Question about AEG L86800 Front Load Washer
WE HAVE CHANGED THE OUT LET PIPE FOR A LONGER ONE NOE MACHINE WANT START ITS SAYING E,F O
    Brigadier General:
  • 6,277 Answers
Sorry but I do not have the decode for EF0 your particular machine but in the same 'area' EF1 states 'drain filter blocked/kinked/too high, drain filter dirty/blocked and considering that you have recently changed the outlet (drain) hose I would suggest checking those items. In particular I would suggest that you check the drain motor lint tray/filter.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 23, 2011
My cd drive will not read or write cd i put in a cd and my drive will not read the disc. it will not start
Remove it from Device manager by right clicking and saying uninstall and restarting your system then it will install the driver again and noe it should work normally.
Mar 15, 2014 | Toshiba (WMD070AC) Magneto-Optical Disk...
I have mercedes sprinter 313 cdi 2002 recently noticed taking longer to start hot and cold 4 weeks ago changed fuel filter Thought this must have something to do with problem So changed o rings on top of...
Normally problems starting could be the glow plugs these warm the diesel up making ignition easier also check the wires going to glow plugs if only 1 of these are off it makes starting harder
Oct 02, 2017 | Mercedes-Benz Cars & Trucks
98 continental turns over will not start
the immoblizer is on lock and unlock the drivers door using the key to reset it,noe try to start..good luck
Mar 22, 2012 | 1998 Lincoln Continental
I start the machine, it runs till it would appear that it is full of water and ready to start to wash, then shuts off, displaying a message saying "Unable to fill - check water supply" IF you then push the...
disconnect machine from mains electric supply. remove top cover of machine then check the back of the control panel for a small black pipe, it should be attached to a small nipple in the panel rear if it is not you will get the fault you describe. if the pipe is connected remove it and blow down pipe with your mouth or a foot pump to remove any blockage then reconnect it and try the machine again. check also that the pipe is not trapped or kinked too i hope this helps you
Oct 14, 2010 | Dyson Memory CRO1 Front Load Washer
Changed to windows 7 and now noe of my acer
you have to install all drivers fro your acer.
Go to acer support and download drivers.
Start with the chipset driver and than the others,
Restart after every install.
http://support.acer-euro.com/drivers/downloads.html
May 15, 2010 | Acer Aspire 6930-6771 Laptop
please refer to this link for your drivers for windows 7 http://tinyurl.com/dbqaop
Mar 28, 2010 | Acer Aspire 6930-6771 Laptop
Gaggia titanium machine, is Ventilate problem connected to leak??
the steam valve is most likly plugged with sacale or such have you decaled the machine latly may want to start there
Dec 17, 2009 | Gaggia Titanium Espresso Machine
Neff coffee machine keeps saying fill up pipe-sys
I have a questionDoes this machine have a preheated ewservoir? Do this,keep filling the pip sys until it wont take any mor. cke the machine and make sure there is an on switch on the side at the back, if so, turn it on and wait 15 minutes . Make sure you have a carFE OR CATCH CONTAINER WHERE IT IS supposed TO COME OUT. gOOD LIuck.
Jun 27, 2009 | Coffee Makers & Espresso Machines
Washing machine drain hose/pipe leak
Make the standpipe longer (the black pipe).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 01, 2009 | Washing Machines
AEG L86800 Front Load Washer Logo
64 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
