Question about Samsung G3 Station Desktop External Drive HX-DU010EC/BW2 2 TB Hard Drive
Hi, My new Samsung G3 Station 2.0 TB External hard drive has problems waking up when it goes to sleep mode. More often than not I have to unplug and plug the usb or the mains to be able to use it. Any help would be most appriceted
    New Friend:
I have the same problem it seems not to work on 64 bit
Posted on Jan 08, 2014
2 Suggested Answers
SOURCE: Setup: Win 7 64-bit i7
Once the device is plugged in, Please go to device manager and look for the instance of the Samsung harddisk drive. Right click on it and see if you have a Power Management tab available. Under Power Management, untick all the options there and reboot the computer. Check if it would still goes off during the routine backup.
Post you observances here. Please keep me updated.
Posted on Sep 18, 2011
Windows 7 64 bit usb
Control Panel, Computer Management, Disk Management. Check that your Samsung disk is present. If it is present, does it have a drive letter assigned? If not Right Click and Assign Drive Letter.
If drive not present you should check power and data connections.
Jan 08, 2014 | Samsung G3 Station Desktop External Drive...
Permissions read
Select the disk. folder, or file and choose File>Get Info. In the Get Info window, choose sharing and permissions pane to change.
Sep 15, 2013 | Samsung G3 Station Desktop External Drive...
I bought a new Sumsung G3 station 1.5tb external drive, it wont show up in my computer nor disk management. am using windows 7 64bit
Try Using the Samsung 64 bit driver update tool
http://driverwhiz.com/drivers-en?brand=Samsung%2064%20Bit&logo=Samsung&subid=1001-us-en-10000202160&gclid=COzGnv-mi6sCFSE95Qodyh2bvw
Jul 26, 2011 | Samsung G3 Station 1.5TB USB 2.0 External...
I have connected my g3 station I use firefox and no icons have appeared so i dont know how to access the station,let alone use it.
Go to Start------>My Computer. You should see the Drive there or else your hard-drive is not showing up and there is a problem with it but try it first.
Please don't forget to rate my solution, thanks.
Apr 30, 2011 | Samsung G3 Station 2TB USB 2.0 External...
We have been using a 2 TB Samsung G3 Station External Hard Drive to connect to the TV through a laptop. One day it was working next day no power seems to be going through it. The light doesn't come on...
Assuming you don't hear any activity it might be the power supply that has died. Check if it's under any warrant.. if not you can always rescue the hard drive by taking it out of the enclosure and plugging it into your PC. Odds are it's a SATA drive. Either way.. taking it out of the enclosure will rule out of it's the hard drive or the components. Good luck.
Mar 19, 2011 | Samsung G3 Station Desktop External Drive...
When i put my samsung g3 station 2 TB on my pc, my pc will not boot.. When i look it up in de BIOS the C:\ is not available.. that why it cant boot.. it does not see the normal HDD. how can i solf this...
My desktop has a 6 year-old motherboard which will not start up if the external USB HDD is turned on. So I have to make sure the HDD is off before turning on the PC in the morning. After it starts booting I can turn on the HDD and everything works fine.
Does your machine work this way?
Mar 12, 2011 | Samsung G3 Station 1.5TB USB 2.0 External...
My 2TB g3 station doesnt wanna work on my mac os x 10.4.11, it says it cannot be modified.
You problem is most likely because the hard disk is formatted using NTFS which can be read on MAC OS but does not allow writing data on it. Solution is to backup your data somewhere and give it a clean format.
Click on the spotlight icon (the magnifying glass) in the upper right corner of your screen, and typing "disk utility."
Once in disk utility, select your external drive in the list on the left of the Disk Utility window, and click "erase". Select FAT32 as your file format, name the volume, and click the "erase" option.
REMEMBER TO BACKUP YOUR DATA as everything will be wiped out during a format!
Mar 03, 2011 | Samsung G3 Station Desktop External Drive...
Is it possible to repair Samsung G3 Station if the USB connector inside the box has been broken?
The adapter board is a common fault, I have had about 20 of these cases in the last year, and It has made me hate external hard drives. My advice, take the hard drive out, its easy enough, remove the top two rubber feet, take out the screws, pry the top open, gently lift out and take the screw out of the adapter board. Now get an external reader. I've just got a cheapo for $50 and it works great for me (http://www.chinavasion.com/product_info.php/pName/premium-dual-sata-hard-drive-docking-station/) but if you want to pay more for something more reliable, I can't blame you. Keep the area reasonably dust free and hard drives you're not using in zip lock bags and you shall have much less drama, trust me.
Feb 22, 2011 | Samsung G3 Station Desktop External Drive...
Hi there. Everyday I have been using my external hard drive. The front lights up when power is on. Today when I turned it on, the fron just flashed and I could not get it working. Just wondering if...
Hi ,
I'm afraid your drive is damaged .
The best way I can think to recover your data is to extract the HDD from it's box ( box will be lost ) and connect the drive directly inside your desktop .
You could also try a recovery tool , from here for instance
http://www.geckoandfly.com/3163/crashed-hard-drive-hard-disk-data-recovery-software-tools-and-service/
Best regards
Jan 29, 2011 | Samsung G3 Station Desktop External Drive...
Samsung G3 Station Desktop External Drive HX-DU010EC/BW2 2 TB Hard Drive Logo
656 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
