Question about Thermador Dishwashers
Need the two screws that hold black plate below door bottom on model DW442ZP/16.
  • 55 Answers
You can purchase the parts from the link below. Type your model number in for a parts diagram.
Appliance & Refrigerator Repair
Posted on Mar 23, 2011
How to clean/pull out reservoir in bottom of fridge?
If the instructions are different than below,I will need you model number. Water Tank Assembly (some models)
1. Remove crisper drawers from fresh food compartment.
2. Remove hex screw holding water tank to rear
bulkhead.
3. On rear of cabinent remove hex screws holding water
valve cover plate.
4. Remove plate and tubing away from cabinet to expose
water valves and tubing.
5. Disconnect water tube from secondary valve coming
from water tank, remove compression nut from tubing.
6. On front of unit remove toe grill and disconnect water
coupler going to water dispenser
7. Remove compression nut from water tubing on cabinet
side of connection.
8. From rear of cabinet pull water tube out of conduit
going to dispenser.
9. From inside of fresh food compartment pull tubing up
and out of cabinet to complete removal of water tank.
10. Reverse procedure to reassemble.
To clean I would use Clorox and warm water and rinse well before replacing. Thanks, Sea Breeze
Apr 18, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
Tip
Removing The Bottom From a Black & Decker B2300 Bread Machine
Things you will need
  1. A large clear table with lots of room to work.
  2. At least 4 small dishes to keep screws organized.
  3. A few screwdrivers - 1 or 2 Phillips head, 1 or 2 straight (slotted) with long shanks are best.
  4. A straight screwdriver to be modified
  5. Utility knife or Xacto knfe
How-To open up the breadmaker
  1. Modify a straight screwdriver by taking a dremel tool with a 1/32" or 1/64" thick cut-off wheel and grind a notch in the centre of the blade as pictured below.ianchristie1.jpgThe depth of the notch is best around 1/16" deep because there are other screws in the machine that will need this screwdriver. However for our purposes here we only need it for 2 screws
  2. Proceed to remove the screws from the bottom of the machine. There are 4 Phillips/Straight screws (can use either type) and 2 of the special screws and set to the side in a dish. The screw locations are shown below: 1=Normal Screws -- 2=Special Screwsianchristie1_0.jpgThe special screws look like:ianchristie1_1.jpg
  3. Turn the machine over and disassemble the lid by opening up the lid and removing the 5 screws shown below and set aside in a dishianchristie1_2.jpg*Note be careful when removing the metal plate, the window is made of glass and can easily fall out and break, remove carefully. Also the plastic vent is just sitting in its opening and can fall out.
  4. Once you have removed the metal plate, remove the 2 screws holding the lid to the hinges and slide the lid off the hinges, put screws with the others from the lid as they are the same. Screws shown belowianchristie1_3.jpg
  5. Remove the controls and display. There are 3 screws as shown below, they are covered by little white plugs which are most easily removed with the point of a utility or Xacto knife, put the screws and plugs in a dish.ianchristie1_4.jpgThere are also 4 clips holding the panel in place, 2 pop off easily, the last two are near the display and can be awkwardianchristie1_5.jpg
  6. Now remove the 8 screws from the bottom of the "oven" walls, locations shown below and put in a dish.ianchristie1_6.jpg
  7. There are 8 clips inside the machine that hold the top to the bottom, with any luck they won't really be holding well and you can lift the top off. Start by pulling the left side up, letting the clips pop open. While lifting the top, carefully feed the control panel through the opening below it and finish taking the cover off. If the top doesn't come off easily, you may have to remove the "oven" walls by carefully prying up the top lip. If you get stuck the seal around the outside of it can be removed as well with the use of a small screwdriver or a utility knife.
There you now have the cover off and you can have fun working on the innards of the machine.
One problem area I discovered is the main drive belt. You may want to check that if the machine suddenly stops running and you think the motor is fried. The problem is the pulley on the motor shaft can slide up towards the motor causing the belt to slide off.
Reassembly
Reassembly is simply the reverse of of the above procedure.
Conclusion
I hope this guide has helped and good luck repairing your machine.
You can also find this guide at my site at ianchristie dot info
Direct link to the original article Removing The Bottom From a Black & Decker B2300 Bread Machine
on Aug 13, 2011 | Black & Decker B2300 Bread Machine
Door Ice dispencer Problem
First , remove the top freezer door hinge cover ( only held by 1 screw ) . Disconnect the plug there , to remove power to the door . Use a butter knife or flat head screw driver , and pry outward from the BOTTOM of the dispensor control plate . Disconnect the 3 plugs there and set aside . Remove the 3 or 4 screws holding the arm and cover in place , and slide out . Your problem , is probably a rusted coil and plunger , in the top right corner with 2 black wires going to it . The part # is WR62X10055 . Solenoid coil and plunger is the correct term for it . Cleaning will not work for long , only replacing will correct for a long period of time .
Apr 10, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Back door latch broke cant open back door where can i buy the part and the name of the part
I just bought the part last week for 61.76 from the dealership. It takes about two hours to unscrew the strap from the inside, remove trim from the inside starting at the top, sides and bottom. Remove the license plate from the outside of the hatch. Next remove the 8 bolts (10mm)and 3 white plastic tabs that snap on from the large black plate and move to the side (you don't need to disconnect the wires). From here you can reach around the rear window unit and open the door by moving the latch or pulling the cable. You should remove the 4 nuts that hold on the rear window assembly and move the to reach two nuts which holds the center portion of the trim piece you are trying to remove. There should be a plastic piece covering the cable and latch, it just pops off by pulling it straight out. There are three plastic tabs in the corners and one screw (lock for the hatch) that holds on the license plate assembly to the rear hatch along with two white plastic tabs which are located at the bottom two holes for license plate. These plastic tabs come in from the front. Use pliers to squeeze the together and push. You will need to disconnect the license plate lamp wire connector from the left side. The license plate assembly should drop away. Two screws hold on the latch, remove and replace and reverse proceedure.
Jul 08, 2009 | 2002 Toyota Sequoia
Passenger side rear door window not working need to know how to take door panel off.
Thier is a Metal panel behind the door panel.
Both need to be removed
Yes. If your window has fallen down and will not roll up.
99% Chance you car is suffering the Infamous VW plastic clip.
The door panel comes off With a T-10 torx or a Hex (Allen) wrench
that will fit and A large Philips Screw Driver..
Remove the Plastic cover on the inside Door handle.
And the Screw or Screw along the Bottom of the door panel.
Then remove the screws that hold the handle the the door.
They are located behind the Plastic plate you removed with a tiny screw driver earlier... Be careful not the mark up the cover whaytprying it up. It is best to pry from underneath. Where marks if made can not be seen
After the screws are out 4 I believe. The Use of a CLip tool ir best.
For getting behind the panel to pop it off. A screw driver will work.
After all the clips are released. Pull the light at the bottom of the panel down and out. Disconnect it ur push it back thought the hole it came from..
Now you need a 10mm socket, or wrench to remove the 12 bolts that hold the metal plate to the Door. Remove all the 10mm bolts, If the widow has not already fallen in the door. It should be released. By removing the Black 2" plugs. THe loosen the bolts that clamp the window the the arms. DO NOT LOOSEN THEM ALL the way, .
Disconect the all the wiring.. THe Door lock cable,can be a pain.
I think it pulls down,.
Next remove the Metal plate. that is the regulator.
reverse to install
SKETCHLAB.com
Apr 12, 2009 | 2003 Volkswagen Passat
Window mechanism broke on passat
reverse to install
SKETCHLAB.com
Apr 01, 2009 | 2002 Volkswagen Passat
Take of drivers door panel
reverse to install
SKETCHLAB.com
Mar 21, 2009 | 2002 Volkswagen Passat
Passenger front power window
reverse to install
SKETCHLAB.com
Jan 16, 2009 | 2001 Volkswagen Passat
I NEED TO REMOVE THE DOORS
Removing doors can be tricky... if you need to reinstall them.
First remove the plastic cover top door if it's an over under. Usually the screws are 5/16 there are 3 screws usually. Remove 2 screws loosen up the third. swing the bracket out of the way. Reinstall the screws you removed, this keeps interior screw plate in place and does not allow it to shift. Remove the 3rd screw , Remove the bracket reinstall the 3rd screw.
lift up and remove the door rememder washer locations.
Is there a washer on top of the middle bracket? Do not loose this or get it confussed with the bottom washer on the bottom bracket. Next there should be 2 screws on the middle braclet.
Remove one, loosen the other swing the bracket around. Install the removed screw. Remove the second screw. Remove the bracket, reinstall the screw. Lift bottom door up remove.
Now do the same to the bottom bracket. Or do not remove the bottom bracket if you don't have to. hope thisd helps.
Jun 01, 2008 | KitchenAid Refrigerators
Zanussi ZDC67550 Dryer, door swing change?
Hi
just reversed the doors in 15-20 mins. It worked for me. You do need to be a competent DIYer to do this.
If in doubt, do now't. Get in an engineer
Disconnect from mains (obviously)
Remove top using 7mm nut driver/spanner
Remove 2 cross-head screws holding the door - Door will come away from dryer.
Remove 2 cross-head screws holding the white top and bottom blanking plates
pull out the switch blanking plate
Locate the PINK wires connecting the switch/latch mechanism inside the dryer at the top. This will be taped to a blue wire.
Unscrew the 2 smaller cross-head screws holding the latch/switch assembly whilst holding the pink wire to stop the mechanism dropping inside the dryer.
Pull up the latch mechanism and unravel the black tape holding it to the blue wire.
Drop the latch assembly down the lefthand side of the dryer and refit using the 2 small cross-head screws.
Retape to the blue wier and feed the PINK wires through the plastic retainers.
Fit the white blanking plates to the RIGHT handside of the door opening.
Swap the hinges and the switch latch on the door (don't lose the spring !!!, refitting the hinge blanking plates(ease these out with a small flathead screwdriver covered witha bit of insulating tape to avoid damage.)
Fit the door using the 2 cross-head screws you have left
Refit the top.
Connect to the mains and switch on to the sound of £80 you have just saved yourself !!
Electricity kills Be careful
Oct 03, 2007 | Whirlpool GEW9250P Electric Dryer
Dishwashers Logo
79 people viewed this question
Top Thermador Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
DROPNDEAL
DROPNDEAL
Are you a Thermador Dishwasher Expert? Answer questions, earn points and help others
