Question about IBM Wheelwriter 30 Typewriter
I need directions for installing a correction tape on wheelwriter 3500
  • IBM Master
  • 3,594 Answers
The correction tape just snaps on the bottom of the ribbon.
For a manual Go to http://support.lexmark.com/index?page=content&id=SO4998&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT
DickyO
Posted on Mar 24, 2011
Is there an auto correction feature
The key to the right of the spacebar with the "X" printed on it is the correction button. You just place the carrier on the character to the right of the wrong one and hit the corr. button. The carrier should automatically back up and and remove the incorrect character and if you hold the key down it will continue to back up and remove characters. then you just type in the right one(s). Of course you have to have good "correctable" ribbon and correction tape cartridges installed. If the tapes are old you may have to advance them by typing and correcting or by manually advancing them before they will work. If the correction doesn't remove all the ink from the paper you may have a bad ribbon and/or correction tape.
Sep 17, 2015 | IBM Wheelwriter 3500 By Lexmark Electric...
What'sIBM Wheelwriter 2 , does not erase word
You may have a non correctable ribbon or the correction tape is old,
Try a fresh ribbon and L/O tape.
DickyO
May 11, 2012 | IBM Lexmark Personal Wheelwriter 2...
The correction tape will not erase properly
If the tape is moving and showing marks of correction attempts you probably have old supplies or a non correctable ribbon. Install a fresh ribbon & L/O cassette NOT AN OLD ONE FROM THE BACK ROOM.
DickyO
Oct 20, 2011 | Lexmark Wheelwriter 1500 Typewriter
Typewriter won't erase letters completely.
Correction tapes do have a shelf life and can dry out. You should try replacing the correction tape and see if it is better. If that does not fix it, does the tape lift up high enough to cover the entire letter? If not, you have a lifting problem and will need a tech to fix it.
May 28, 2010 | IBM Wheelwriter 6 Typewriter
I changed the correction tape on our IBM wheelwriter 3 and it doesn't seem to be lifting the error. Any advise? The correction tape is not old and I had already tried moving it a couple of inches but it...
You may have a very old correction tape or ribbon, a non correctable ribbon or it isn't properly installed
Go to LEXMARK.COM for a downloadable manual.
DickyO
Mar 31, 2010 | Lexmark Wheelwriter 3 Typewriter
IBM Wheelwriter correction tape will not lift off print. New correction tape installed.
You may have a very old L/O or ribbon. The ribbon may be a non correctable the knob must be orange, yellow or violet. Not blue or red.
DickyO
Mar 31, 2010 | IBM Wheelwriter 30 Typewriter
I need correction tape for a ibm wheelwriter 30
Here is a link for the correction tape you need from staples. It simply snaps under the print ribbon you already purchased
http://www.staples.com/office/supplies/p1__32346_Business_Supplies_10051_SEARCH
Jan 16, 2009 | IBM Wheelwriter 30 Typewriter
Correction tape on wheelwriter 3
The correction cassette snaps on the bottom of the ribbon. The two little "feet" on the cassette slide over the small tabs on the ribbon and the ribbon clips on.
Hope this helps
DickyO
Apr 24, 2008 | IBM Wheelwriter 30 Typewriter
Wheelwriter 3500 only printing top half of letters
Sounds like the platen is not fully seated in the side frames, align the black latches with the frames and press firmly on both sides of the platen. the latches do occasionally crack in witch case you may need a platen replacement.
DickyO
Mar 20, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
100 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
