Question about Bamix Immersion Handheld Blender
Bought a bamix frm ideal world now its stopped working blade not rotating
I need attachments
It seems you can no longer buy the HA-3058 or parts for that, however Bamix sells a similar product it seems to be the same machine with only a few aesthetic changes.
They sell many accessories and you can get blades.
Check:
http://www.bamix.com/
http://www.bamix-blender.co.uk/
I have had our customers buy the Bamix blades for the MegaMix HA3058 and the blades are interchangeable on those machines.
-Colleen@ MendingShed http://www.bamix.com/ http://www.bamix-blender.co.uk/
Apr 06, 2015 | Blenders
How can I Loosen the spring blades on a Bamix mixer attachment
You are lucky. they usually fall off mine.
However you can gently ease them off with small needle nosed pliers.
May 23, 2014 | Bamix Blenders
Rusting blade
Why don't you just clean it?
Very carefully use a soap pad, and then dry thoroughly. remember to dry thoroughly after every use, and wipe a little veggie oil on the blades with a paper towel.
Apr 07, 2014 | Bamix Mono Handheld Blender
How do i change the blades to change function
Website for company: http://www.bamix-usa.com/
Search by model on the site; they have streaming videos that may answer the issue.
May 17, 2011 | Bamix Deluxe Handheld Blender
Old bamix - motor on but the blade does not turn. unscrewed the bottom casing and cleaned out the oily part but still not working?
If possible, check the spot where the blade fits onto the driveshaft. It's probably a toothed gear or wheel. I have had blenders "die" before due to wear between the drive shaft and the blade. The blade would bump along inconsistently as the gear teeth failed to catch.
May 03, 2011 | Bamix Mono Handheld Blender
I have a bamix M200 hand blender & the shaft does not turn although the motor is working can you help?
After a period of time food residue will migrate up through the seal on the "foot" and lodge in the shaft. Once this is gummer up the motor will go but the shaft will not be able to rotate.
The machine will need to be disassembled and the shaft cleaned out. I recommend that you find your local Bamix Service Centre to do this as there are fragile parts in the stick mixer.
May 21, 2010 | Bamix Deluxe Handheld Blender
I have a Bamix Immersion Blender, but it stopped working. Press it on and it makes a humming sound but does not move. Where (in Canada) can it be repaired or replaced?
Sounds like the motor shaft has broken from the impeller. If I had it I would crack the case and see if that were true.(You might see screws holding the case together- If not, they might be hidden under the cosmetic label. If it is true, you need factory help. You better call Customer Service for Bamix.
THis is from http://www.bamix-usa.com/:
The drive shaft is frozen i.e. no longer rotates although the motor still hums: place the operative part of the appliance for 5 to 10 minutes in a jug of hot water, then switch it on. In general the appliance will then work again - if not just try to free the shaft very carefully with pliers
It can happen that the attachments fall off the shaft as they have in time become loose. In this case simply press the spring blades lightly together with a pair of pliers Processor/Dry Grinder: Discoloration of the bowl (i.e. carrots) can be cleaned with a cloth impregnated with salad oil.
Oct 23, 2009 | Bamix Immersion Handheld Blender
Whisk blade on BAMIX hand-held blender is frozen!
try to gently twist the blade up and around the shaft with a pair of pliers. I've loosened mine by pushing and pulling on the blade with the pliers. be sure to use caution so as not to wreck the blade.
Mar 17, 2009 | Bamix Mono Single-Speed Handheld Blender
Bamix stick blender Handle vibrates but shaft does not turn
Old food residue and juices will have got into the shaft bearings, and have dried out enough in 9 years to stop it turning. Starting with the simplest solution, try immersing the shaft in hot, or even boiling, water nearly up to the top of the metal shaft. CAUTION - DON'T BURN YOURSELF! Let it stand in the water for a few hours, and then try turning the shaft by hand (with the machine unplugged, of course). This could be repeated a number of times. You may also be able to unscrew the blade guard after this treatment, bear in mind it has a left hand thread, so if you are looking at it from the bottom, turn it clockwise to loosen. Be careful not to lose any seals or springs when it comes off.
If this doesn't work, support the Bamix upside down, and pour a small amount of WD-40 into the blade guard, so that it pools around the end of the shaft. Leave to stand, and the oil should slowly seep into the bearings, dissolving the food residues. Again, try this a few times.
If neither of these work, the Bamix will need to be dismantled to clean the shaft and bearings. This is really beyond the scope of this forum and requires some experience of this type of work.
Mar 13, 2009 | Blenders
Open Questions:
Dry mill base is broken I have an older version of Bamix (the dark brown handle says: " ESGE Handmixer, Listed UL 734 Z, M 122 2-speed Household Type 115V 85W 0,7A max.5 min. AC 60 Hz", then there's a caution about immersing, and at the end if says "90 01 bamix Made in Switzerland") which came with a dry mill which is 4.5" square dark brown base with white interior. The base upon which the blade rests is cracked and a part of it has broken off. The blade will NOT turn by hand. I know you will ask me whether I got this wet, and I assure you I did not. I enjoy my mixer and have taken very good care of it. However, the dry mill had not been used in several years (it got shuffled to the back of the cabinet and forgotten!) and when I found it I saw that some kind of black stuff was all over the inside of it (even on the underside of the blade where it rests on the plastic base), as if some mouse or other critter had eliminated all over it. Very nasty looking. I cleaned it with a damp paper towel, but cannot get the blade to turn, neither with the mixer attached nor by hand. I noticed that you now have a newer wet/dry mill. I don't know whether this will fit my older mixer, but it would be marvelous if I could just order another dry mill just like mine. What are the possibilities of this happening? I do not know which of the products listed below that I have; this is why I gave you all the info written on the top side of the mixer. I appreciate any assistance you can provide. Naomi Snider
Feb 28, 2017 | Bamix Immersion Handheld Blender
See all Bamix Immersion Handheld Blender Questions
Bamix Immersion Handheld Blender Logo
Top Bamix Blenders Experts
Ruth summersides
Mai Lor
Are you a Bamix Blender Expert? Answer questions, earn points and help others
