How do you share a netgear router . my neighbor and i want to share the bill..
  • 3,289 Answers
First, you'll want to do this wirelessly. Running a copper network cable (CAT5, etc.) between equipment (computers and other network gear) that is plugged into two different electrical systems (your house & the neighbor's house) is going to cause problems. The slight differences in voltage between these homes is going to try to equalize over the copper network wiring between the two homes. The points of connection will be the router in one home and the network device in the other (this can be the computer network card or other switch). You will be repairing and / or replacing these parts pretty often - especially after lightning storms. Of course, if you run fiber between the two locations, this voltage equalizing problem won't be an issue and the network will be very reliable and extremely fast. This is highly recommended but is also costly.
My suggestion is that you use a pair of high gain, directional antennas pointed directly at each other (if signal strength is an issue). The more gain they have, the better the wireless performance of the network and the longer the range will be (this is very helpful if you're more than 100 yards apart). Since the signal is concentrated in only one direction, it restricts the ability of the network to be detected all directions by those not it is not intended.
To do this, you'll need to utilize network hardware that supports the use of external antennas. This is accomplished by devices that have removable antennas, secured by threaded antenna jacks. You would disconnect the supplied antenna from the router, and connect a short length of antenna coax cable designed for this use (the shorter; the better) between the new antenna and the antenna jack of the router.
You would do the same thing in the second location, too. You would use the wireless signal utility to help you aim the antennas at each other. Once the highest signal has been found, secure the antennas in position.
This second location could be a single computer with the network card's antenna replaced - or, optionally you could install a second wireless router so that you could connect more than one computer easily via CAT5 cabling in the second location. This would be done with wireless routers that are capable of "Wireless Bridging" This is easier (less expensive, too) than trying to aim multiple antennas in the second location at the router in the first location.
A detailed site offer a great deal of information to do this. They also have firmware that you would use to replace the factory firmware of some routers that make it easy to adjust and configure your network. For instance, I used a couple of LinkSys routers from eBay that cost me about $50 each, and a couple of antennas and 3 foot long coaxial cables for another $100. For about $200, I was able to exactly what you're trying to do. Check the site. Review the list of routers that is supported by the firmware if yours is on it - you're that much further ahead - if not, well, it will be easier to get what they suggest. Download and flash the routers. Configure Bridge mode and see if you're close enough for decent speed and reliability. If lacking - consider purchasing antennas.
There's a LOT of info to learn, but if you take your time, read, ask questions there - you'll get what you need. Check out the site:
DD-WRT
This is a starting point and should give you a point to start learning more about this. Please rate my reply. Thank you.
Posted on Mar 23, 2011
Why is my stationary computer finding an unknown network beside my ordinary one?
It might be your neighbor's network? Just ignore it and it won't hurt you.
Jul 28, 2014 | NetGear Computers & Internet
Can i use my netgear adapter to pick up xbox live on a new xbox 360 from stealing my neighbors wifi signal
not really, as it can't share that signal with your xbox. It can only join their network. If you had a router, and you set it up to "extend" their network, then you could have your xbox connect to the router which would be on their network.
Of course this is illegal and I advise you don't do it.
Apr 22, 2011 | NetGear USB 2.0-Stick WiFi 108 Mb WG111T...
Netgear adapter/router compat. issue
1. Unplug the router for 1 minute
2. Clear the browser cookies, temp folders,history.
3. reboot the computer.
4. Ping the router
5. log into the router and check the status page.
May 20, 2010 | NetGear WNR2000 Wireless Router
I cannot get my wireless router to transmit a signal?
Make sure it is turn on under the wireless tab on the router. If is try changing number, your and your neighbor can be sharing same channel number. That happen to me.
Nov 16, 2009 | NetGear DG834G Router
No print sharing. Existing but lder Belkin router has no problems, but WRT54g-TM will not print share. Have a Netgear switch box as well, can I integrate the two or even all three to solve print share...
If you are using a belkin router, wrt54g-tm and netgear switch box. Basically they won share the printing. you need a wireless print server..try the linksys WPS54GU2
Jul 28, 2009 | Linksys WRT54G-TM Wireless Router
Netgear SmartWizard Help
Is there an option to use a dynamically assigned IP address (also called DHCP)?
That's most likely the option you need, almost all home Internet providers use DHCP to assign the information you are asking for automatically to your Internet connected device (in this case, your router).
Let me know what options are available to you if neither Automatic or DHCP is.
Thanks!
Mar 29, 2009 | NetGear WGR614 Wireless Router
Netgear DG834PN ADSL ROUTER AND HUB - PC dial-up connection
so your trying to use a dsl router as just a router -dsl with dialup?
Aug 06, 2008 | NetGear Computers & Internet
Netgear 834
changed wep to wpa.ipod works great
regards
Jan 05, 2008 | NetGear DG834G Router
Netgear WPNT834 wireless not working
This could be some kind of interference. Try changing the channel.
Oct 07, 2007 | Nortel Contivity VPN Switch 1600...
Computers & Internet Logo
85 people viewed this question
Alun Cox
David Payne
David Payne
