Question about Welding Tools
Showing low air will not arc yellow light flashing hypertherm powermax 1250
2 Suggested Answers
  • 3 Answers
SOURCE: I HAVE A HYPERTHERM POWERMAX 1250, AND IN THE
Air pressure is probably falling off. This can be caused by several things. The compressor that is too small to keep up is usually no.1. the 1250 is a large unit amd requires a sizeable air source. A way to test would be to connect a compressed air bottle from a welders supply.
Posted on Jul 25, 2009
Fix the yellow flashing light on a numatic hoover ref hqz 250-2
What is wrong with the yellow flashing light? This is a bag full / low air flow indicator. If your bag is not full then you most likely have a blockage in the hose, wand or tool.
Feb 13, 2015 | Numatic Vacuums
Tip
Prone to arc eyes from welding?
If you have a conventional flip lens welding helmet and are prone to getting arc eyes from "peeping" though a gap to strike your arc, try this.<br /> Replace the inside fixed clear lens in your helmet with a yellow perspex lens. The world will appear strange at first through the yellow lens, but the yellow cuts out the ultra violet rays that cause arc eyes. The yellow lens should not be considered a replacement for the dark glass, it is only to shield you from that inadvertant flash when making your strike.
on Jan 19, 2011 | Welding Tools
Powermax 1250 low air flow
check the blower, it may need to be replaced, or you may need to replace the blower vacuum switch. you can jump the blower vac switch to test if it is the problem. if so, make sure all air lines going from the switch to the blower to ensure no cracks in the rubber tubing.
Apr 10, 2014 | Pentair Power Max Commercial Pool Heater...
I have Hypertherm Powermax 600 and the green OK light does not come on at times. I will let it set over night and it may come on or maybe not. Driving me NUTS!!! Please can you help. Thanks
you might have a bad relay on your circuit board. They arc and spot weld themselves at times (nothing a sharp hit can't fix) Replace the relay with a higher quality one if you can.
Oct 30, 2013 | Welding Tools
My Hobart 250 airforce doesn't start
On the main circuit board for the power supply, there is usually a thermal fuse installed, its a sealed unit and is not servicible, look for a black epoxied case,approx 3/8x3/4 long, with 2 leads coming out of it. Inside is a set of bi-metal contact points which serves as an over voltage/over current protection. These contacts deform/corode over time and it sounds like there not contacting properly. As soon as you try to load the machine, the current passing through this high resistance heats these contacts up, and shuts off power to the unit. I am not familiar with the guts of a hypertherm, but have extensive experiance repairing inverter based plasma cutting equipment, and i have encountered this before. I assume hypertherm must have some equivelent to this thermal switch inside the power supply.....Good luck..
Dec 29, 2009 | Miller Hobart AirForce 250A Plasma Cutter ...
Red arc comes on when gun signal starts checked cinsumables many times put on new parts, hypertherm 1650 plasma brand new
have you tried to tighten the end where the arc comes out thats what i do and that fixes mine
Jun 27, 2009 | Welding Tools
I HAVE A HYPERTHERM POWERMAX 1250, AND IN THE MIDDLE OF THE CUT, IT WILL SHUT OFF, WHAT IS CAUSING MY TORCH TO SHUT OFF DURING A CUT.
Jun 15, 2009 | Welding Tools
Hypertherm plasma cutter making weird air sound from inside unit
Open the cover (only after a day of not being plugged in).
Check the airline that comes in through the back of the case.
The air line has either fallen off or has a hole in it.
If you are a technician and don't mind working with thousands of volts of electricity that is inside the case, then and only then can you plug it in. Safety First. Rember the voltages inside this unit are lethal. It will not give you a second chance.
If you feel you are qualified, then plug it in and start it up, use it as normal, while at first watching from a 2 meter distance, you may immediately see and/or hear where the noise is comming from.
DO NOT under any circumstances put your hand or hands inside the box while it is live.
Try running a WOODEN stick (at least a foot long) along the length of the airline inside the case and around the valve as it enters the case. The sound should change in pitch when you find it.
If you think you have found it, DO NOT touch anything inside, until you have both DSCONNECTED THE UNIT from the power source and WAIT ONE DAY before putting hands inside the unit. Any storred or residual energy will have discharged by this time, making it safe to work on. Safety first. The voltages inside are lethal. This aplies to all Plasma Cutters. Good luck.
May 10, 2009 | Welding Tools
Safety light flases on a lincoln pro-cut 80 and mashine wont work
sounds like the torch tip is not tight.with a hypertherm you have to turn of the machine to reset .
Nov 26, 2008 | Lincoln Pro Cut 55
Welding Tools Logo
70 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
