Question about Epson Stylus Photo R200 InkJet Printer
My epson r200 works great printing on paper and as well as cd/dvd until yesterday when i tryed a cd it pushed out the cd tray and the 2 buttons stared blinking but when i close the tray it stop?????
  • 54 Answers
Try to reset the priter, by presig for 5 secods. if does'work, try to realign the cartridge ad pritheads ( with printer soft)
Posted on Mar 23, 2011
  • jst4ucolton Mar 23, 2011
    doesent work and how do youb reset
Epson R260. Brand new. Green light blinks, red stays on.
https://www.manualslib.com/manual/357821/Epson-Stylus-Photo-R260.html?page=55#manual says Epson's manual thinks Red
paper out light ) is on and green P power light flashes means
If you're printing on paper, your paper ran out or multiple
pages have fed at once. Make sure you push the tray lever
up to set the front tray to the paper (lower) position. Then,
load more paper and press the ) paper button to resume printing.
If you're printing on a CD or DVD, the CD/DVD tray is not
inserted. Follow the instructions beginning on page 27 to
insert the tray, then press the ) paper button.
Nov 06, 2017 | Epson Stylus Photo R260 InkJet Printer
The epson printer driver dealing with cd printing is not installed
is there an ok button on that error message? if so just click on OK button and click on a button says manual.
It will let you check on the settings on the printer. paper size should be A4.
on print settings it should let you select on cd/dvd
Note: this only works if you have installed the epson easy print from the epson.com website of your printer model
Feb 07, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson stylus photo R300 cd/dvd tray not set correctly
I had the same problem. Restarted the printer. Reinstalled the drivers. Scratched my head ... nothing! then I moved the printer away from the wall - problem solved! I can't say that this will work for you but if everything else is working, as it was and still is on mine then it's worth a try.
What I didn't realsie was that the cd tray comes out of the back of the printer when it's checking the alignment. I had inadvertantly pushed the printer back, too close to the wall. Moved it forward slightly and it's fixed.
Hope that solves it for everyone.
Nov 16, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson stylus photo r220
Hi - have you tried giving the tray a little push; I had to do it with my R200; one minute it was fine the next I received the same message as you - Might work - brand
Sep 19, 2008 | Epson Stylus Photo R220 InkJet Printer
Re: DVD labels won't print on my Epson R265
Hello guys.
About the problems printing CD/DVD with your Epson R265 ....................
There is nothing to do. The prg coming with the printer (PrintCD) is wrong at all and we cannot understand why the Epson Corp. has simply deleted the prg by its download site.
After tryng for a lot of solutions ........ INCREDIBLE but TRUE ..... the program Print CD coming with the previous Epson R200 is ok at 100% !
So, in conclusion, all prgs inserted onto the Epson R265 CD are OK eccept the Print CD. Don't install it from the R265 disk ! It will crash !
If already installed, delete it and install the prg Epson R200 print CD.
It will work fine and without troubles.
Repeat ... it's incredible, but true.
The prg can be downloaded searching for Epson R200 software.
If you will have troubles, let me know.
Aug 23, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson stylus r200
(1) Check you have about 6 inches clearance at the back of the printer
(2) When loading the CD Tray, Align the arrows then when the printer starts to feed the tray, give the tray a gentle push towards the back of its direction of travel. That seems to help on my R200
Nov 28, 2007 | Epson Stylus Photo R200 InkJet Printer
Unable to print on DVD/CD
The latest R800 driver for Windows
epson12379.exe
(which is probably required for Vista as well as XP) has a hardware interface problem.
When you try to print on a CD, the power button should blink slowly and the paper feed button should turn red until the media (CD) is readied by holding the paper feed button down for a second. However, with the driver above, the paper feed button instead blinks very fast (the printer is being "probed" by the PC in a tight loop I would guess) and so the CD cannot be readied.
The previous version of the driver,
epson11222.exe
does not have this problem. But I doubt it will work under Vista.
If you would like this driver e-mailed to you, send me an e-mail to my "junkmail" account asking for it (include this documentation so I know what you want) and I will send it.
My junkmail account is jim3 underline porter6 at fastmail dot fm
(underline, at and dot are not words but single characters)
Sep 04, 2007 | Epson Stylus Photo R800 InkJet Printer
Printing directly on a cd or dvd
You should clean the white printed marks on the CD caddy. the "magic eye" relies on these marks to accurately assess where the CD is.
If it still struggles after cleaning the white alignment marks, clean the exit rollers with something like windowlene/windex to ensure they have sufficient grip.
Jun 13, 2006 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
