Question about APC Smart-UPS 1000VA UPS System
Hi, i have APC Smart 1000 SUA1000l, suddenly its stop working. i power on and when ever i switch on monitor my USP trips, even its connected to direct power. another question, can you tell me what is the specification of relay in Smart 1000 ups? Thanks in advance
SOURCE: APC Smart-UPS 1000VA shut down and now will not power on. How do I troubleshoot?
my apc smart ups sc 1000 do not switch on. when i need to chage no any light open in normal its open two secont then its quiet. how to do it?
thanks
eric
Posted on Mar 13, 2009
SOURCE: APC Smart-UPS RT 1000VA
Hello Dear Specialists I have a problem with the APC Smart-UPS smart 1000VA: when I insert the
power plug in the wall outlet in one ups , indicate the AVR Boost ups regulating low AC voltage, when I measuring the AC city power voltage that is 207v .whey this ups is not working about the AC low voltage? ,but it should be work from (170v ~ 230v) AC input volte.please solve this problem, which element of AVR from the ups is failed or wrong and give me free circuit diagram low & high AVR and charger and inverter circuits. thanks allot
Posted on Jun 17, 2009
  • 1684 Answers
SOURCE: APC UPS 1500 w/full load forces immediate reboot at pwr failure
With a 980watt load the run time is only 7 minutes on a brand new battery. If you have the system on full load your run time will be much less and it has likely damaged the battery. here is the APC web site page for your model. If you are running that much equipment I think you need either a bigger UPS or another 1500 and spread the load out.
Buddy
Corporate Computer
Posted on Jul 24, 2009
SOURCE: APC Back UPS RS-1000 Overload LED with beeping sound after on.
in the end solution is you have to bring it nearest apc service.
if you loaded more than its max. capacity at past, the sensor of power is geting burn the sequare wave generator IC.
so you need help with that, olso complicated.
I live the same position with my rs1000, horrible :((
Posted on Jan 09, 2010
jaye_ellen
  • 591 Answers
SOURCE: hi my APC 1500VA smart UPS show overload
Contact APC Customer Service. They will help you resolve this. If unit is still under warranty they will replace it. There is nothing you can do to repair anything yourself. Sorry ... try calling 1-800-555-2725800-555-2725 for support from APC
Posted on May 06, 2010
My ups does not give enough back up and the others are not powering
It is usually a battery problem.It is not charging anymore.The battery is the power source for your UPS once the AC source is cut off.Open the unit and there you could locate the battery enclosed inside the UPS box unit.Replace it with the same type and size of battery, observe polarity where the red is (+) positive and black is negative (-).Depending on what the manufacturer used for the color coding but still see where the Positive and Negative wires are connected to.But before you open the unit remember to unplug the unit from the power outlet.
Nov 06, 2010 | APC Smart-UPS 1000VA UPS System
Infinit loo between online and on battery?
With all 5 units behaving the same, I would expect that the power is still out of range. If the power is too high or too low (see manual for thresholds) the unit will stay on battery power to protect the attached equipment. If you have the software loaded, it will show you what the input AC voltage is at. Otherwise, it could be time for new batteries: http://batteryinternational.com/apc-smartups-1000-ups-battery-ups-batteries-f2.html
May 09, 2010 | APC Smart-UPS 1000VA UPS System
Hi my APC 1500VA smart UPS show overload without any load in battery mode, but when switched on AC power all lights are blinking. plz describe me how to resolve this Issue?
May 06, 2010 | APC Smart-UPS 1500VA Shipboard...
shady545, If units have batteries older than 3 years of age, they may need to be replaced. I suggest you evaluate each unit one by one and try swapping in a new set of 12v 12ah or 18ah fully charged batteries to see if that will clear-up the problem in at least one unit. I had to replace both batteries in my APC1250 when one battery developed a shorted cell. Let me know what you find out with your units. 12fixlouie 30min north of Windy City
Mar 17, 2010 | APC Smart-UPS 1000VA UPS System
How to connect a UPS to a computer? why some UPS with RS-232 port some UPS not? What is difference from APC smart UPS and normal APC UPS? Why APC with same VA output, but the price is so much difference?
A UPS goes between the Power Socket and the PC equipment.
So ya can "Talk" to the UPS and change monitor settings. So do some don't depends wat ya want?
A "Smart" one is computer controlled, and most probably ya can "Talk" to it, the other is the "Vanilla" model, real plain.
More Complex.
Jan 26, 2010 | APC Smart-UPS 1000VA UPS System
APC SMARTUPS 1500VA Battery Problem When Replaced
You are correct. The APC Smart line has a partial charge when it's new. Similar to cordless phones, the work right away, but you're still supposed to charge them before use for best results.
Just leave it plugged in with no load for a couple hours and it will be fine.
Sep 02, 2009 | APC Computers & Internet
APC Smart-UPS 1400 no power
Better late than never...
The older Smart UPS models are peculiar in the way that they appear dead (will not power on) if the battery is completely bad.
Replace the battery, and the UPS should come back to life.
Jul 01, 2008 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
APC Smart-UPS 1000VA shut down and now will not power on. How do I troubleshoot? No power, no lights, nothing and I've never tried to troubleshoot a UPS before. Where do I start?? :-( Thanks Chris
Hello Chris,
I have a similar unit and there is a fuse inside that can blow. Mine did. It worked again after replacing the fuse.
Another option...check the battery connections.
Another option...are the batteries getting old? If so, when they won't reach a certain level of charge the unit will not power on.
Finally, make sure you don't have a blow fuse or popped circuit braker in your home.
Hope this helps?
Charlie
Nov 21, 2007 | APC Smart-UPS 1000VA UPS System
APC Smart-UPS 1000VA UPS System Logo
206 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
