Question about Sylvania G-Netbook
I need help get this to work for me - Sylvania G-Netbook
    Genius:
  • 1,267 Answers
Try follow ing the detail listed below.
It is looking for apassword (WiFi Network Key) You have to double click on the little computericon down in the right tool bar area, the one with the two side radiating arcs,and possibly has a small red X under it. The red X indicates that it is NOTconnected. When you double click on that icon a window called RT28701 opens up,then you click on Wireless Information tab, then you cursor down to the name ofyour WiFi and high light it and click the connect box. Then another windowopens up called Network Properties. Uncheck "The key is providedautomatically" box. This will allow you to type in your "NetworkKey", the password that protects your network from outsiders. This"KEY" was set up when you installed the router on your servercomputer. If this does not work at first, turn the machine over on its back andusing a toothpick, insert it into the little hole about an inch diagonally fromthe right corner of the data plate, this will re-load a new copy of everythingincluding the WiFi RT28701 driver. sometime thisdriver gets confused. See my TIP at: It is looking for a password (WiFi NetworkKey) You have to double click on the little computericon down in the right tool bar area, the one with the two side radiating arcs,and possibly has a small red X under it. The red X indicates that it is NOTconnected. When you double click on that icon a window called RT28701 opens up,then you click on Wireless Information tab, then you cursor down to the name ofyour WiFi and high light it and click the connect box. Then another windowopens up called Network Properties. Uncheck "The key is providedautomatically" box. This will allow you to type in your "NetworkKey", the password that protects your network from outsiders. This"KEY" was set up when you installed the router on your servercomputer. If this does not work at first, turn the machine over on its back andusing a toothpick, insert it into the little hole about an inch diagonally fromthe right corner of the data plate, this will re-load a new copy of everythingincluding the WiFi RT28701 driver. sometime thisdriver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing AdditionalInformation When I try to signon with the red X showing, I get "The page cannot be displayed If I thendouble click on the icon down in the right corner I elucidated above, RT28701opens up to "Internet Protocol (TCP/IP) with all zeros in the IP addressfield, and Subnet Mask, with no entries in the default gateway. That is a clueto me that the automatic sign on has not found a viable network, or needssomething else. If I then click on Wireless Information tab, the list ofavailable networks, appear in the box. The machine keeps trying to associate myprevious entered name site with my preferred site and tells me the signal isgood, but it cannot link up. This is a signal to me that it has lost my NetworkKey or that the softwarehas failed or both. I then click on advance and delete my preferred network andhit OK, this will force the software to ask me for my network again, and noticethat the preferred is missing. I click on the name of my network again and thenhit connect., then the Wireless Network properties window opens up and I caninsert my Network Key again after I uncheck the "The key is providedautomatically" box. I enter the key and hit the OK button. I still do notget a connection, so I reboot the machine, and wait for about 30 seconds andthe machine synchs up because the little RED X under the icon has disappeared.Now the machine will hook to the internet as long as I want to, but sometimeswhen I turn the machine on it will not synch, so I go through the abovesequence again. The secret is once you have entered your key and ask for themachine to synch up you have to reboot. Why? I do not exactly know, but Isuspect that the WiFi driver looses it You may also wantto look at the TIP http://www.fixya.com/support/r7679654-sylvania_syneto7526_wirless_keyboard To make your knowledge complete AdditionalInformation When I try to signon with the red X showing, I get "The page cannot be displayed If I thendouble click on the icon down in the right corner I elucidated above, RT28701opens up to "Internet Protocol (TCP/IP) with all zeros in the IP addressfield, and Subnet Mask, with no entries in the default gateway. That is a clueto me that the automatic sign on has not found a viable network, or needssomething else. If I then click on Wireless Information tab, the list ofavailable networks, appear in the box. The machine keeps trying to associate myprevious entered name site with my preferred site and tells me the signal isgood, but it cannot link up. This is a signal to me that it has lost my NetworkKey or that the softwarehas failed or both. I then click on advance and delete my preferred network andhit OK, this will force the software to ask me for my network again, and noticethat the preferred is missing. I click on the name of my network again and thenhit connect., then the Wireless Network properties window opens up and I caninsert my Network Key again after I uncheck the "The key is providedautomatically" box. I enter the key and hit the OK button. I still do notget a connection, so I reboot the machine, and wait for about 30 seconds andthe machine synchs up because the little RED X under the icon has disappeared.Now the machine will hook to the internet as long as I want to, but sometimeswhen I turn the machine on it will not synch, so I go through the abovesequence again. The secret is once you have entered your key and ask for themachine to synch up you have to reboot. Why? I do not exactly know, but Isuspect that the WiFi driver looses it You may also wantto look at the TIP http://www.fixya.com/support/r7679654-sylvania_syneto7526_wirless_keyboard To make your knowledge complete
Posted on Mar 23, 2011
How do i work for smallworlds and help people who need help right now?
hi Caitlin.
i am in the uk so not sure if this is what you are looking for,go to this link might help you out.
How do work for smallworlds and help people who need help right now Google...
Nov 18, 2017 | Computers & Internet
I need assistance with getting my digital speedometer to work unable to find sensor, blinkers work
Hi, Catherine I would love to help you but the batteries in my crystal ball are dead so I have to resort to plan "B" mental telepathy let me see, yes I am getting something it's a little blurry, though if the images I received don't help you I am going to need the year, make, and model of your motorcycle so please ask your question again and provide this information in the details box or comment section or edit your original question. Good luck and have a nice day.
Need help with digital Speedo not working Scooter Doc Forum
Speedometer Not Working
Electronic speedo not working Speedzilla Motorcycle Message Forums
How to FIX For Scooter Speedometer and odometer Stopped Not Working
May 09, 2016 | Motorcycles
Printer doen't work
Need more info whats wrong??Leave more info in comments or call 225-290-5733 Thanks
May 02, 2014 | Office Equipment & Supplies
My game wont work
what is ur PC configuration??? tell me that first only then i can help u.
Nov 18, 2013 | Computers & Internet
IBall Baton 150M Wireless-N Router driver
iBall Baton 150M Wireless-N Router or any routers do not need drivers to work on your PC. Just the configurations settings provided by your ISP account.
Only Wireless adapters ie PCI or USB interface needs drivers for the device to work on your PC.
Here is a link pdf help file to help you configure your router to work on your PC/Laptop.
Hope it helps.
Dec 05, 2010 | Computers & Internet
Hey the audi ododnt work in win seven need help i
Currently no Windows 7 driver for this board. Latest OS supported is Vista 32 or 64 bit.
Jan 08, 2010 | ASUS P5GDC Deluxe Motherboard
Need driver for Canon Multipass C530 to work with Vista
Hi, Here's a link for your driver. If this helps plz rate this 'fixya', if you need more help leave a comment & I'll be happy to help. Thank you kindly.
http://www.dll-provider.com/search/Canon%20MultiPASS%20C530%20InkJet%20vista%20driver.html?aff.id=1950&aff.subid=3
Feb 13, 2009 | Canon MultiPASS C530 InkJet Printer
I have the Nintendo DS Browser and I need help working it.
sometimes you need to configure the connections manually, check the manual.
Nov 24, 2007 | Nintendo DS Lite Console
Sylvania G-Netbook Logo
48 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
