Question about Star 530TD Deep Fryer
THE ON/OFF SWITCH IS NOT WORKING WHAT IS PART NUMBER SO I CAN ORDER?
  • Star Expert
  • 684 Answers
Check the parts list at www.middleby.com
Posted on Mar 31, 2011
Phone no to call in order to buy switch
Intermatic E1020 is sold at Amazon, but there is no phone number:
http://www.amazon.com/dp/B0090Q0910/?tag=waterheaterti-20
1000bulbs also sells E1020, and they show a phone number 800-624-4488
http://1000bulbs.com/product/3296/ELEC-E1020.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 17, 2013 | Heavy Duty Hardware & Accessories
Older model Weedwacker Trimmer/Edger with flip switch on shaft that converts trimmer to edger. No serial/model number/manual. Need to order the metal guide (curved, v-shaped) that fit under shield. ...
You will probably have to find someone who has the same model or a different model but has the part that looks the same and get there model numbers. You may just need to take a good look at yours and go to Sears to see if theirs are identical. Then get the model number information and order your parts. You can order by searching Craftsman parts and going to the Sears website and entering the model number and finding the part on the illustrated parts diagram and then look to the list at the right of the screen and find that number to get your part number to order. You will be able to order or if you look at the top of the page (i think) you can call order if you prefer.
Jul 07, 2011 | Craftsman 25cc Gas Line Trimmer
Dremel 10.8V cordless model 800 (8000) The speed is stuck on the high setting (variable doesn't work now) and battery lights no longer work. I'm assuming its the switch and now needs expensive repair. Only...
You are right,it will need a slider switch replacement,But first-is it still under warranty?If it is call the costumer support on their 1-800 ...number.If not you could DIY it.Opening the drill is not that hard and as long as you observe the proper orientation and where every wire is connected to,you will be able to disassemble the unit.Inside you could see where the slider switch is connected and how it is positioned.Usually the surface of the switch is burned out and this you have to replace.The next problem is locate the part number it is usually found printed under the slider part.And the next big thing is to order the part and where to order it.Consult the user manual that came with Dremel unit and the ordering address is there.
Nov 06, 2010 | Dremel 8000 01 Cordless Rotary Tool Kit...
3 speed switch only works on full speed.
Make and model number of the fan is a good start. Ceiling fan or desk or pole or?????
Jul 28, 2010 | Hunter Ceiling Fan Control Switch
Whirlpool microwave not working. inside light's on, control panel working, hear rely click. No fan sound, beverage not heating inside. Door switch appears to be OK
It depends on the model number, but it may be as simple as a door switch or the magnetron's thermostat / thermal cutout.
See our file on door switches here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your model number).
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If you only need a switch, you can order a universal type here for $5 postpaid.
May 31, 2010 | Whirlpool Microwave Ovens
Replaced ignition switch on Saturn, won't recognize new switch.
Have you tried unhooking the negative battery cable for about 30 seconds and letting the computer reset itself.
Jul 08, 2009 | Saturn SL2 Cars & Trucks
Our dustbuster (dont' have model number with me-sorry) won't turn off when I pull back on the switch handle. I disassembled the unit and realize that the tab on the switch handle that pulls back on the...
If you can provide a model number, I can check availability of the switch and can either order it for you, or supply the B&D part number and you can order it from most local vacuum shops in your area or from Black & Decker direct online: http://www.blackanddeckerservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
May 06, 2009 | Black & Decker 15.6 Volt DustBuster Vacuum
Panasonic NN 9859 Membrane switch
Yes, you are correct. The membrane switch for this model was discontinued. The correct part number for the membrane switch is A630Y5460HAP for model NN 9859.
Mar 26, 2008 | Panasonic NN-T888S Convection/Microwave...
Kenmore vaccum cleaner
Switch number is 4369051 . You can go to sears.com, click on the parts link, put in the part number and you can order it thru them. Or put in you model number, click on dust compartment and a parts list and a picutre diagram will come up. You can order there also.
Mar 20, 2008 | Vacuums
Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Nov 19, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Star 530TD Deep Fryer Logo
61 people viewed this question
Top Star Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve
Bill Boyd
Are you a Star Kitchen Appliances - Other Expert? Answer questions, earn points and help others
