My wash will not stop spinning, even after its unpluged ?
  • 157 Answers
Check brushes in motor.
Posted on Mar 23, 2011
Water pump shorted out. Now will not stop running unless washer is unplugged
oops you shorted the control board and now it needs more fixing at more expense
Jul 13, 2016 | Kenmore Elite Oasis 27052 Top Load Washer
Maytag is clicking when its going to weigh clothes and spin at the end of cycle
It's a faulty relay on the control board. If you remove the top panel and remove the boards you will find a spot burned out on one of the relays. If you know how to solder then you might be able to repair it.
Mar 04, 2014 | Maytag Bravos MTW6600T Top Load Washer
I have a whirlpool wfs1072Aw 7.5kg washer that has stopped spinning and won't start even the wash cycle
You probably have either a bad gearcase, timer, or lid switch. Defective motor is also possible.
May 08, 2012 | Whirlpool Washing Machines
We are having same problems as this customer... I wish I had a solution, I have the same issue. My WHDRE526EWW Top Load washer stops intermittently sometimes while filling up, sometimes while rinsing,...
I had the same issue as well. A friend of mine, who does appliance repair said the control board was bad. Had a 5 yr extended protection plan so warranty repair, otherwise looking at @$500. Fixed the problem and have not had it since then (almost 2 yrs now). Hope this helps.
Jul 20, 2011 | General Electric WHDRE526EWW Top Load...
LG 8kg Fuzzy logic top loader and it will wash and fill the water but the water wont stop when it wash, rinse or spin it, the water also come out even there is no power to the machine.
Assuming the water is coming in even when unit is unplugged from wall. You should to replace the water inlet valves where the hoses connect to the machine. You need to unplug the power and remove the top, disconnect the hoses unhook the wire harness plugs, unscrew the hose valve hex nut and remove valve. Install the new one in reverse order.
May 16, 2011 | Washing Machines
My washing machine (model AQXL 95) will not go onto spin mode and I cannot open the door - I have a duvet inside and it will get to the spin mode and then stop. I have tried switching it on/off, tried...
when I wash heavy stuff it will not spin properly because the weight is not distributed evenly over the load and it stops every time. you may need a repair man unless you can just move the dial to a drain spot rather than spin, if enough water gets out it will probably open then.
Feb 03, 2018 | Ariston Technologies Washing Machines
GE adora WHDRE526EWW when started it begins to fill then stops filling and have to restart sometimes three to four times help!!!.
I wish I had a solution, I have the same issue. My WHDRE526EWW Top Load washer stops intermittently sometimes while filling up, sometimes while rinsing, sometimes while washing and sometimes while spinning. I just have to guess when it's going to stop and check on each load frequently to restart it when it stops. Sometimes I can't even get it to start spinning again and I will have to unplug it and plug it back in and then it will spin. Hope someone can help!
Jan 05, 2010 | General Electric WHDRE526EWW Top Load...
HELP
ww.repairclinic.com/RepairHelp/RepairHelp.aspx
www.acmehowto.com/howto/appliance/washer/washer.php
home.howstuffworks.com/how-to-repair-a-washing-machine.htm
http://www.managemyhome.com/mmh/Troubleshooting_Guides/TopLoadWasher.pdf
Nov 16, 2009 | Washing Machines
After the washing cycle it stops. It will not
HI, i would try a hard reset in this case. unplug the unit for five minutes. this will reset the logic sectors. if this no spin issue continues, replace the motor control board.
Sep 21, 2009 | Whirlpool Washing Machines
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
