Question about Panasonic KX-TG4500B Phone
Hey i have a Panasonic KX-TG4500b and im having a certain issue i was wondering if you would help me out? I have 4 phone lines plugged into this unit and its set up to if the first line is occupied it will automatically roll over to the second line. My problem is when im on line 1 and i have an incoming call it cuts off the call until someone picks up the line. once the line has been picked up the first line will be restore.
Chintu-KPV
  • 202 Answers
SOURCE: panasonic kx-t7730
Hi this is normally a programmable control, operating only when the power is ON,...so try to disconnect the power and operate it
or else, reprogram it by using the manual...
http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
Try to tell me.... whether my suggestion was useful???
Bye
Have a nice day.
Posted on Feb 09, 2008
cnavarro
  • 2460 Answers
SOURCE: Can not pick up line on incoming calls from one extension only
That's what happens when you plug in the system and don't program it. You need to review ICD groups.
By default, the phone connected to the first extension is the master phone and the only phone that rings.
Carl
Posted on Sep 12, 2008
cnavarro
  • 2460 Answers
SOURCE: cant retrieve incoming calls from someone elses extension
Of course you picked the feature with conditions :-)
From the intercom 40 picks up any incoming call. 4* picks up trunk calls, and 41 plus ext number picks up a specific ringing phone.
The condition is that an extension can block call pickup by dialing 7201.. 7200 clears it.
Carl
Posted on Nov 15, 2008
cnavarro
  • 2460 Answers
SOURCE: I want to pick up incoming calls from another extension
Yours may be different if your TA-308 is not a U.S. version, but the family is generally 40 picks up all calls in your group and 4+the ringing extension will pick it up. Just in case they have call pickup deny set (721) you'd have to cancel it with 720.
Carl
Posted on Nov 18, 2008
  • 4 Answers
SOURCE: We have KX-T7730, want to stop incoming calls going to a different extension, so that the main calls just go through reception phone
try 408
Posted on Feb 26, 2009
Where can you get the A/C Adapter for this phone?
You can get another adapter from panasonic's parts website:
http://www.pasc.panasonic.com/epartr/PartslistChoice.asp
The adapter's model number is PQLV256Z.
Aug 31, 2010 | Panasonic KX-TG4500B Phone
Just plugged caller id box in to panasonic kxt7420
There is no such thing as correctly plugging an analog caller ID box into a digital phone line.
CID display comes from a TD-193 card mounted in the Key Service Unit and it only displays on Panasonic system display phones designed to work on a TD system. The only system that passes CID through to stations is a TA-824 and certain models of TDA-s that have special analog extension cards.
You can use the analog box, but you have to bring the line from in front of the system to the CID box.
Carl
Nov 11, 2009 | Panasonic KX-T7420 Corded Phone
Hi, i purchased Panasonic KX TG4500B base unit and one hand set, 3 lines connected to the base unit, i will use only the base unit, but when there is a missed call, i can't see that which line is missed...
In the window, you should see the Name, Number of Caller, and at the bottom, it should say which line number, ie. line 1, line 2, or line 3, it will not say which number the call is on. If you need the user manual, you can find it here: http://service.us.panasonic.com/OPERMANPDF/KXTG4500B.PDF
Aug 26, 2009 | Panasonic Lands Phones
Setting up voicemail for base unit and handsets
Download a pdf instruction manual from panasonic.com od pdf on internet ....
Jun 11, 2017 | Panasonic KX-TG4500B Phone
Dead handsets
i had the same problem with my KX-TGA650 and called repair out and they said it wasn't seating on the home base to charge, we'll see. i'm looking for a manual for this phone lost mine and cost prohibitive to order from panasonic. and download pdf is just too large.
go to website and it tells you that only a same model is able to be used with the base unit. hope this helps.
martha
angelml@sbcglobal.net
Jan 05, 2009 | Panasonic KX-TGA650 Cordless Expansion...
Base Unit does not work
Turns out the A/C adaptor was bad. Replaced it and all is good!!
Dec 17, 2008 | Panasonic KX-TG4500B Phone
I have a Panasonic KX-T61610 phone switching system. Some of my phone extentions are not working and some are. I have unpluged the unit and also pushed the reset and that didn't help. The extentions that...
Also, are there certain CO lines that can only work with this KX-T61610 system? Typical FXS? or any odd analog settings on CO lines or within the Key controller for the KX-T61610?
May 27, 2008 | Panasonic Lands Phones
KX-TG4500B
The only way to loose your saved numbers is to delete them or initialize the system. Removing the power, battery and hitting the reset button will not delete your settings messages or phonebook.
Go ahead and remove the battery, power and try the reset feature it just may solve your issue with this unit.
Apr 03, 2008 | Panasonic KX-TG5632 Phone
Panasonic KX-TG4500B Phone Logo
54 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
