Question about Kitchen Appliances - Others
I need a part for a electromaster sandwich toaster
How do I clean it after grilling
Gloria, All the links can show how to clean after grilling.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Wash Toasters and Sandwich makers
What the best way to clean panini press with non removable sides
How to Clean Sandwich Toaster Helpful Tips to Cleaning Your Kitchen...
Easy tips for cleaning an electric grill
Apr 19, 2016 | Kitchen Appliances - Others
Where can I get it repaired?
How to fix and open, Sandwich Maker Disassembly - YouTube
? 5:05
https://www.youtube.com/watch?v=HAsnk6qebDw
Apr 9, 2015 - Uploaded by Teo Zb?rcea
7:09. Chicken Recipes - How to Make Chicken Panini - Duration: 2:49. by Allrecipes 126,361 views. 2:49. Beginning TechsRepairing a Toaster ...
How to Repair a Toaster - How to Repair Small Appliances ...
Dec 25, 2015 | Kitchen Appliances - Others
My toaster is not hot enough, the bread doesn't get toasted, is there a way to fix this?
Sounds like your toasters heat selection switch is defective or the knob my be stripped that adjust the heat level..try pulling the knob off and see it is..To check use a small pliers to turn the switch manually to the lighter or darker mode if it gets hotter and cooler it is the knob if not the switch must be replaced..good luck
Dec 31, 2014 | Krups Sandwich Maker Fdk112 - Extra Large...
1978 ge toaster
Their website claims that the ProHeat elements fit toasters made in the last 50 years...
I would say take the thing to a good electrician, and she can inspect one of the ones that still works, compare it to the one that burnt out, and come up with some sort of fix...
Nov 19, 2013 | Dualit Kitchen Appliances - Others
Need manual for VST004 Sanwich toaster
Hi there.
I have seen Breville Owner's Manual but only for BTS400 4-Slice Sandwich Maker.
If this is the one you are looking for, you can download it at http://www.breville.com.au
Regards.
Jul 16, 2011 | Breville VST004 Sandwich Maker
Back ti Basics toaster the Egg portion does not get hot
Call the company. They will send you a new toaster -- at least they did for my neighbor.
May 10, 2009 | Back to Basics TEM-500 Egg & Muffin...
I need instructions for Toaster VTT090
Below the only manuals for toasters available from breville.
Sandwich Toaster
Die Cast Model
Ikon model
Hope they can help
Mar 02, 2009 | Breville Kitchen Appliances - Others
Odor from toaster
ozone smells like fresh sweet air ( same smell as after a lightning strike )
what you probably have is the smell of melting plastic from wires in the toaster
Apr 06, 2017 | Kenmore KTES4 4-Slice Toaster
Kitchen Appliances - Others Logo
172 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
