Question about Toastmaster 217 Cool Touch Belgian Waffle Maker
I have lost the instructions to this waffle maker. How do I take it apart to clean it? thank you.
  • Toastmaster Expert
  • 684 Answers
Download man at www.middleby.comual
Posted on Mar 31, 2011
SOURCE: waffle mix spilled over entire waffle maker, inside and out
Is this question for real? If you can't figure this one out on your own, maybe you should stick to IHOP.
Posted on Dec 21, 2008
SOURCE: removing top of waffle maker to clean it
The other night my wife had the same issue. My thought had always been to wipe it down using a wet cloth with simply hot water and rely on the extreme heat of using it to sterilize it.  My wife decided instead to disassemble it.  The problem is that it is not made to disassemble and she bent some parts and broke others and stripped out screw heads.  It is clean now, but can not be reassembled without extracting stripped screws and replacing some parts. My advice to you is - don't try to disassemble it. The factory went to great lengths to ensure that you don't.  Instead use a soft cloth dampened (not dripping wet) with the hottest water you can.
Posted on Dec 29, 2008
  • 33 Answers
SOURCE: No instructions for used Sunbeam#3856 waffle maker
sunbeams customer service 800-458-8407
oster customer service 800-334-0759 Try both of these numbers one should tell you where you can download and print your manual. let me know if this helped. goofballlovers
Posted on May 21, 2009
  • 33 Answers
SOURCE: I need instructions for a waffle maker mine are lost
When making a waffle have your batter made plug in your maker and get it started heating if there is a light it will go off whenit is hot enough if not wait aprox 2-3 minutes at the most 5 then spay or brush the inside of the plates with a nonstick cooking spray or brush with butter then pour your batter in the center of the bottom plate and close the lid it should start steaming right away watch the steam it is a never fail indicater of how done your waffle is the less steam the more done your waffle is, there is a lot of trial and error with waffle makers, you should spay or brush between each waffle or they will stick. Let me know how it all cooks out. goofballlovers
greenspan
  • 1734 Answers
SOURCE: Need instruction manual for oster waffle maker model 3871
Ask here, it seems they can get you every Oster manual
Posted on Jul 03, 2009
Waring Belgium Waffle maker shorted out and blew house breaker.
The wire near the fuse is shorting out on the metal under the lower grill. Mine did that when I replaced the fuse and turned it on. If not under warranty, it is easier to replace it for $39.95 from Costco than the hassle of taking it apart and trying to replace the fuse, which involves the time to take it apart, buying a fuse and either the crimper and connectors or a soldering iron and high temp solder, since the regular solder melts shortly after it begins heating.
Nov 12, 2011 | Waring WMK300 Professional Belgian Waffle...
I lost the instructions for my sunbeam waffle maker, and I dont know how long Ihave to bake it.
Here is a direct link to the User's Manual for your appliance:
http://dl.owneriq.net/d/db0acd4e-57c1-43f0-a51b-4ef04ad30e2d.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 2 of the manual for detailed operating instructions. Basically they read as follows:
Preparing Waffles
1. Close Waffle Maker and plug into outlet. Use only voltage specified on bottom of Waffle Maker. The Power light (Red) and Ready light (Green) will come on.
Caution: Touch Waffle Maker only by handles during use or directly after use. Take care not to touch hot surfaces.
2. The Waffle Maker is ready for initial use when the Ready (green) light goes out (approximately 2-4 minutes).
3. Open Waffle Maker, pour approximately 3/4 cup waffle batter onto grids. For best results, pour batter around outer edge of waffle maker. Close cover. It is very typical to have a small amount of batter run over grid and down Waffle Maker. However, if an excessive amount of batter runs over, use less batter.
4. Close the Waffle Maker by lowering the upper plate onto the lower plate and secure with the safety latch. Do not open cover while steam is escaping. Most waffles bake in approximately 2-4 minutes, depending on personal taste. Waffles are generally done when the Ready light (green) goes out and when steam no longer escapes from sides and front of Waffle Maker.
5. When waffles are done, remove with a fork or wooden tongs. Note: Be careful you do not scratch the non-stick cooking surface.
6. Close cover and wait for Ready light to go out before preparing another batch of waffles. The next waffle may be baked in less time because the plate will store heat.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 31, 2011 | Sunbeam 3852 Waffle Maker
Cleaning your waffle iron WPLT4
Let me start by telling you WHAT NOT TO DO.
  1. Never clean a waffle maker while it's still hot. Let it cool completely.
  2. Never dunk your entire waffle maker in water.
  3. Never use scouring pads, steel wool or abrasive cleansers.
  4. Never use a knife or pointed object to clean your waffle maker(I've actually seen that advised on less reputable sites).
When it comes to cleaning a waffle maker, your first source of information should always be the owner's manual. There are many different kinds of waffle makers, so your buddy Mr Breakfast will gladly defer his expertise to the company that makes your waffle maker.
What I can speak about is my own favorite waffle iron. It's a modern electric waffle iron with non-stick and non-removable baking plates. That's the same kind you have? Oh good. It looks like you came to the right guy.
Cleaning the baking plates:
  1. Remove any small puddles of oil with a dry paper towel.
  2. Brush away any crumbs with a soft-bristled kitchen brush or old toothbrush.
  3. Remove any batter stuck to the iron with a rubber spatula.
  4. To remove really-stuck-on batter, douse the baked-on batter with cooking oil. Wait 5 minutes for the batter to soften. Dab the batter off with a paper towel or cloth.
  5. To prevent staining and long-term oil build up, wipe down the baking plates with a damp cloth or paper towel.
  6. Make sure the waffle iron is completely dry before storing.
To clean the exterior, wipe down the housing and handle with a damp cloth.
Keeping it clean:
There are a couple things to remember to make sure our kind of waffle maker stays clean.
  1. Unless stated otherwise in the manufacturer's instructions, you should never coat the baking plates of a non-stick waffle iron with cooking spray. Over time that will give you a gummy build up that will turn your waffle maker to junk. Today, when a waffle maker makes the claim that it's non-stick, they really mean it. The only oil you need is the oil in the recipe. If your waffles are sticking, it's your batter that needs more oil, not your waffle maker.
  2. Unless stated otherwise in the manufacturer's instructions, don't use soap to clean your baking plates. Soap can be the enemy of a non-stick surface. Oil - on the other hand - can be a great friend. It creates a thin layer that helps maintain the non-stick surface. Soap will completely obliterate that layer of friendly oil. Harsh soaps can deteriorate the manufacturer's non-stick surface over time.
Mar 05, 2011 | Salton WM4 Waffle Maker
I bought a Krups Household Type Waffle Maker at a thrift store. It looks new, but doesn't have any instructions with it on how much batter to use or how to clean it. I got a recipe online and it was great...
I think this is why people make pancakes. =) Cleaning the waffle iron is a real pain. My waffle maker looks exactly like the one you have pictured. Mine also came with no instructions because its my fiance's. As far as how much batter to use, you should use a ladle and through trial and error figure out how much is the best amount. I would guesstimate approximately 1/4 c. For cleaning the overspill, from what I have read online, everyone says to unplug the iron (obviously) and wait until the waffle iron has completely cooled before cleaning. I have cleaned the back of the unit (where the coils are, which unfortunately got flooded with batter the first time) with a damp kitchen brush, damp sponge, and paper towels. Its messy and time consuming to clean up. You can get in the coils better with an old toothbrush or a very small bottle cleaner (like the kind you would buy to clean cake decorator tips). I just use warm water to remove the batter/gunk. I use a sponge (damp with warm water) to clean the baking plates. I towel dry everything after its clean, and clean the outside with a little windex so it stays nice and shiny. Good luck! I also recommend making lots of extra waffles and freezing them, so you can avoid as much waffle clean-up as possible. ;) You can heat them up in the toaster like Eggos. They stay good in the freezer for up to 6 months.
Sep 21, 2010 | Krups 65475 WaffleChef Waffle Maker
To whom it may concern, I lost my instructions
You can download the instructions manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
  • To magnify the text of the manual, click the [+] button in the Adobe Reader window.
Hope this solves your problem. Thanks for using FixYa.
Jun 22, 2010 | Black & Decker G48TD Grill & Waffle Maker...
Waffles sticking in a Salton wm-4.
Salton wm-4! one of the oldest waffle maker. The waffle is generally known to be difficult to clean. I would only advice you should always grease the plate before use. This helps make cleaning easy. You can also check our post on The Best Waffle Maker in 2017 The best waffle maker 2017 Easy buying guide Kitchenutilitypro
Sep 24, 2017 | Salton WM4 Waffle Maker
Waffle mix spilled over entire waffle maker, inside and out
If it is a non-stick surface brushing cold water on with a pastry brush while it is still ver hot and immediately after removing the food will clean the surface easily. As for the outside, if it is a painted surface a non- abrasive cloth with warm water could possible clean it. I would not recommend pulling it apart.
Sep 06, 2008 | Kitchen Appliances - Others
Toastmaster 217 Cool Touch Belgian Waffle Maker Logo
215 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oscar Netto
Oscar Netto
Mohamed Ismail
Mohamed Ismail
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
