Question about Yamaha 88 Key Digital Piano w Stand YPG635B
I have a yamaha p150, and the sustain is not working. I have used different pedals, and did a did factory reset, and hasn't helped. Can u help me?
  • facdiva77 Mar 24, 2011
    how do u check the polarity on the p150 keyboard?
    When u say adapter, u mean pedal right? Where on the pedal will I see the plus r minus?
    Genius:
  • 1,157 Answers
Hi facdiva77,
Just another thought about this issue. Have you already checked if it has cable breaks or if the contacts get dirty inside. There are two possibilities that sometimes caused this issue, either footswitches go bad or a dirty contacts. Here are some steps that you may apply for additional troubleshooting. Hope it may help you.
1. First, you can simply disassemble the system and clean it (specially the contacts).
2. The other thing is the polarity, sometimes keyboard read new polarity due to power glitches. Most of the time it can be very dirty at venues so please check the power.
3. Check the power cord connector. Sometimes the power cord connector can become marginal causing momentary power loss.
Hope it helps.
Thank you for using FixYa.
Posted on Mar 23, 2011
  • Reynaldo Labaguis Jr.
    Reynaldo Labaguis Jr. Mar 24, 2011
    Hi facdiva77,
    You can easily determine the polarity by its symbol. Polarity is a little symbol like letter [C] with a protruding out of the opening of the [C] symbol. At the end of the line you will see a [+] or [-]. That would tell you the polarity of the [tip]. If you can see [+] on the keyboard then you need to use an adapter that also says [+]. If it says [-] on the keyboard then you must use an adapter that says [-]. If you already used an adapter with the wrong polarity, you may have damaged the circuit in the keyboard.
    Hope it helps.
Sustain issue with Yamaha MM8
Your pedal may be the wrong polarity for this keyboard. Different manufacturers wire differently. And some use trs 1/4" and others use ts 1/4". Contact Yamaha customer service to get the correct pedal for your instrument.
Apr 08, 2016 | Yamaha MM8 MUSIC SYNTHESIZER
Sustain Pedal works intermittently.
To start with always best to use the correct power supply these should be readily available from any good Yamaha store. Is the sustain pedal a Yamaha pedal? The plug end of the pedal connect a multimeter across the two connectors and set meter to show continuity. If there is no continuity press pedal, hopefully this will now respond. If not then the break is in the pedal. If meter idea works then it could be the socket on the keyboard, these can work loose on the pcb they are mounted to if they are used a lot.
You could open up the keyboard and look inside checking the solder joints on the socket or simply take to a Yamaha service centre.
You could also try a master reset of the keyboard, hold down the highest note whilst turning on, this will reset to factory default.
Let me know how you get on.
Nov 02, 2015 | Yamaha NP-30 Portable Grand Piano &...
Ctk-651 sustain pedal working backwards
Buy sustain pedal made for CASIO or switable model.
Pedal for Yamaha or Roland will work in reverse on a Casio.
If you cannot return for exchange, then open up and solder a different type of micro switch.
Dec 31, 2013 | Casio Keyboard Ctk-481 Ctk-631 Ctk-651
Sustain pedal does not work
Yamaha FC4 and FC5 sustain pedals are normally closed, sorry Fred. Roland is opposite. I suspect the P120 just needs to be reinitialized. Hold down top white key (C) while turning on power. Wait 3 seconds and then release white key. Should now be reset to factory spec. Always plug the pedal in before you turn it on. If it still doesn't work check it with a meter.
Mar 17, 2012 | Yamaha CP300 Stage Digital Piano...
Hello- my P95 sustain pedal does not work when plugged in but the sustain works when you disconnect the cord from the back of the keyborad
This is confusing... you say "the sustain works when you disconnect the cord"? How can that happen? and doesn't work when it is plugged in.
MOST sustain pedal problems are due to people using a different pedal than the keyboard is designed to use. It is very common that someone tries to use a Roland sustain pedal on a Yamaha and oof course it doesn't work because the Roland pedal is normally closed and Yamaha usually requires a normally open contact.
A FEW keyboards now check the state of the pedal input when power is first turned on and configure the pedal polarity accordingly. For these keyboards, make sure the pedal is plugged in before power is turned on.
Apr 02, 2011 | Yamaha P95 Digital Piano
Hi. I'm Using PX330 as a midi controller that plays "Galaxy pianos" in cubase 5. I'm interested in buying a continuous sustain pedal (the one I got with the piano is an On\Off pedal). can you...
The Yamaha FC-3 uses a TRS (three conductor plug). The PX330 does NOT use TRS jacks for the sustain and sostenuto pedals so they are NOT compatible with the Yamaha FC-3. Therefore I would conclude that continous sustain that the Yamaha pedal would be used for is NOT supported.
Feb 15, 2011 | Casio Privia Keyboard Case
The Sustain pedal does not work.
When push comes to shove, a factory reset never hurts.
Assuming you'd like to proceed with a factory reset, follow these steps:
This procedure makes it possible to restore the S08 to the original factory-installed Internal Voices, Multis and System settings.
WARNING: The current settings for all Multis and User Voices will be deleted. If the current settings and data are not expendable, create a backup before executing the Factory Reset.
1) Press the [UTILITY] button.
2) Press the [JOB] button. The 'FactorySet' screen will be displayed.
3) Press the [ENTER] button. The 'Sure?' message prompt will appear.
4) Press the [INC/YES] button to execute the Factory Reset. The 'Completed!' message will be displayed to indicate the procedure has been successfully executed.
5) Press the [EXIT] button to return to the Utility Mode.
Oct 14, 2017 | Yamaha Full-Size Keyboard
Is a sustain foot pedal similar to a tattoo machine pedal?
The sustain pedals have only two wires. Usually they terminate in a 1/4 inch mono plug.
yamaha USUALLY sustains when switch is closed. Roland usually sustains on a switch between the wires when the switch is open.
NO POWER should be supplied BY the sustain pedal... it is ONLY a switch.
Apr 19, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
Sustain Pedal Opposite Effect
I found that if I plug in the sustain pedal BEFORE turning the power on, it works fine. If I plug in the sustain pedal AFTER turning the power on, then it works in the opposite way. Probably just the design. So I would try playing with that before doing anything drastic.
Feb 16, 2009 | Yamaha Full-Size Keyboard
Yamaha 88 Key Digital Piano w Stand YPG635B Logo
107 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
