Question about HP LaserJet P2015 Printer
What do the lites on top of HP Laserjet P2015 stand for? How would I know if I need a new cartridge? Is the first lite on top of printer?
  • 77 Answers
Like please read your manual!
Posted on Mar 23, 2011
HP LJ p2015 How do you replaced the feed roller on the 250 sheet tray? It is not in the service manual?
HP LaserJet P2015 Series Printer - Replace the pickup roller (tray 1)
  1. Unplug the power cord from the printer, and allow the printer to cool.
  2. Press the print-cartridge-door button to open the print-cartridge door.
  3. Remove the print cartridge.
    After removing the print cartridge, only handle it on the ends.
  4. Grasping the pickup-roller cover with thumb and forefinger, squeeze the left side of the pickup-roller cover to release the left retaining tab, and then slide the cover to the left and up.
    Failure to slide the cover to the left when removing it can cause the right retaining tab to break.
  5. Press the two black retaining tabs outward until the pickup roller is released from its seat.
  6. Remove the old pickup roller from the printer.
  7. Line up the black retaining tabs in the printer with the grooves in the new pickup roller, and then press the pickup roller into the pickup-roller seat until the retaining tabs click.
    Do not touch the pickup-roller pad.
  8. Grasping the pickup-roller cover with thumb and forefinger, insert the pickup-roller cover's right retaining tab into the retaining slot.
  9. Squeeze the left side of the pickup-roller cover and insert the left retaining tab in the retaining slot.
  10. Close the print-cartridge door.
  11. Plug the printer in.
Jan 29, 2014 | HP LaserJet P2015 Printer
Orange light on SIDE (not top) of HP LaserJet P2015 Series printer won't go out. Have disconnected all leads and re-booted printer and computers (2) to no avail. There are no paper jams and have
Is there any text to indicate what this light refers to?
In general, you might want to remove paper trays, and use a compressed air can to spray inside the printer, especially the paper path. Oftentimes, paper dust will impede a photo-optic sensor, and keep an indicator light lit when there i no real reason for it. It can also give you a paper jam indication when there is none.
So blow out all paper dust to get the printer to work correctly now.
Cheers!
-a.
Apr 10, 2012 | HP LaserJet P2015dn Printer
HP LaserJet P2015 will not print
Are you able to get a stand alone test page out of the printer? Hold the green button down for 5-6 seconds. It should print out a demo page. That way you can narrow it down to either a problem with the printer or a communication issue with your PC or network. Also, it would be helpful to know what the lights are doing on the printer when you try to print.
Aug 16, 2010 | HP LaserJet P2015 Printer
My HP LaserJet P2015 Printer will not print. One icon is lighted up, the broken circle.
If that's the only lite on, and it is on solid. It means the printer is ready, but no job activity. Press and hold the GO button for 5 seconds. It should print a CONFIG page. Press and release the GO button and a DEMO page will print. If both of those print, the printer is good. You might have a bad cable. Look at the CONFIG page to make sure the printer has the correct address
May 06, 2010 | HP LaserJet P2015dn Printer
We hve a hp laserjet P2015 printer. The tirangle w/the ! in the center keeps coming on. Is this a chip issue or something else. I have tried 4 different cartriges in it now. All doing the same thing Thans,...
I dont have solution,but I have similiar problem. My toner light comes on after 10-25 copies and i need to open and take out cartridge every time it does it.I have tried diferent cartridges (oem and compatible ) all with same problem
thanks Andy
Jan 08, 2010 | HP LaserJet P2015 Printer
HP P2015 Intermittent paper jam lite on solid.
Remove the covers and thoroughly clean the inside of your printer. Vacuum it out and wipe it down. Then examine the sensors and their wiring connectors. Intermittent problems are difficult at best. I suspect a thorough cleaning will eliminate it.
Nov 09, 2009 | HP LaserJet P2015 Printer
Printing or doing a test print. very lite print.allso no print
few things to consider:
1. You might be running out of ink from the cartridges. Try replacing.
2. You can clean the printer head for some clogged nozzle.
3. Check your printer settings if it was set to grayscale.
Jul 30, 2009 | HP LaserJet 4p Printer
Hp P2015 printing black pages
it is the problem laser unite
Jul 22, 2009 | HP LaserJet P2015 Printer
I could not print with hp laserjet p2015 usinh window vista
hi there,
Is the drivers of P2015 correctly installed on vista? If yes then you have to check your printer USB cable. Try to change it and see the result.
Good luck
Jun 24, 2009 | HP LaserJet P2015 Printer
Hp laserjet p2015 series
Maybe you are out of toner?
Change cartridge !
Dec 09, 2007 | HP LaserJet P2015dn Printer
HP LaserJet P2015 Printer Logo
93 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
