I have an HP Officejet pro 8500 how do you correct carriage jams on these models?
  • Tommy Smith Mar 23, 2011
    HP Office jet states that their is a carraige jam how do you fix it
  • 823 Answers
Hello!
The first thing to do to correct a carriage jam is to unplug the printer from the power source and the pc too.
Press and hold the power button for 30 seconds to release power stored.
Open the top cover to view the cartridges & current position of the carriage. Remove the ink catridges and set them a side.
Remove anything that you view which should not be inside the printer.
Grab the carriage and slowly move it to the right and left. If it does not move freely on its own, then stop and take your printer to a repairman.
move the carriage all the way to the right and then left to make sure that it has full motion.
Replace the cartridges, close the cover, connect it to the power and pc again and then turn on the printer and try a test page.
This should solve your problem.
Posted on Mar 23, 2011
  • 2,574 Answers
Solution one: Turn the All-in-One off and on again 1. Press the Power button to turn off the product. If the product does notturn off, continue to the next solution. 2. Wait 60 seconds. 3. Press the Power button ( ) to turn on the product. *** If these steps resolved the issue , you do not need to continuetroubleshooting. If not, Continue to the next solution. Solution two: Clear any paper jam 1. Remove any loose paper 2. Clear the jam from the back of the All-in-One 3. Clear the paper jam from paper tray 1 4. Clear the paper jam from paper tray 2 5. Open the top cover and clear the jam *** If these steps resolved the issue , you do not need to continuetroubleshooting. If not, Continue to the next solution. Solution three: Make sure that the carriage moves freely 1. With the product turned on, open the cartridge access door. The carriagemight try to move into the access area. If so, allow it to move to thatposition. 2. Without turning off the product, disconnect the power cord from the productand the electrical outlet. 3. Look in through either the cartridge access door or the output paper trayto make sure that the cartridges are secure in the carriage and not loose.Also, make sure that there are no obstructions under or around the carriage toblock it from moving. 4. Make sure the carriage can move freely across the width of the product bygently pushing the carriage to the left, and then to the right. Clear anyobstructions found. 5. Close the cartridge access door, and then reconnect the power cord to theproduct and the electrical outlet. 6. Press the Power button to turn on the product. *** If these steps resolved the issue , you do not need to continuetroubleshooting. If not, Continue to the next solution. Solution four: Plug the product directly into a wall outlet 1. Plug the product directly into a wall outlet to make sure the powersource is functioning correctly. *** If these steps resolved the issue , you do not need to continuetroubleshooting. If not, Continue to the next solution. Solution five: Service the product 1. If you have completed all the steps listed above and are stillexperiencing a problem, service the product.
  • Reparatii PC - Service IT
    Try to reset your printer to clear the error.
    here's how:
    Unplug the power cord from the back of your HP 8500 All-in-One wireless printer.Count or use a timer to wait 20 seconds.Press and hold "#" and "3" on the printer's number panel at the same time while you plug the power cord back into the back of your printer.Stop pressing the "#" and "3" keys once the HP 8500 wireless printer starts.
HP Pro 8500 my carriage cradle jams on the right side - it is like the ink cartridges are protruding - but i can move it manually
If you have removed/renewed, make sure that they click in place, they don't always sit right first time, like with female's gentle but firm pressure. Remove and reinstall feeling for a gentle click?
Feb 22, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I can't figure out where the carriage jam is...help
Are we talking a paper jam originally?
Switch Off.
Access carriage area, gently but firmly hold printer carriage and firmly pull to the left about halfway.
With a CSI Torch, check area for an inkie covered piece paper. If that's the problem?
Jan 24, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Error message - carriage jam
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
Sep 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I do not know how to open the printer carriage access door to clear a paper jam
You can find detailed instructions on clearing paper jams, including carriage jams, here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01618201&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3752462
Oct 29, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro 8500 has a paper jam. Can't get
Hi! I will be glad to assist you in this issue, here is the link that will fix the issue:
Paper Jam' Message Displays on the All-in-One
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01617494&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
Carriage Jam' Message Displays on the Control Panel Display
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01618201&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
Oct 11, 2009 | HP Office Equipment & Supplies
k24674
jasbo
jasbo
Marvin
Marvin
