My cd-rom drive works just fine My cd rom drive is drive D: however when I try to use the recover disks it restarts and tries to use drive Q. It says it is starting windows 98 then it says: SCDEX Version 2.25 Copyright microsoft blah blah blah Drive Q: = Driver TOSCD001 Unit 0 CDR101: Not reading drive Q Abort, retry, fail? Any ideas?
  • Tony Mar 23, 2011
    is the disc scratched? what happens when u hit retry?
  • Computers & ... Master
  • 27,725 Answers
You might have to physically unplug the leads for this cd drive then plug them back in this should activate the found new hardware wizard you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Mar 23, 2011
Risk of losing data by re-booting CD-ROM recovery disk
Copy off your data to another computer before recovering. A recovery usually restores to factory settings and loses all data.
You could boot to Ubuntu or Linux and copy your stuff that way, then when restored, copy it back.
Feb 11, 2016 | IBM ThinkPad Computers & Internet
Im not able to boot from os cd the bios can see rom drive and hard drive but im not able to boot iv'e tried f12 but no joy can you help?
hi there.
If you go to the bios on start up and select cd rom drive as your primary boot and then restart. Your computer will then try to boot first from the cd rom drive and second from the hard drive. If it fails to boot from the disk then this would lead me to believe that either the disk is unreadable by the drive or that the cd rom drive itself is unable to read the disk.
Jun 30, 2011 | Dell Computers & Internet
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
When i start my lap top is say's a a disk read error occurred press Ctrl+Alt+Del to restart an it keeps bringing me back to the samething?
Remove any CD-ROM disk from the CD-ROM drive.
Disconnect all USB devices.
If your computer has a 3.5" diskette-drive, remove any media from the drive.
Restart.
Your computer is trying to read from your disk-drive,
but it has not been successful, i.e., an "Input/Output Error" (I/O error) has occurred when trying to "read" from your disk-drive.
Find a qualified technician, to see if _any_ of your files can be recovered from your disk-drive.
Mar 02, 2010 | Acer Aspire 4315 Notebook
My computer will not start,
Instructions Things You'll Need:
  • A Startup Disk Or A CDROM With The Operating System On It
  1. Step 1 If your desktop computer does nothing at all when you try to start it, first check that the power cable is securely plugged in at the back of the computer as well as into a working power outlet. It's amazing how often this is the case.
  2. Step 2 If you're starting from a button on the keyboard, make sure the keyboard is connected to the computer.
  3. Step 3 If the computer is plugged into a surge protector, see if the surge protector has a reset switch that you can push. (If it doesn't have a reset switch and the problem is with the surge protector, it will need to be replaced.) Try plugging a lamp or other device into one of the surge protector's outlets to make sure it's working.
  4. Step 4 If you can hear the computer's fan or hard-disk drive, or if you can see indicator lights on the main unit but the monitor stays dark, make sure that the monitor is connected to a working power source, that it's turned on and that it's securely connected to the computer via the video cable.
  5. Step 5 If the monitor and computer have power but the computer displays a "Non-system disk or disk error" message, check to make sure you didn't leave a disk in the A: drive. If you did, eject it and restart the computer.
  6. Step 6 If the operating system still won't start even though the computer and monitor have power, try restarting with a Windows CD-ROM in the CD-ROM drive or, if you've got a Macintosh, with a Mac OSmag-glass_10x10.gif disc in the CD-ROM drive. (You can start a Mac from the CDROM drive by holding down the C key while starting up.)
  7. Step 7 If the operating system then starts, your problem is probably with the startup hard drive or with the operating system installed on it. If you can't fix the drive, you'll have to replace it. (See also How to Fix Bad Sectors on a Hard Disk and How to Recover Lost Files.)
Jan 27, 2010 | Computers & Internet
Dvd rom not working
please uninstall the driver and then unplug the dvd rom and then restart the system and then install again all things new.ok
May 15, 2009 | E-Machines emachines (emachinees) CD-ROM...
Cd rom has stopped working. the light is flashing as if it is working but the cd is not spinning.
Check the disk for scratches, and try other disks to make sure the problem is not unique to that one disk. If all disks fail, then double-click on My Computer, then double click on the CD-Rom drive and see if a CD will run. The "autorun" option may have been disabled, which is very noticeable if you've been used to this feature working. To re-enable autorun, right click on the cd-rom drive in My Computer, and go to device properties - recheck the autorun or autoplay option.
If none of the above resolve, then turn off your computer. Open up your computer with screwdriver. Unplug and replug the cd-rom driver. Restart computer. Test cd-rom drive again.
If it still fails, Make sure you are connected to the internet (I am assuming Windows XP - Vista may vary): Go to Start --> Control Panel --> Printers & Other Hardware --> System --> Hardware --> Device Manager --> DVD/CD Rom Drives - se if the drive has a yellow exclamation by it - if it does, then right click on the yellow exclamation, and click install drivers - windows will most likely find a solution
If all of the above fails, write back with more details, including model/manufatcurer of cd-rom drive, and model/manufatcurer of computer.
Jun 11, 2008 | Computers & Internet
Windows XP Unsuccessful on Start Up
no you just need to fix your bios problem, if you dont have the manual take the battery out of the motherboard that keeps power to the bios keep it out for a few minutes put it back in then turn it on it should go to bios automatically then just go to set best defaults for ststem hit y for yes then hit enter and it should take off fine if it dont then you need to take it to a pro who can reset it for you manually or reprogram it that would be cheapest for you without trashing it.
Dec 30, 2007 | Acer Aspire 3000 Notebook
Only reads some disks.
hi try taking a air can spray with a nozzle and clean the laser eye other option is to buy a more quality CD's good luck
Mar 15, 2006 | LG CRN 8245B (CRN-8245B) Internal 24x...
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
