Question about Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator
I removed the bottom Cool Select Pantry door to remove it, and I am unable to slide it back fully into it's slot. It stops a couple of inches from the back of the refrigerator, and I am unable to get it to fit completely in the opening. I read the user's manuall, and have made sure the rails are as far back as they will go (they stop within the mechanism slide, and do not extend all the way back the wall of the refrigerator.). I am unable to fit the drawer back into the refrigerator. Is there a tip to doing this?
SOURCE: samsung refrigerator
There is a screw down foot in front of each forward wheel under the fridge. You can access this by looking under the front corners.
Posted on Apr 16, 2008
tborn6
  • 700 Answers
SOURCE: SM-RS255BASB
there are 11 screws that hold the regrigerator cover on. the light cover is the easist because it snaps in besides the 1 screw in the middle, the htere are 4 mre that have to caosnm e out behind the ligeht cover. then thered are two in the middle that are covered with aa blank offf cover. the htere's the 2 for the resevour and finally the two on the bottom
Posted on Dec 24, 2008
  • 531 Answers
SOURCE: Food in Chef's Pantry drawer freezes, even on warmest setting
check the cold control or the door is not closing proper
Posted on Apr 01, 2009
SOURCE: Door Removal
If you don't have the manual, go to Samsung's website and download the manual. It explains how to remove and adjust the doors and bottom drawer.
Posted on Jul 25, 2009
Bat1956
  • 585 Answers
SOURCE: my Samsung RB1855SW refridgerator not cooling
You may just be catching the unit during normal defrost cycles. Next time, allow the unit some time to complete it's needed task. If you allow it 30-minutes, it should restart on it's own. The cycles are necessary to keep the unit working properly. The cycles will be more frequent as the weather warms. If you allow the unit 30-minutes and it does not restart on it's own, then there could be a problem. You might consult the owners manual for more details.
Posted on Apr 06, 2010
Can't get rf266abpn cool select pantry drawer back in
There may be guide rails on the underside of the shelf above.
Apr 25, 2016 | Refrigerators
Cool Select Pantry, to relocate per manual instructions, doesn't slide all the way in.
Cool select Pantry
To remove the pantry - Pull the pantry out to full extension. Tilt up the front side of pantry and pull straight out.
To relocate the pantry - Push the rails to the back of the Refrigerator. Place the drawer onto the rails and slide the pantry back until it is in place.
before install they ask to push the rails to the back of the refrigerator
should be no problem
Jul 29, 2014 | Samsung RFG297AARS Bottom Freezer French...
I cant get the cool select pantry drawer back in
I just had the same problem. The drawer was removed for cleaning and we could not get it back in; it would slide in with about 3 inches not able to go in. Took everything out that we could and still could not get it to go back in all the way. Finally started looking closer at the metal rails and the sides of the drawer and realized there is a tab on each side that needs to be inserted in the the corresponding hole on the metal rail. With the drawer out, pull the rails all the way out; place the side rails of the drawer on the metal side rails and line up the tabs with the holes and insert. Your drawer should now slide in correctly.
Dec 18, 2012 | Samsung RF265AA Bottom Freezer French Door...
Freezer rack
Without further info, this is just a guess; but generally 'Frig/ Freezer racks may be drop in, or slide in, or pinned. Does the fron or the back (or both) Lift? is Ice holding it in place. Some lift in the front & then slide out. Some lift in the back then you slide it sideways in the front and release one side, tilt it and slip the oter pin out of its hole. The ones that are adjustable usually have slotted bars in the back. You lift the front several inches and then pull it out of the slots in the back. Most of the time the door(s) must be fully open to get them out.
Mar 27, 2012 | Refrigerators
How do I change cabin air filter in 2006 m35? video or pics?
First, you need to remove the glove box: Open the glove box. There are three hinge points at the bottom of the box (left, center and right). There are "tabs" on the box that slide into these "holders". Gently pull up and out on the left side of the glove box. The tab should pop out. Repeat for the center point. This should allow the left side stop pin to clear the dash slot. Repeat for the right side. You should now be able to turn the box, pull it from the dash and let it hang from the retaining cord on the right side. Note the hinge slots and tabs for reference for re-installation later. Second, remove the black access door behind the glove box: This is an "L" shaped cover with three hinge points at the bottom and three tabs at the top. Gently push back on the tabs at the top to un-lock, rotate down on the hinge points and pull out. Behind this you will see a white plastic door which covers and holds the filter in place. Third, remove white access door as follows or you will break the retaining tabs off! On the right side is a locking tab, gently press in and pull the right side of the tab toward you to unlock the tab BUT STOP AS SOON AS THE TAB UNLOCKS THE DOOR AND OPENS ABOUT ½ " or the tabs on the left side will break off, they are not hinged! Next, slide the door to the right to clear the tabs on the left side and remove. Note the position and orientation of the filter inside. Remove the old filter. Fourth, install the new filter: Make sure the orientation and air flow direction are as marked and match previous filter. Mine was pointing "up", with the rigid side plate facing out. The new filter will be sitting on top of the fan, when the white door is re-installed, it has "fingers" that lift the filter into the proper location, but you may find it easier to lift the filter up with one hand and slide the door back into position with the other hand. That said, lift the filter, slide the tabs on the left side of the door back into there slots. Push the door back into original position and latch the right side locking tab. Make sure the door is sealed and back to original position and latch tab on the right is locked. Now, reverse the previous steps to complete the task. Re-install the black access door cover. Lift up the glove box and turn to install right side stop pin into dash slot position, rotate left side into position and center box in dash opening. You will have to move the box up/down, in/out a bit to "feel" the hinge tabs properly engage the hinge slots. Once the tabs are in the slots you can push down on each side and it will pop back in place. (If you have difficulty, you may want to remove the under dash cover below the glove box. There are three tabs in the front that slide into three slots and one tab and slot in the rear. This can be removed by pulling down on the front of the panel at each side and the middle, then slide it forward out of the rear slot. Disconnect the light if required by pushing the latch on the plug and pulling it off. Feel around the hinge locations to guide the parts together).
Read more: http://wiki.answers.com/Q/How_do_you_change_the_cabin_air_filter_on_a_2006_Infiniti_M35#ixzz1NKCLa6qC
May 25, 2011 | 2006 Infiniti M35
I removed the range door to clean oven. Now I
NOTE: The door removal pins you inserted must still
be in both sides of the door.
1.
Grasp the door on the sides with your fingers on
the front of the door and your thumbs on the
inside surface.
2.
Rest the hinge hanger so that it is flat (at the
bottom of the hinge hanger on the bottom of the
front frame slot).
3.
Position the door with the hinge hanger slots
almost parallel to the front frame.
4.
Push up and in until the hinge hanger slots
become fastened to the range. Lower the door
and rotate it slightly from the front to the back
until the slots are fully fastened. The hinge
hanger will be close to the bottom of the front
frame slot.
5.
Pull door open about halfway and remove the
door removal pins. Save door removal pins for
future use.
6.
Close the door.
Dec 25, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
My sd card came out of my camera
IT SHOULD JUST SLIDE BACK IN PUSH IT UNTIL IT LOCK IN
Apr 08, 2009 | Philips PT44434 Digital Camera
Whirlpool range
Hello dolphin 1 mom
Welcome tofixya.
You said, accidentally removed the door to my range and now it won't go back on. The door won't go back into the slots on the range.
Send me your e-mail address and I'll e-mail the diagram with the door instructions for removal and replacement.
It will not fit in here with the diagrams.
Waiting for you.
Huuum
Please do not forget to enter a rating when we are done
These are the installation instructions, but with no diagrams
To Remove:
1. Open the oven door. Insert door removal pins, included with
your range, into both hinge hangers. Do not remove the pins
while the door is removed from the range.
2. Slowly close the door until it rests against the door removal
pins.
3. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on the inside surface.
4. Pull door straight up, then toward you. Hinge hangers will
slide out of front frame hinge slot. Do not remove door
removal pins until the door is replaced on the range.
To Replace:
1. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on its inside surface.
2. Hold oven door so that the top edge of each hinge hanger is
horizontal. Insert hinge hangers into the front frame hinge
slots.
3. Tilt top of door toward range. Slide hinge hangers down onto
front frame support pins. Make sure the hinge hangers are
fully seated and engaged on the support pins.
4. Insert the door stop clip with its angular surface at the top of
the frame hinge slot, then push in the bottom of the clip until
its flanges are flush with the front frame.
5. Open the door completely and remove the door removal pins.
Save door removal pins for future use.
6. Close the door.
StorageDrawer
The storage drawer can be removed. Before removing, make sure
drawer is cool and empty.
To Remove:
1. Pull the storage drawer straight back past the drawer stop
notch and the end of the side rails.
2. Lift up the back of the drawer and pull the drawer out.
To Replace:
1. Lift up the back of the drawer and place it inside the range in
its fully forward position.
2. Lift up the front of the drawer to a level position.
3. Slowly push the drawer into the range until the drawer side
rails engage with the gap in the drawer glides.
4. Once the drawer is fully engaged on both sides, slide the
drawer back into the closed position.
NOTE: When removing and replacing the storage drawer, a slight
push may be needed to move the drawer stop notch past the
drawer glides.
A. Removal pins
B. Hinge hanger
A. Hinge hanger
B. Door frame hinge
C. Support pins
A
B
A
B
C
A. Drawer stop notch
B. End of side rail
A. Engage drawer glide
A B
A
Sep 09, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator Logo
431 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
