Question about Breville BBL550XL 5-Speed Blender
Hello, I didn't see model #BBL600XL which is what
Hello, I didn't see model #BBL600XL which is what I have My question is can I order the glass container and the other question is does the container and blade assembly need to be in place for the blender to operate. Mine lights up but without the missing piece, what to make sure it works before ordering. Thank you, Sandy Hammer
  • 24 Answers
The jar has to be on for it to blend.
If you replace the jar first check the printing on your old jar. If your jar has blue print you will need a new jar and blade, Breville redesigned the jar and now the old blades don't work with the new jars. You tell the difference between the jars by the print color, old is blue, new is white.
BBL600XL/06A jar part number
BBL600XL/14A blade part number
Contact Breville at 1-866-273-8455 for service center locations.
Posted on Oct 05, 2011
I need a part for my Black & Decker Model BL2020R.
Perhaps you could find Black & Decker parts web-site for your blender model BL2020R. It will show a parts diagram for your machine. Find the part and order it online.
Dec 24, 2012 | Applica Black & Decker Blender With Glass...
Burning smell in the container and outside when in use
Seal under blade Assembly, on shaft leaks, allows liquid to enter bearing, which then fails, creates heat and overheats rubber, thus the smell. Bearing and seal must be replaced.
Jul 11, 2012 | Breville BBL600XL. 5-Speed Blender
I Need to Remove Fan from a Breville BBL600XL blender. I believe the fuse has blown -- I can get everything off but the fan... please, if anyone has done this -- how do I remove the fan so I can open it...
Hold the fan still and then turn the top and it will start to loosen the bolt you can see on the fan.
Side Note: If you need to remove the bottom completely then you also have to remove the screws hidden under the rubber feet.
Jun 05, 2011 | Breville BBL600XL. 5-Speed Blender
My breville blender model#bbl600xl leaks every time I put liquid in it, the gasket is in place and it is tightened as much as possible, what is the problem.
It leaks if you over tighten it. So try to just do it finger tight. I was having the same problem, once I eased off on the tighten if stop leaking. I assume you are getting it correctly aligned as that can be the other issue.
May 14, 2011 | Breville BBL600XL. 5-Speed Blender
I need the replacement glass bowl. My wife dropped and broke. It is the blender bowl for the Cuisinart Smart Power Duet, model FPB-5CH
Hi!!
Smart & Final carries a variety of glass bowls in plastic, glass and metal, at the cost or the S&H you would pay if ordering from dealer.
If helpful, click below.
Apr 08, 2010 | Juicelady JL600 Professional Work Top...
This damn thing leaks! Any fixes for this squishy silicone seal?
If you get desperate I have access to seals for the BBL600 (the Australian equivalent) but would need to know if the blade assembly is a screw in or lock in type.
Dec 04, 2009 | Breville BBL600XL. 5-Speed Blender
Blender will not run. the power button is lite but
There is a 10 Amp thermal fuse (SF129E) that is supposed to create an open circuit when the motor windings exceed 133 C degrees. Although this fuse should close again when the motor cools down it can become perminantly damaged. Locate the fuse by following the black leads from the coltrol board to the motor brushes. It's inside a cloth insulating sheath secured against the windings with a metal strap and two ty-raps. I bypassed the fuse with a wire instead of replacing it. It would probably just blow again sooner or later. p.s. you need a T10 Torx screw driver to disassemble (screws under rubber feet) $3 at ACE hardware.
Jul 01, 2009 | Breville BBL600XL. 5-Speed Blender
Breville 600XL not turning on
My BBL600XL stopped working because of a blown fuse. You need to remove the phillips and torx head screws out of the bottom. Then remove the base. There you will clearly see a fuse on the circuit board.
It appears to be a 10A 250V fuse.
Jan 28, 2009 | Breville BBL600XL. 5-Speed Blender
Breville BBL550XL 5-Speed Blender Logo
393 people viewed this question
Top Breville Blenders Experts
Mike
Craig Butler
Craig Butler
Joseph Hoffmann
Are you a Breville Blender Expert? Answer questions, earn points and help others
