Question about Home
I can,t get the cover off to change bulb - Home
    Problem Solver:
  • 7 Answers
Try a screwdriver and a hammer.
Posted on Mar 24, 2011
How to change bulb
You can change the bulb from under the bonnet there should be a black rubber cover on the back of the light were the wires connect to the light bulb unplug light pull rubber cover remove metal clip then change bulb.
Aug 17, 2014 | BMW 318 Cars & Trucks
How to change the inside bulb in a ge spacemaker microwave that has a top vent fan
My Spacesaver bulb replaces from the top. You have to remove 2 screws that hold the upper vent cover. W/ cover off you will find a phillips head screw about the center that holds the bulb cover. Remove the cover screw & lift up & remove the cover, then replace the bulb, the cover & screw then put the vent cover & it's 2 screws back. There may be some variance but they are all similar.
Mar 16, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
How to change headlight bulbs
You don't take the lens cover off to change bulbs...the bulb holders are at the rear of the headlight unit.
May 24, 2012 | 1993 Honda GL 1500 Aspencade Gold Wing
How to change bulb in fridge
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb, you can buy a new bulb at any home improvement center. Insert the new light bulb and replace the cover. If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair center that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
Jul 04, 2011 | Whirlpool Refrigerators
HOW TO CHANGE THE LIGHT BULB IN THE REFRIGERTOR
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb you can buy a new bulb at any home improvement centre. Insert the new light bulb and replace the cover.
If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair centre that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
Check this link if it helps:-
http://www.ehow.com/how_4856659_change-light-bulb-whirlpool-refrigerator.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Oct 01, 2010 | Whirlpool GB2SHKXL Bottom Freezer...
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
Step 4
Unscrew the old light bulb.
Step 5
Screw in the new light bulb.
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
How do I change the bulb in an Inglis oven. Can't
Normally the cover will have an anticlockwise turn thread. Twist the glass cover anti clockwise and it should unscrew.
Jan 04, 2010 | Ovens
Replace front headlight
Headlights Removal & Installation WARNING
Halogen bulbs contain a gas under pressure. Handling a bulb improperly could cause it to shatter into flying glass fragments.
To help avoid personal injury:
  • Turn off the headlamp switch and allow the bulb to cool before changing bulbs. Leave the headlamp switch off until the bulb change is complete.
  • Always wear eye protection when changing a halogen bulb.
  • Handle the bulb only by its base. Avoid touching the glass.
  • Do not drop or scratch the bulb. Keep moisture away.
  • Place the used bulb in the new bulb's carton and dispose of it properly. Keep halogen bulbs out of the reach of children
To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • LH and RH engine under covers
    • RH and LH Front fender liners
    • Front bumper cover
  3. 2 bolts and disconnect the connectors
  4. Headlight assembly by pulling it forward
  5. To Install:
    1. Install or connect the following:
      • Headlamp assembly
      • 2 bolts and connector
      • LH and RH front fender liners
Jul 25, 2009 | 1998 Toyota Camry
Change light bulb
ok just like you would change the belt take screws out of top the cover should come off inside there is a plastic cover take it off theres the bulb
Jun 29, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Home Logo
23 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
