Question about Ducane 30400040 Stainless Steel Grill
How to install new igniters ? - Ducane 30400040 Stainless Steel Grill
    Brigadier General:
  • 4,736 Answers
The easiest and simplest way, is to you the old ones as a guide. That is, if you haven't already removed them. If you have, here is a link to your owners manual. Pay particular attention to page 30 under Annual Maintenance. It will show you the wiring diagram.
http://www.weber.com/help/manuals/ducane/2009%20Manuals%20pdf/Affinity_3400_4400_LP_OwnersManual_27010341_061008.pdf
Hope this helps you solve the problem.
Posted on Mar 23, 2011
How do u install a new ignition on a 1997 Monte carlo
I would look around on the web like you are. Be sure to look in U tube.
Dec 11, 2017 | Cars & Trucks
Lost ignition key
got to your nearest dealer for the make of bike you have ! Or look up M n P motorcycle after market parts in Wales Uk and email or phone them !
Dec 19, 2013 | Honda CBR 125 R Motorcycles
New key programming for lancer 2005
you need to first install one of factory key into ignition.turn ignition switch on position for 5 seconds.switch off the ignition and remove key.wait 7 seconds insert new key into ignition switch.and switch ignition on until alarm system warning lamp will flash twice mean key programmed. switch ignition off if warning light illuminate for 3 seconds to confirm or flash 3 times indicate registration has failed. if you fail on programming new key let dealership reprogram new keys using diagnostic equipment.
Dec 20, 2012 | 2002 Mitsubishi Montero Sport
How to install a 94 buick regal ignition modulator
take the negative cable off the battery,unplug the plugs relaled to the ignition module.remove the ignition wire from the coils ;remember where they were removed from so that you don't cross the wires. once that you've done that remove each coil and the ignition module will be cler and available for you to remove the screws that holds the module in place. install the new module, be sure to follow all directions and repeat the removable instruction in reverse to install new module.
Sep 03, 2012 | 1994 Buick Regal Gran Sport
I need a wiring diagram for a 2002 883 harley sportser
If you are going to install a new ignition unit, all you basically need to know is which wire is the "HOT" wire. Disconnect all the wires to the coil, turn the ignition switch on and use a test light to find the "power" wire. Once you know which wire this is, you'll need the wiring schematic for the particular type of ignition unit you're installing on your bike. Usually, if you got the website for the manufacturer, they'll have "installation instructions" under their "Technical" section. Usually, with a dual fire ignition system, there are only three wires to hook up. Good Luck!
Feb 22, 2010 | 2004 Harley Davidson XL 883 Sportster
Car still running after take key out . cheked barrel thats ok don't know if it's relay problem
I think you have a bad ignition switch, not the ignition lock cylinder. they are 2 different things.
Section 11-05: Steering Column Switches 1996 Taurus, Sable Workshop Manual
REMOVAL AND INSTALLATION Ignition Switch Removal
  1. Disconnect battery ground cable (14301).
  1. Remove lower instrument panel steering column cover (04459).
  1. Rotate ignition switch lock cylinder (11582) to the RUN position.
  1. Disconnect the ignition switch electrical connector.
  1. Remove the two screws retaining ignition switch (11572).
  1. Disengage the ignition switch from the actuator.
Installation
  1. NOTE: A new replacement ignition switch assembly will be set in the RUN position as received.
    Adjust the ignition switch by sliding the carrier to the ignition switch RUN position.
  1. Make sure that the ignition switch lock cylinder is in the RUN position. The RUN position is achieved by rotating the ignition switch lock cylinder approximately 90 degrees from the LOCK position.
  1. Install the ignition switch pin into the actuator. It may be necessary to move the ignition switch slightly back and forth to align the ignition switch mounting holes with the lock cylinder housing threaded holes.
  1. Install retaining screws. Tighten to 5.6-7.9 Nm (50-69 lb-in).
  1. Connect electrical connector to ignition switch.
  1. Connect battery ground cable. Check ignition switch for proper function, including START and ACC positions. Also, make certain that the column is in the LOCK position.
  1. Install lower instrument panel steering column cover with screws.
Nov 21, 2009 | 1996 Ford Taurus
Installing new ignition switch in dash, would like to know howw the old one comes out.
installing new ignition switch in dash, would like to know howw the old one comes out.
Aug 01, 2008 | Oldsmobile Intrigue Cars & Trucks
Ducane 30400040 Stainless Steel Grill Logo
141 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
