Question about Maytag Dishwasher
My dishwasher is making a terrible screeching sound when the pump is running. My hustand is willing to 'have a look' but isn't sure how to proceed to take things somewhat apart. Any suggestiongs? Model WU300, serial #124703EE
  • 77 Answers
Sounds like your coupler is going bad and you have dragging brake shoes (this is the squealing, not a pump), potentially a serious problem to get fixed soon. Not a "hustand" job. Get a pro.
Posted on Mar 23, 2011
My dishwasher is making these horrible screeching sounds during the wash cycle !! It's a stainless steel fridgdaire dishwasher about 5 yrs old
Open up the door, try spinning the cross fan to see if you can replicate the sounds if it does, check the fastener to see if it's either too loose or too tight, either of which can create such sounds.
Mar 17, 2013 | Dishwashers
Screeching sound remains
Your AC pump is starting to faiL. It's starting to bind and putting heavy back pressure on the belt causing it slip and screech. After the car cools off inside, the load on the AC compressor is lower and the sound will die down. Also when the belt gets hot it gets a little more flexible and grippy which also lowers sound.
Take it to an auto AC repair place and have it checked.
Mar 15, 2017 | BMW 320D Cars & Trucks
Will only run if i push in the top control panel then stops until i push again kudp01lwh6
Sounds like the door switch isn't being activated all the time. Make sure nothing is binding the racks which could be pressing against the door when closed. Also you can try bending the door latch a little to see if it holds better. Also make sure the dishwasher isn't installed too tightly in its place. You may need to lower the leveling legs a bit. May need to replace the door latch if those don't help.
Oct 19, 2011 | KitchenAid Dishwashers
I have a Frigidaire Gallery dishwasher with model # GLDB958JB0 and it started to make a screeching noise only after a few mins into the wash cycle. I took out the filter and made sure there was noting...
Hello & Welcome to FixYa
The problem is with the impeller or the chopper assembly that is causing this screeching noise. You can take apart the bottom front access panel and clean the drain pump assembly completely and check for any broken parts inside that need replacement. If the problem returns then replacing the impeller/drain pump-motor assembly is recommended repair. Please get back to me if you have any other questions.
Kevin
May 12, 2011 | Frigidaire Dishwashers
Prius screeching noise before starting
Probably your fuel pump, have it looked at by a mechanic.
Jul 22, 2009 | 2001 Toyota Prius
Paper isn't catching on the roller - terrible sounds
make sure the paper is not wet and not damp. possible buy a new paper
Jul 14, 2009 | HP PSC 1610 All-In-One InkJet Printer
Dryer makes screeching noise runs for awhile then shuts off.
The 1,5 year new dryer makes a terrible screaching noise when it has a load of clothes in it. It still dries fine, no problem with the heating element. No noise without clothes, only when it has a load.
Nov 23, 2008 | Dryers
Dishwasher loud in beginning cycle and drains early
sounds like you have 2 problems however generally speaking (most makes) of dishwashers go into drain mode when there is a fault elsewhere, however is this set up properly, is the waste pipe end high enough to allow the water to actually fill up (only about 30cms of water aprox)so it doesn't flow straight though to the waste. the noise could just be an empty pump, it runs dry after a while, and makes a screeching noise eventually? check installation pictures to see if its set up right, you may have also a leak somewhere check all other connections and pipes
Sep 21, 2007 | Maytag MDB7100AWB Dishwasher
Maytag Dishwasher Logo
675 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
