Question about Home
Water in shower is too cold how di I adjust the thermostat control. It is turned up as far as it will go. Rest of hotwater is fine in rest of house.
  • 718 Answers
If you remove cover usually in the handle area most unit have an adjustment there, give it a try. Good Luck..
Posted on Mar 24, 2011
Uberhaus 75175006 shower column has very low hot water pressure
The shower head may be clogged with debris.
Nov 09, 2013 | Home
Got mira discovery mixer shower. wont get hot just luke warm or cold. taps in rest of house ok? Had it off the wall recently to tile behind it but apart from that been great for 6 years. any ideas?
There should be a hot water limiter behind the knob on the shower - shingle handle, undo the handle and move the adjustment to allow more hot water. Not familiar with mira discovery mixer
Feb 03, 2013 | Home
No hot water pressure
These types faucets have a what is called an anti scald valve build into them, it is required by law, it is either defective or out of adjustment, contact a local hardware store for more detailed info.
Feb 02, 2012 | American Standard Plumbing
Shower goes hot then after few minutes cold then hot again and constantly up and down. this shower is only 2 month old and has done this since fited
it is possible that the hot mix valve needs to be adjusted higher or there is a crossed plumbing line somewhere down the line. ( just wondering(?) are you tapped off a standard hotwater tank or a hotwater on demand system ? ). also, how is the hot water throughout the rest of the house ?
c...
Dec 29, 2010 | Home
Turn on shower, only a little bit of heat but only when you really turn up temp gage. there's no power light on as well.
make sure the rest of the house is getting good hot water to rule out a problem with your hotwater heater, if all other is ok then your shower valve may be clogged with trash on the hot side restricting flow and hot water. If its an ant scald shower valve you may need to raise the temp control.
Oct 26, 2010 | Home
Just had a single handle shower faucet installed in my new walk-out developed basement and it seems there is a control on it I want to remove. I can't get the handle to go beyond mid-point and I want more...
Hi im Rossouw
The rest of ur house water in the showers fine?
If not they must install a prv (Presure reducing velve) on the cold going to the house and geyser befor it t,s of to the house and even if the rest of the house water is fine u must ask ur plumber who intalled it if he took the cold water going to the new shower strait of the mains if so he must corect it by t-ing in at the right cold water supply or put a velve on the cold water to ruduse the cold presure . then u will have more hot presure and that means lovely hot shower
plz vote and rate my advice thanx
Jul 17, 2010 | Delta & Single Handle Shower Faucet
50 gallon electric heater not working after about 5 minutes in the shower the water gets cold and the rest of the house i do have 240 going to water heater thermostats goood element good
Some elements will read with a meter good until they heat up.
Hot water then going to ice cold top element is working and bottom bad. Luke warm water and then goes cold bottom element good and top element bad.
Elements and thermostats are not to exspensive to replace.
If you have power only two thing's left are the thermostat's and the elements.
May 21, 2010 | Water Heaters
Gainsborough Shower Running Cold
It sounds like you have a faulty thermostat or broken heater element.
Oct 08, 2008 | Home
Home Logo
53 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
