How do i log on to the safeboot mobile data security on my pc
    Genius:
  • 2,669 Answers
Depends on the make of computer, most popular keys are F8, F12 . Delete key. Shut down the computer, Reboot computer ,press one of the above keys repeatedly till the computer beeps, if you were lucky and pressed the right key the computer safe mode screen will appear , if not start over with another key. Do what you have to do then reboot. Note must start pressing key before computer beeps.
Posted on Sep 18, 2014
  • 187 Answers
Answer: To get into Safe Mode with Networking: 1.Log out and reboot your machine. 2.When the machine starts the reboot sequence, press the F8 key repeatedly. 3.Select Safe Mode with Networking from the resulting menu. 4.Login. If malware has changed your password, try logging in as Administrator. By default, Administrator has no password. 5.The machine will continue booting, but the Windows desktop will look different. 6.When you're finished doing what you need to do, log out and reboot back into normal mode. Hope that helps.
Posted on Mar 25, 2011
Hp safeboot password removal
I'm assuming this is a desktop since you said motherboard. First take cover off then locate small round battery (looks like watch battery) remove it and count to 15.or 20, replace battery and cover. You will have to reset time but all memory should be cleared. You should go to Hewlett Packard Compaq support. If you find this didn't work, it's in your HD. computer.> HD >properties>tools>check disk> all else fails reformat.Hope you have the oringinal windows disk
Dec 10, 2011 | HP Compaq 6735s Notebook PC
Tip
Unable to create a Yahoo account on mobile phone
Log in to your Yahoo account from a PC.
Go to your email at the top right corner and select account info.
Go to Account Security, you will need to log in again
Turn on "Allow apps that use less secure sign-in"
Go to mobile phone and create account again.
on Feb 08, 2017 | Miscellaneous
Tip
How to make windows installer work in safe mode
Windows Installer will not work under Safe Mode, this means that programs cannot be installed or uninstalled in safe mode without giving a specific command using msiexec in command prompt.
To make Windows Installer work under safe mode, you need to create a registry entry for every type of safe mode you are logged in to.
1.Safe Mode.
Type this in a command prompt:
REG ADD "HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MSIServer" /VE /T REG_SZ /F /D "Service"
and then
net start msiserver
This will start the Windows Installer Service.
2.Safe Mode with Network
REG ADD "HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MSIServer" /VE /T REG_SZ /F /D "Service"
and followed by
net start msiserver
on Mar 15, 2010 | Computers & Internet
How to start safe mode on computer
As soon as you turn on the computer you have to keep tapping the "F8" key on the keyboard and you will get the advance boot options menu and select safemode in it
Thank you
Oct 30, 2010 | Computers & Internet
My pc is stuck in safe mode. How do I get out of this? This is before main page.
Hi, If you cannot log on normally again on your computer. you can go to start > click on run > type 'msconfig' > then click on boot.ini > if safeboot is checked, remove the check on the box. then restart the computer. look at the picture below. 03f2689.jpg
Thank you for using Fixya, your recommendation is highly appreciated for the free support.
Oct 07, 2010 | Computers & Internet
Safeboot corrupted (error 92h)
Check the BIOS setting to see if the hard disk is detected. If not either the hard disk controller or the hard disk is faulty.
First thing I would try is to remove the hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this hard drive as an external hard drive and you can open the various folders and files, then I would backup your data.
If the hard drive is not detected then the hard drive is dead and data cannot be retrieved with this method.
Retrieving data from damaged hard disk is possible. There are companies that can remove the disk platters from the damaged hard drive and with special equipment may be able to recover your data, but it will cost you an arm and a leg for their services.
Jun 24, 2010 | HP EliteBook 2530p Notebook
My dimension won't boot anymore, not even safeboot
I would suggest you to install another OS in the system. Choose a drive in which you have some space (or may be create a separate drive during the OS installation). May sure you choose the same File System as your first operating system. I guess you should be able to retrieve the data from that OS and then might consider formatting the drive once you are done.
Feb 12, 2010 | Dell Dimension 3100 PC Desktop
G4 MAC LOCKING UP
After boot??? Have you tried holding down the shift key (Safeboot). If you can log into your account then check startup items in systemprefs/user accounts/startupitems
If it still crashes you need to create a new user account. Log in and if that works then copy all data from old account by using Batch Mod on old users folder. Do not copy anything from user library.
Jun 26, 2008 | Apple Power Mac G4 Dual Mac Desktop
Computers & Internet Logo
326 people viewed this question
David Payne
David Payne
