servicepartstec.blogspot.com/
Water Valve - Dual Outlet
P/N: 2188542
May 25, 2009 | Whirlpool Refrigerators
Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
Jun 23, 2008 | U-Line Icemaker
Water dispenser spontaneously erupts when making ice
I had to fix a problem like this the other day you need a inlet solenoid
Aug 29, 2007 | Frigidaire FRS26KR4A Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
