Question about Pit SSR 110CC Pro Beginner Bike
How to change the fork oil on a 110 SDG pit motorcycle?
How much oil per leg
Depending on bike it's normal between 420-470 per fork with the springs removed or set air gap between 105-110 mm with fork level gauge.
Jan 24, 2015 | Motorcycles
What volume of fork oil do i need for a yamaha ttr110 2009
Hi, Anonymous for this scenario you will need your service/owners/ manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Changing fork oil on TTR110 TTR
Fork Oil Quantities
YAMAHA TT R125 Owner Service Manual
OEM parts for Yamaha
Yamaha TT 110 Owner Manual
Sep 26, 2013 | 2009 Yamaha TTR110E
Correct measure fork oil?
Normally, the fork oil level is set with the spring out, and the fork fully compressed. Fill the fork to 110-120mm from the top.
Jul 27, 2013 | kawasaki Motorcycles
Wireing for a sdg pit bike
110cc sdg pit bike is not getting any spark what are some causes that it isn't getting spark please help!!
Aug 19, 2012 | Pit SSR 110CC Pro Beginner Bike
Replace fork seals ttr110 2008
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
How To Replace Fork Seals On Dirt Bike TTR125
2009 YAMAHA TTR 110 SERVICE REPAIR MANUAL PDF DOWNLOAD Download Manuals... $10
Jan 30, 2012 | 2009 Yamaha TTR110E
Honda XRM 110 fork oil capacity
Hi, Eadc11 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to Change Fork Oil
http://www.answers.com/Q/How_much_oil_in_the_front_fork_Honda_xrm_125?#slide=1
Honda Xrm 110 Service Manual Free
https://www.partsfish.com/page/oem-parts-for-honda
https://www.google.com/search?q=honda+xrm+110+owners+manual+pdf&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjugoqC4YrZAhWMk1kKHQx_C_0QsAQIPA&biw=1366&bih=637
Feb 14, 2011 | Honda Motorcycles
1983 Bmw R80 st Going through a curve, especially to the right, I get a shimmy. Jerry
check head race bearings for pitting and swinging are frame bushes for wear,, also check the shockers and forks refill forks with fresh oil,,,
ps,,hitting the road hurts!!
May 28, 2010 | 1984 BMW R 80
How do you set fork oil level 93 sprint 900 air gap 110 mm is it with fork extended or compressed spring in or out
It is with the fork extended. You need to no how many CC's of oil to put in so call the local dealer and ask the mechanic.
Oct 18, 2009 | 1993 Triumph Trident 900
How much oil for 2003 yz 250f fork seals
3 Pints is average but you can adjust it to your riding style and weight. Stock oil height is around 130mm from top but you could set it around the 110 to 100 range for increased bottoming if you do a lot of big jumps ect.. 5w oil is the usual weight but fork oil goes up to 20w.
-John
Jun 03, 2009 | 2003 Yamaha YZ 250
'85 xj700x: My right fork is leaking what appears to be oil!
The air is on top of the oil. You still have to change to fork oil (and dust) seals. Not hard, messy. Use your digital camera as a guide to help you re-assemble the unit. Do one at a time. Support the motorcycle securlely.
Apr 12, 2009 | 1985 Yamaha XJ 700 X Maxim
Pit SSR 110CC Pro Beginner  Bike Logo
132 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Are you a Pit Cycling Expert? Answer questions, earn points and help others
