Question about Vacuums
I need a charger for my phone box - Vacuums
  • 77 Answers
You have a phone box on your vacuum cleaner?
Posted on Mar 23, 2011
I have purchased a Dyson and when setting it up noted that there should have been a charger this was not in the box please advise
If it's a rechargeable model, then a charger will be required. If you are sure that it's not in the box then you will need to return it.
Apr 18, 2017 | Dyson Vacuums
My stick vacuumed won't charge,the blue light comes on for only 10sec
You didn't give make model or serial number, so the information is going to be somewhat generalized:
Most charging systems go through what is basically a P.O.S.T.-a power on self test. This checks that the charger is working correctly, that the power coming in is correct, and that the battery needs a charge AND is ready to accept a charge-IE NOT overheated, or frozen. If any of them fail, ESPECIALLY the temperatures, IT will shut down, This is to prevent explosions! (THINK: a certain brand of phones and most hover-boards!)
What you can do: UNPLUG the charger from the vac, and the wall. Wait 24 hours. Try again. If it works, it was likely an overheated battery. If not, possibly the charger. Hard to say if it's worth repair, but that would be the place(s) to start.
Apr 03, 2017 | Vacuums
Will not charge the charging light is flashing
I'm not familure with your device but this is battery charging101. For a battery to charge the input voltage must be higher than the operating voltage of the battery. An example of this is your car. You have a 12 volt battery in your car and the alternator applies 13.4 volts or so to charge it. It is the same with any battery charger be it phone, laptop, chordless drill or small AA,AAA,C,D battery charger, that being said is the Dyson charger a seprat device? If so it can easily be tested at Batteries Plus, Any big box auto parts store, any high school electronics class. Check your owners manual it should give you the operating voltage, check that against what you discover about your charger. The charger only needs higher voltage output than the battery it doesn't have to bee a lot more. If you have further ? Email me at bret610@icloud.com good luck. Ps, you can by a reasonably accurate and easy use volt meter at W-mart for under $20. I am attacking video from u tube as to usage it's not difficult and well worth the money.
Sep 28, 2014 | Dyson Animal Bagless Cordless Hand Vacuum,...
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Black decker problem
Sounds like it could be a bad battery pack that's not accepting a charge.
Jul 14, 2014 | Vacuums
Need Charger for Shark: Charger # KA12D090015023U and Im sick and tired of looking for it. It shouldn't be this hard This shark was purchase by my mother who is 85 years old from HSN, she bought 2 one...
Call 1-800-798-7398 the person I talked to was knowledgable. The cost of the charger KA12D090015023U is $14 including shipping and takes 2 days to deliver.
Dec 27, 2009 | Vacuums
Lost battery charger AD-1215-US. Need replacement. Pls advise. Please advise how I can order a replacement
you can call this number 1-800-798-7398 and order by phone...i got it from the shark euro pro website...all they need is your model number
Oct 08, 2009 | Euro-Pro S3325 Handheld Steam Vacuum
Charger for a Bissell Spot Jifter
I had the identical problem -- a box full of combined chargers! Bissell tech support (1-800-237-7691) informed me Feb. 23, '09 that the 1715 charger/cord model number 203-2506 is 4 amps.
Feb 01, 2009 | Vacuums
Vacuums Logo
14 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
