Question about Samsung UN46C9000 46 in LCD TV
The LED touch Pad underneath the stand does not slide out when touching the Pad. Happened after doing TV reset ( Pressed Remote " Exit" Key for15 secs). Samsung Model: UN46C9000
With your remote, go into Menu. Then scroll down to setup and press the right arrow. Scroll down with the down arrow until you reach General and press the right arrow again. Scroll down once on Slide Key and press the right arrow. Now turn this feature on if not already. If the slide key does not slide out then consult Samsung for repair.
Posted on Jul 27, 2011
Toshiba touch tv not responding to remote control or touch sensors
Do a hard reset, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jun 13, 2016 | Toshiba Televison & Video
Touch pad not working
reset all pluges on board.
Mar 07, 2014 | LG 42CS560 42 Class LCD HDTV
SAMSUNG 3D LED TOUCH PAD REMOTE FELL AND BATTERIES CAME OUT PUT THEM BACK IN NOW ITS FROZEE LIGHTS ON BUT DOSNT DO ANYTHING
it probably crack or misplacent is done in its circuit kit ..i prefer u to take the remote in samsung care if it is in warranty if not u can open it by own and see what has happened but be careful donot touch the kit
Dec 23, 2013 | Samsung Televison & Video
C-1105
If your copier model is KMB C 452/552/652 the code refer to Paper exit auxiliary roller motor malfunction.
Check the paper exit motor and sensor and the mechanical transmission drive components.To reset :
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON the copier.
Keep pressed the Utility key when the Trouble reset message appaire.
Release the Utility key and touch the message.
Turn OFF the copier ,wait 1 minutes and turn ON.
Apr 08, 2013 | Konica Minolta bizhub Office Equipment &...
Did it work for you before? what has happened since then?some laptops have a way to disable the touch pad so you won't accidentally move the cursor while typing. It may be a switch on the computer itself, or a LED in the corner of the touch pad, or it may be one of the Function keys (does any of them have a symbol of a mouse with a circle and one diagonal line indicating "no mouse") If so, push the fn key plus which ever function key has that symbol beside it.Some laptops automatically disable the touch pad if a USB mouse is plugged in.If none of these is the problem, you may not have a touch pad driver installed. Get a USB mouse to plus in until you get the driver installed. Go to the web page for the manufacturer for the laptop. Search for your model in the support section, and look for drivers. Download the appropriate driver for your touch pad and your version of Windows, and install it.Buying a USB mouse or a wireless mouse may be a valid solution no matter what the problem is if you like a real mouse.
Mar 02, 2012 | Computers & Internet
This has happened several times... so hopefully you can teach me what I am doing. I am in the middle of writing an email, my hand moves.... somewhere.... and the message is deleted. Sometimes it goes to...
What e-mail program are you using?
Try placing a piece of card or a thin book or similar item over the touch pad so it cannot be touched. Then try typing an e-mail. If the problem goes away then it is definately a problem with the touch pad. If the problem remains then there is some other problem, possibly the keyboard layout cause you to press the DELETE button by mistake.
If the touch pad is the problem then try setting the touch pad sensitivity to minimum. Plugging in a USB mouse DOES NOT disable the touch pad, so this will not help you if you accidentally brush the touch pad while typing.
Feb 16, 2011 | Acer Aspire 3000 Notebook
The remote and control panel are locked on my 52" LED LCD tv.
Hello
To unlock the remote control function do the following.
On the front pane touch control pad
1 Press MENU to display the MENU screen, and then
press VOL[--/+] to select "System Options".
2 Press CH [UP/DOWN] to select "Operation Lock Out", and
then press INPUT.
3 Press CH UP/DOWN] to select "Off", and then press INPUT
4 Press MENU to exit.
• To unlock the buttons on the TV, press MENU on the
remote control, and then select "Off" in "Operation Lock
Out".
OK.
Feb 16, 2011 | Sharp LC52LE810UN 52 in LCD TV
Unable to use touch pad....rt clk and slide key
If the laptop is that new, the problem is probably the touch pad "disable" button. Look for a small button just above or near the touch pad and make sure the touch pad is not turned off. If you cannot find the disable button, look in your user manual for the touch pad disable.
Jun 01, 2010 | Acer Aspire 5100-5022 Notebook
Touch Pad and mouse buttons
try it with toggle keys it may be work
May 03, 2017 | Sony VAIO VGN-N130G/W Notebook
Zune Touch Pad Stopped Working
The same thing happened to mine where just the touch pad doesn't work. It happened after a few monthes and to one of my friends as well; hers started working a day or two after and I had left mine alone once it stopped working but I went back to mine after she mentioned hers started working again and mine worked again too. I know that isn't much help because I don't know what fixed it but try just leaving it off for a few days and then going back to it.
Feb 04, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Samsung UN46C9000 46 in LCD TV Logo
189 people viewed this question
Jerry Greenberg
Jerry Greenberg
