Question about Whirlpool RBD245PDS Electric Double Oven
OVEN BLACK-OUT! This oven has stopped working. The display is blank. When you press a button in beeps, but the oven does not work. To troubleshoot the problem we disconnected power for over 15 minutes and nothing was restored on the oven. There is power to the oven and the inside lights go on and off, but the oven won't operate. Thanks, T
  • 2 more comments
  • TEIMAC Aug 03, 2008
    The oven has been off since yesterday-Saturday.
    What next?
    Thanks
    Here's the deal:
    This is a fairly NEW (Jan 2004)Whirpool double oven (electric). The light comes on in the Upper Oven, but not for the lower Oven when the door is opened. However, when using the electronic keypad for the "light", both lights come. All other keypads do not work. All you hear are "beeps" when these are "pressed".
    Circuit Breaker was checked again today. This time kept the power off for 20 minutes.
  • Anonymous Aug 20, 2008
    There is power to the oven. We pulled it out and check all the breakers. The light comes on when the door is opened, but the panel isn't lit up. My product numer RBD 305 PDQ12. The serial number is XPO703609
  • 3,037 Answers
Replacing the control panel should fix this problem. If you need information on where to find a new panel, please let me know or if you have trouble getting to it, I am here to help and can help guide you wherever needed.
good luck
Posted on Aug 04, 2008
  • Benjamin Patri
    Benjamin Patri Aug 04, 2008
    Another thing that you could check is the thermal fuse which will be inside the back panel, but since you have power, I don't believe the fuse is bad but strange things can happen
  • 796 Answers
This means the controller thinks the oven is working but the microwave generator AND motors aren't being powered. Note that these symptoms are subtly different than just having no heat and eliminates the actual components of the microwave generator from suspicion in most cases.
Posted on Aug 03, 2008
  • isaac johny
    isaac johny Aug 03, 2008
    When the timer counts down but nothing else works, 99% of the time the lower
    door switch is bad or else the door is not closing fully and the latch hooks
    are not depressing the upper and lower switches. There is also a slight
    possibility that the relay or triac on the control board is not closing but
    those usually do not result in these particular symptoms. Most of the
    microswitches used in recent production microwaves are very poor quality
    and the silicone lubrication used by some of the manufacturers migrates
    into the switch contact area and makes the switch fail even faster than
    it should.
    Sergeant:
    Champion:
  • 310 Answers
Just turn off and then turn on next day...........
  • 13,433 Answers
Read this troubleshooting page, it may provide you with a solution to the problem.
http://www.repairclinic.com/0088_13_1.asp
Have a Whirlpool Gold Accubake Double Oven. After a power outage, the display is dark and ovens are not responding to keypad. Lights work both from doors and keypad. Directions?
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Feb 20, 2017 | Whirlpool Ovens
WHIRLPOOL double wall oven has a blank control screen the start button is the only button that beeps
Their is a small in line fuse going to the oven control. Service manual
6b484ffa-e6f8-4c65-aa67-df87a903038a.pngPage 4-2 shows how to get to it. Radio shack has the fuses
Nov 24, 2013 | Ovens
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
Apr 21, 2017 | Whirlpool GBD307PD Electric Double Oven
Whirlpool Accubake System Mod.# RBD275PB10 front panel blank
Hello Edward!
May 13, 2017 | Whirlpool RBD305PD Electric Double Oven
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
No display, No beeps, No heat
I was able to fix my problem by pushing the setup button and holding for about 10 sec.No where in the manual is this described. I call Jenn air and all they could suggest is that I checked the power supply!
Jul 15, 2008 | Jenn-Air JJW8530C Expressions Collection...
Random beeps, oven almost starts itself
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
Sep 11, 2007 | GE Profile JKP18 Electric Single Oven
Whirlpool RBD245PDS Electric Double Oven Logo
447 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
