Question about Dryers
Error code e10 on zanussi zjd1219 - Dryers
  • 1 more comment
  • Anonymous Mar 24, 2011
    hi rick erm its fitted into the kitchen unit lol i have no idea how to get to it sorry for being dumb
    when you say change out the water valve what does this mean replace??
    also i have looked at the manual for the washer and where it says
    the machine does not dry or does not dry properly
    the drying time has not been selected....its not this
    the water tap is not turnrd on.....its not this
    the drain filter is clogged.....its not this
    does not say anything about wiring water valve or main control board???????
  • 1,998 Answers
E10 on the drying cycle normally indicates a failure to take in water during drying
this is usually a failure of the triple water valve unplug your unit take the top off you will see the valve at the rear of the appliance change out the water valve and you should be up and running again the service manual states that it could be the triple water valve , the wiring , or the main control board if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation it allows me to help others in similar situations Thanks Rick
Posted on Mar 23, 2011
  • 2 more comments
  • Rick Ead
    Rick Ead Mar 24, 2011
    hello Missy,
    does fitted into the kitchen unit mean that the machine is inside of a closet area? if this is the case you would have to remove the entire unit out of the closet area so that you can access and have room to work on your unit. there are three screws along the back of the unit that hold down the top panel unscrew these and slide the top panel towards the back of the machine then remove the top panel. if you have any further questions message me back I try to achieve 100 percent customer satisfaction on all my chats. If needed I can walk you through step by step to replace the valve.One of the first things you do in any type of appliance repair is unplug the machine. Message me back with any further questions that you may have I await your reply Thanks Rick
  • Rick Ead
    hi missy, that error code refers to water is not going into your machine either your water valve is off or water is not able to go past the water valve which would mean the water valve is faulty if the water to the unit is turned on then this would be a bad valve I await your reply Thanks Rick
    ps if you have the water faucet off this would also cause this error code and you would unplug the machine for 7 minutes and turn the faucet on and after 7 minutes replug you unit in and try again running the unit and see if the error 10 comes up again Thanks Rick
  • Rick Ead
    I await your reply if you need any further help in this matter message me back and please remember to rank how this opinion has helped when our chat has fully concluded Thanks
    Rick
  • Rick Ead
    Rick Ead Mar 25, 2011
    hello missy,
    awaiting your reply on how you made out Thanks Rick
My Zanussi ZWF14581 washing machine shows an error
The error code E10 is in relation to low water pressure.Have you checked that the hose at rear is not kinked or check the filters in the ends of the hose.Also make sure when you have hose off check the pressure in the supply.If all that is ok then it could be a faulty solenoid valve.
Hope this helps.
May 09, 2010 | Washing Machines
Drum noisy when in high speed spin
Problem for Zanussi ZJD1219 Front Load All-in-One Washer / Dryer How do i change the main bearing please?
Feb 02, 2010 | Zanussi ZJD1219 Front Load Washer / Dryer
Zanussi ZJD1219 Washer/Dryer - noisy spin and dirty spots
Sounds like the main drum bearings have failed, and the marks on clothes are probably grease spots from the main bearings.
It is quite an involved repair, and not one that I would recommend you tackle yourself unless you are competent to do so,as it really is involved.
Please rate my solution.
Thanks.
Nov 15, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Zanussi ZJD1219 Not Drying
check safety overheat button due to faulty stat or blocked vent,burnt element connections,blown element hope this helps
Apr 07, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
E10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi zjd1219
Hi
Machine is showing E40 ERROR
Sep 07, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Error code 20
Hi, I also got the error code E20 when the filter became totally blocked during the washing cycle (due to a pair of my son's old work jeans!). Once I cleaned out the filter everything worked ok again. Put a large bowl under the filter as you unscrew it; a fair amount of water could be there. Regards, John
Sep 04, 2006 | Zanussi ZJD1219 Front Load Washer / Dryer
Dryers Logo
254 people viewed this question
Top Dryers Experts
