Question about Dishwashers
Water is overfilling and cutting out. Checked filter, blockage and for leaks but no joy. Please help???
  • 55 Answers
The most common issue on these units is the float switch. This is the switch in the front corner, often it gets hung up causing this issue.
Appliance & Refrigerator Repair
Posted on Mar 23, 2011
Ge monogram refridgerator water on floor
Is the water filter located behind the grille under the doors?. I had the same problem and found the O ring on the filter cartridge was leaking.
Dec 17, 2015 | GE Refrigerators
I have a Jenn-air JFC2089HPR Refrigerator. The other day it started leaking water out the bottom somewhere. I turned off the water to the fridge and the leaking stopped. When I checked, all the external...
Sounds like cooling coils inside ref. that cools the water before the dispenser in the door.
These coils are in the back bottom of ref, behind crispers. They may be leaking.
Here is some more help.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
Sep 24, 2011 | Jenn-Air JFC2089HE French Door...
P1131
Fuel/air ratio is correcting rich for an overly lean condition.
Possible Causes:
Fuel System---Exessive fuel presser, Leaking fuel injector(s), Leaking pressure regulator, Low fuel pressure or Contaminated injector(s).
Induction System--Air leaks after the MAF, Vacuum leaks, Restricted air inlet, PVC system, Fuel purge system or Improperly seated dip stick.
EGR--Leaking gasket, Stuck open EGR valve or Leaking diaphragm.
Base Engine--Oil overfill, Cam timing, Cylinder compression, Exhaust leaksbefore or near the HO2Ss.
CHECK AIR FILTER, AIR FILTER HOUSING FOR BLOCKAGE.
VERIFY INTEGRITY OF THE PCV SYSTEM.
CHECK FOR VACUUM LEAKS.
HOPE THIS HELPS YOU ??
Jul 06, 2011 | 1996 Ford Escort 4 Door
Hi my Ariston Margherita LBE12X washing machine is not filling and just making a humming noise. we have checked the pipes and they are not leaking or kinked. Pls can you help?
Have you checked the filter and drain pump for any blockages.If the pump cannot operate properly then it will not let more water into the machine.Also check the filters tn the ends of the hoses are not blocked.
Hope this helps.
Aug 28, 2010 | Washing Machines
Overfilling fault
I believe the washer has had a flood type situation.there is normally a flood switch in the very bottom of the dishwasher right at the very floor,if water get into the bottom tray it floats a piece polystyrene foam wich triggers a little micro switch wich will run the pump continually & show Overfilling fault at the same time..The water in the tray needs to be mopped out with a rag or spunge so that the styrene foam can drop back down.The blockage you had may have caused this flood situation some how.The overfill fault was probably due to the washer not pumping out,So that may be ok now that you have cleared the blockage.hope this helped.
May 13, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
No problem with wash and spin cycles but will not drain water after wash. Makes a ckicking noise when it should drain away
It sounds very much like there is a blockage in the drain pump,when was the last time you checked the filter.It may be spinning ok but if the filter is blocked it may not be spinning fully or draining properly.There is also a good chance that the sump pipe and drain pipes are choked with sludge /limescale.Try the filter check first if no Joy then it will need investigating down by the pump.
Hope this is of some help.
Good Luck.
May 04, 2010 | Zanussi FJS1225W Front Load Washer
E20 fault display
E20 is a fault either in the filter/pump or drain.
The water must be drained thru. the little hose by filter or get machine to back door and undo filter plug and drain onto back step its quicker.With filter out see if any blockages,shine torch up in filter hole turn to spin/drain and see if pump blade spins if not then get long screwdriver and turn blade to free if no joy pump has to come out to free,hopefully this will work and refit plug and check for leaks.Then try again.
Good luck.
Apr 19, 2010 | Zanussi ZWF1420W Front Load Washer
Hi my ariston a1636 doesnt seem to pump water out it is now full to the brim and wont open the last two or three washes water came seeping out the draw is there a blockage in my pump
Could be but think more of an overfill fault cased by a blockage @ the pressure switch this controls the level of water in the drum shutting off fill valves. The pressure switch or air switch operates at 3 psi it is round with wiring onto it and has a tube connected to it ....make sure the Tube and chamber tat feeds this is clear as this is common to fail the valve and result in overfill,Apart from a faulty fill valve of course, this should cut off when power is removed.....good luck
Apr 15, 2010 | Ariston Technologies AWD121WH
While washing water is leaking out of the soap drawer out of our 1st Addition Washer/Dryer Please help
Probably a soap blockage in dispenser, or washer is overfilling, or the drum is turning too fast on wash.
Check the dispenser to make sure it is clear of powder.
The drum should turn fairly slowly, or other wise it will throw water up to the diepemser if it is turning too fast.
Jan 11, 2010 | Hotpoint Washing Machines
Leaking machine
Could be caused by several reasons.
1- Overfilling, check water level .
2-Blockage in dispenser, or dispenser inlet hose to drum
3-Drawer not in properly.
4-M/c not draining properly, thus when it goes into spin, water could be thrown up by centrifugal force, and come out of the front of the drawer.Check filter.
5-Water pressure very high, forcing water out of drawer, adjust pressure.
Plz rate my soution.
Thanks.
Dec 30, 2008 | Hotpoint WMA64 Front Load Washer
Dishwashers Logo
Top Dishwashers Experts
Marvin
Marvin
