Question about Carrier 38CKC036 Air Conditioner
Power to AC does not stay on
Furnace blower and thermostat are on and working fine,power to condenser but will not turn on until I press the switch at the junction,as soon as I release it shuts off.Filter was clogged and I replaced it,breaker was tripped and I turned it back on
  • 30 Answers
Sounds like you might have more than one issue. If the breaker is tripping could be the compressor. If you have to press in the contacts to make it come on something is not sending 24 volts to the contactor. may be a bad wire that runs from the outdoor unit to the control board in the furnace.
Posted on Nov 24, 2008
Goodman aepf426016aa
Communication problem. You say condenser stat and power are fine? if that means the condenser runs but the air handler doesn't that means the communication is good and the blower is not running. That may be a capacitor (you must have ammeter capable of checking microfarads) if not that check power it may be board driven. If no power to blower the board is bad assuming power is at board. If that is ok the blower motor is bad.
Nov 29, 2013 | Goodman Heating & Cooling
The heater coils are staying on after the thermostat kicks the blower off on the furnace. The coils are heting up the whole furnace until the blower kicks back on. Shouldn't the coils turn off when the...
The contactor or relay that turns the coils on has burnt the contacts closed....therefore the contacts are not releasing and shutting down the coils...
A rap to the side of the furnace may knock them loose but they will need to be replaced...
You can also shut them down by turning off the power to the furnace at the breaker.
heatman101
Jan 18, 2011 | Heating & Cooling
I changed the thermostat and then the ac stopped working
if this is a split system, go to the furnace or air handler. Shut off the power, remove blower door and find where thermostat wires go to control module.
Remove thermostat wires writing down where each one goes. Make a jumper wire and install it between r and y or r and y1.Put everything back together and turn on power. IF blower motor and ac start, you have
a low voltage wiring or thermostat problem.
If nothing happens then you either have no power to furnace, transformer
could be bad or you have blown a little 3amp automotive fuse that is
installed on the control board.
Jun 30, 2010 | Carrier 38CKC042 Air Conditioner
York Diamond 80 Issue. AC and Blower work fine. Heat will not come on. Circut breakers are fine, all power is on. Any advise.
Open the furnace door. Turn the thermostat on, and hold the power switch on. Look for the service code on the control board. That should tell you whats wrong with it. www.FastACservice.com
Oct 12, 2009 | Heating & Cooling
I have a Trane Xe-60 furnace about 19 years old. During summer months, with thermostat set to deliver air, the outside condenser runs, but furnace blower does not. I can move thermostat lever from auto to...
THIS IS A COMMON PROBLEM WITH THE DOOR SWITCHES, MY FIRST ANSWER WOULD BE REPLACE THE SWITCH SECOND WOULD BE OPEN THE DOOR AND PUSH THE BUTTON IN AND SEE IF THE FURNACE WILL WORK. THIS SWITCH IS JUST A DOOR SAFTEY IF THIS WORKS. I HAVE TAPED A PIECE ON THE INSIDE OF THE DOOR WHERE THE SWITCH WILL HIT THE DOOR ABOUT A 1/4 INCH THICK AND SEE IF THIS WILL GET YOU RUNNING UNTILL YOU CAN GET A SWITCH
Oct 12, 2009 | Omega Trane Furnace Draft Inducer Blower...
Blower stays on after heat goes off
when the room thermostat is satisfied it stops the heat by stopping power to the sequencer or contactor which is in series with the heating element/s...the TEMPERATURE OPERATED FAN SWITCH then takes over the blower until the heaters cool
Oct 02, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
AC unit turns on blower doesn't come on
The thermostat is the controller.
Jun 19, 2009 | Heating & Cooling
Carrier Weathermaker SXI Model 58SX8100LG Code 12
Code 12 I believe is power up after power off and a call for heat from the the thermostat. If you have a weak door switch that may be vibrating and going on and off it would cause this as would any thing that causes the power to drop low or out then reapply its self. try holding the door switch in while watching the board and after 2 or 3 minutes the furnace should go on to lite and the blower cycle off. If it stays in this mode try turning the thermostat off (heat - OFF -cool) and then push in the door switch nothing should happen except the lite on the board come on and stay on. If it does this than have someone turn the thermostat to heat and see if it starts or put the door on and set the heat and see if *** goes through the normal cycle of heating. If however it goes right back into the blower mode and shows the 12 code your problem is still with you. So next remove the wire on the "W" terminal on the board. Retry power to the door switch and now nothing should be on except the red lite. If it tries to start the 12 code and blower up again Im pretty sure you have a bad ignition/blower control board.
Mar 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Need to know which terminals run what
Had similar problem, continuous fan, turn off power, then won't start up. Replaced thermostat, no change. The main controller board in the furnace went bad. What was weird was that it happened in the summer, while the heat was turned off. One day I noticed that the fan was running. The thermostat was in the off position, and I had to shut off power to the furnace to make it stop. I forgot about it till heating season came along and it wouldn't start up. The preliminary blower would start, the gas would click on, it would light, then quit. After tracing and checking the various safety switches, etc. it became apparrent the main board was bad. I found one on ebay, replaced it, [a simple job, unplug, a few screws, replug] and it's been working fine..good luck, John
Nov 07, 2008 | Honeywell Focus 6300B 5-2 Days...
Carrier 38CKC036 Air Conditioner Logo
87 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
