Question about HP Pavilion dv6000z Notebook
My HP pavilion dv6 1338ca shut down suddnely while powered on battery even though the battery is charged at 76%
    Genius:
  • 1,570 Answers
Hi
Is it not about the battery charge, but your computer is telling the there is problem on your computer that tends to shut down.
Posted on Mar 23, 2011
  • Benjamin Jr Singson Mar 23, 2011
    The best solution is to repair the operating system if you have the installer CD.
    Computer can shutdown because of viruses in your computer, faulty software installed or corrupted operating system or drivers in your computer.
My Pavilion g6-1b79dx notebook will not charge even with a new battery and charger. The light indicating the charger is plugged in is blinking white
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/replacement-hp-pavilion-g6-ac-adapter-19v-90w.html
Dec 09, 2012 | Plantronics Hp - Pavilion G6-1B79Dx Laptop...
I have an HP Pavilion 8113cl the problem is power. Starts just fine til window screen appears then shuts off. I can go into the bios sut as soon as it displays the machine shuts off. I've tried other
a notebook
well take out the battery , large one
run ok now/.
if bios does dead, that is POWER iSSUES.
BIOS never goes dead unless
1: POWER LOSS. (battery it does, try a new power pack )
2: OVERHEATED. clean out the dust lint yet?
3: Or far worse... (lots)
Jun 28, 2017 | HP Pavilion Computers & Internet
My hp pavilion dv6000 won't charge even with it plugged in. It also shuts down randomly. If someone could help me to figure out whats wrong with it that would be great!
http://bpr.hpordercenter.com/hbpr/ Check For Battery Recall Here
http://h10025.www1.hp.com/ewfrf/wc/weInput?lc=en&dlc=en&cc=ca&product=3224052&lang=en Check For Warranty Here.
In general terms, if the battery does not charge, it may be required to be replaced. A typical battery will last longer if a series of charge and fully discharge cycles occur. It is not good for the battery to constantly run on AC power.
You can check the above URL's to see about your warranty status and for the Battery if under recall, you will need the product number and the serial number from the laptop.
As far as the laptop shutting down, this may be an overheating problem. The fan may be clogged with dust and debris imparing the flow of air into the laptop, make sure the laptop has good ventilation when operating.
I hope this helps, Pre...
Jan 14, 2011 | HP Pavilion dv6000z Notebook
Hp pavilion dv-7-1245dx --keep shutting down after a few seconds
If the computer's battery is bad it won't stay on. If the fan is plugged up and over heats quickly, then the computer will shut itself down. I would start with those. Wouldn't be bad to check that your memory chips are in securely as well.
Jan 06, 2011 | HP Pavilion dv6000z Notebook
Earlier my laptop shut down with no warning even though the charger was all connected and plugged in. now even though the charger is plugged in everytime i try to turn it back on the needs to be charged...
This could be caused by several things, but try the obvious first. I just bought a brand new power supply, and in less than a week the customer called and said it stopped working. I suggested she take the cord from the old charger and try it - it worked - the brand new cord lasted less than a week. The other thing that could cause this is a bad connection on the end of the power supply, going into the computer. It could even be a bad power supply.The last thing I can think of is a bad battery that won't hold a charge.
Aug 12, 2010 | HP Pavilion dv4000 Notebook
HP Pavilion DV2700T PC Notebook - won't reboot.
go into bios next time it starts and turn off all power settings, same in control panel in windows and turn off sleepmode and hibernate.
Dec 01, 2009 | HP Pavilion DV2700T PC Notebook
Laptop starts to turn on but then shuts down, then repeats over
do the hdd and ram reseat and update the bios from hp.com.I am sure it'll fix the issue or else run the hdd test from f10 bios
Sep 29, 2009 | HP Pavilion dv6000z Notebook
Battery not charging
Your Battery is Done.
Get a New One!
(it might be cheap or free if you are still under warranty.....so check up on that, but I'm not sure)
But your battery is dead, It has seen better days.
Apr 21, 2009 | HP Pavilion dv6000z Notebook
HP Pavillion ze2000 loses power
I had a laptop just like that and it ended up being that the cpu fan and heatsink was coated with dust. do you have pets or dusty house?
Dec 18, 2008 | HP Pavilion ze2000 Notebook
HP Pavilion dv6000z Notebook Logo
97 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
